+DZ-Jay Posted May 30, 2014 Share Posted May 30, 2014 Any progress with this Jay?Sorry, I haven't had a chance to check it. I'm on the road this week-end, so it will have to wait have to wait until next week. Quote Link to comment Share on other sites More sharing options...
tacrec Posted May 31, 2014 Author Share Posted May 31, 2014 I'd also like to get rid of the highlighted player color, so that all players are one color, looks more like a team. Highlighted colors won't matter since the comp will be playing itself. I'm also thinking the Sharks team name is better for football. I'm thinking of replacing it. Which team name is better: Space Hawks or UFOs? Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 4, 2014 Author Share Posted June 4, 2014 Any progress Jay? Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 4, 2014 Share Posted June 4, 2014 (edited) OK, I just got home last night and tested it this morning. Using the Intellivision Rocks disc, here's what I did: Copied the files WS_Baseball.itv, WS_Baseball.cfg, and WS_Baseball.ivw to a local folder. I renamed the first file to change its extension to, WS_Baseball.bin From the command line, I navigated to that folder. I executed the command as before: $ dis1600 WS_Baseball.bin WS_Baseball-dis.asm The output I received was: SEGMENT ofs 0000 len 2000 addr 5000 FLAGS: R---P SEGMENT ofs 2000 len 3000 addr D000 FLAGS: R---P It seems to have worked. On a lark, I did the same thing to the third file (.ivw). I suspect this is a second ROM for another bank, and it mostly contains data. I don't know. -dZ. Edited June 4, 2014 by DZ-Jay Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 4, 2014 Author Share Posted June 4, 2014 Got it! Thank you! Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 9, 2014 Author Share Posted June 9, 2014 So I changed some colors and tried to assemble it using as1600 and I get a bunch of "undefined symbol" errors. Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 10, 2014 Author Share Posted June 10, 2014 Any help with this problem above? Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 11, 2014 Author Share Posted June 11, 2014 Any info on the EQU problem? Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 15, 2014 Author Share Posted June 15, 2014 Hey Jay, any help with the EQU problem? Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 15, 2014 Share Posted June 15, 2014 (edited) Sorry, I got distracted with other things. The "EQU" directive means "Equivalent," and is used to define a constant. When you say something like: X_RESET EQU $1000 it literally means "X_RESET is equivalent to $1000." This allows you to use symbolic names to represent other constant values, such as memory addresses. The assembler will automagically replace all such symbols with their equivalent base value. All that said, here are the EXEC constants supported by the "disasm" tool. I've extracted these directly from the source code. Just add the following snippet to the very top of the disassembled file, and you should be good to go: X_RESET EQU $1000 X_RET_R5 EQU $1003 X_ISR EQU $1004 X_ISRRET EQU $1014 X_CHK_KBD_OR_CBL EQU $101D X_INIT EQU $1026 X_READ_ROM_HDR EQU $10AB X_DEF_ISR EQU $1126 X_RAND1 EQU $167D X_RAND2 EQU $169E X_INIT_MOB EQU $16B2 X_INIT_MOBS EQU $16B4 X_FILL_ZERO EQU $1738 X_FILL_MEM EQU $1741 X_PACK_BYTES EQU $174F X_PACK_BYTES.1 EQU $1750 X_UNPK_BYTES EQU $1757 X_UNPK_BYTES.1 EQU $1758 X_GETNUM EQU $18FF X_PRNUM_LFT EQU $189E X_PRNUM_ZRO EQU $18AD X_PRNUM_RGT EQU $18C5 X_PRINT_R1 EQU $1867 X_PRPAD_R1 EQU $186C X_PRINT_R5 EQU $187B X_PRPAD_R5 EQU $1871 X_EXT_SIGN_LO EQU $1668 X_EXT_SIGN_HI EQU $1669 X_CLAMP EQU $1670 X_SET_BIT EQU $16DB X_CLR_BIT EQU $16E6 X_POW2 EQU $1745 X_TIMER_STOP EQU $1838 X_TIMER_START EQU $1844 X_PLAY_NOTE EQU $1ABD X_HUSH EQU $1AA8 X_PLAY_MUS1 EQU $1B27 X_PLAY_MUS2 EQU $1B5D X_PLAY_MUS3 EQU $1B95 X_PLAY_SFX1 EQU $1BBB X_PLAY_SFX2 EQU $1BBE X_SFX_OK EQU $1EAD X_STOP_SFX EQU $1EB4 X_PLAY_RAZZ1 EQU $1EBA X_PLAY_RAZZ2 EQU $1EBD X_PLAY_RAZZ3 EQU $1EC1 X_PLAY_RAZZ4 EQU $1EC4 X_PLAY_RAZZ5 EQU $1EC5 X_PLAY_CHEER1 EQU $1ED5 X_PLAY_CHEER2 EQU $1ED6 X_PLAY_WHST1 EQU $1F1B X_PLAY_WHST2 EQU $1F1E X_PLAY_WHST3 EQU $1F22 X_MPY EQU $1DDC X_DIV EQU $1DFB X_DIVR EQU $1DF8 X_SQRT EQU $1E23 X_SQUARE EQU $1DDB X_DO_GRAM_INIT EQU $1F2F X_NEW_GRAM_INIT EQU $1F35 Edited June 15, 2014 by DZ-Jay Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 16, 2014 Author Share Posted June 16, 2014 Thanks, but I'm still getting errors. This is the top of my asm file: ORG $5000 .HEADER: BIDECLE $D000 ; 5000 Ptr: MOB graphic images BIDECLE $F000 ; 5002 Ptr: EXEC timer table BIDECLE $F01D ; 5004 Ptr: Start of game BIDECLE $F183 ; 5006 Ptr: Backgnd gfx list BIDECLE $F012 ; 5008 Ptr: GRAM init sequence BIDECLE $F01A ; 500A Ptr: Date/Title DECLE $01E0 ; 500C Key-click / flags DECLE $0000 ; 500D Border extension DECLE $0000 ; 500E Color Stack / FGBG DECLE $0000, $0001 ; 500F Color Stack init (0, 1) DECLE $0005, $0000 ; 5011 Color Stack init (2, 3) DECLE $0000 ; 5013 Border color init Does the EQU's go above that? Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 16, 2014 Share Posted June 16, 2014 It doesn't really have to be above that, but I would recommend it. By the way, make sure that the symbols start at the beginning of each line, otherwise it won't work. What's the error you are getting? dZ. Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 16, 2014 Author Share Posted June 16, 2014 Here's an example of an error: MVO R1, G_01AD ; 50D6 0241 01ADbaseball.asm:222: ERROR - undefined symbol G_01AD50D6 0241 0000 MVO R1, G_01AC ; 50D8 0241 01ACbaseball.asm:223: ERROR - undefined symbol G_01AC Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 16, 2014 Share Posted June 16, 2014 OK, that seems to be my fault: I may have missed a few symbols in the list I provided. I'll review it when I get home, and update the constants list accordingly. Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 16, 2014 Author Share Posted June 16, 2014 Thanks. The number of errors were reduced with the new code added. Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 16, 2014 Share Posted June 16, 2014 (edited) Strange, I do not see those constants defined in the source. Moreover, those do not seem to be real labels, but placeholders for addresses. I wonder if you could replace the "G_" with a "$" to make them work. -dZ. Edited June 16, 2014 by DZ-Jay Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 16, 2014 Author Share Posted June 16, 2014 You're right! That got most of them. Now I'm seeing these errors: MVO R1, .ISRVEC.0 ; 5140 0241 0100baseball.asm:259: ERROR - undefined symbol .ISRVEC.0 MVO R0, .BTAB.62 ; 51C0 0240 0262baseball.asm:344: ERROR - undefined symbol .BTAB.62 JSR R5, .EXEC.730 ; 51C9 0004 0114 0330baseball.asm:350: ERROR - undefined symbol .EXEC.730 ...etc, Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 16, 2014 Share Posted June 16, 2014 Darn! I just saw those in the source while looking for the other ones. I'll do a full sweep tonight and update the list with all constants defined. Sorry about that. Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 18, 2014 Author Share Posted June 18, 2014 Any update Jay? Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 18, 2014 Share Posted June 18, 2014 Sorry, I was busy with work and some personal affairs. In looking through the symbols generated, I see that this is not going to be as straightforward as I thought. For instance, the disassembler's source code uses a symbol called .EXEC with a base of $1000 and a size of $1000 words. The disassembled code then includes made up symbols that represent offsets from the base, such as .EXEC.730, which represents $730 words after the base, or address $1730. This means that whenever you see something like .EXEC.XXX, you'll have to take the "XXX" as a Hexadecimal value and add $1000. The same is true for other symbols such as .STIC.X and .STIC.Y. I wish there was a way to disable these symbols from the code generation. I'll post the question in the programming forum. In the meantime, attached is the updated and complete symbol table. Any further errors will have to be fixed manually based on the derived symbols. ; ------------------------------------------ ; DEFAULT SYMBOL TABLE ; ------------------------------------------ .PSG0.chn_b_lo EQU $01F1 .PSG0.chn_c_lo EQU $01F2 .PSG0.envlp_lo EQU $01F3 .PSG0.chn_a_hi EQU $01F4 .PSG0.chn_b_hi EQU $01F5 .PSG0.chn_c_hi EQU $01F6 .PSG0.envlp_hi EQU $01F7 .PSG0.chan_enable EQU $01F8 .PSG0.noise EQU $01F9 .PSG0.envelope EQU $01FA .PSG0.chn_a_vol EQU $01FB .PSG0.chn_b_vol EQU $01FC .PSG0.chn_c_vol EQU $01FD .PSG0.rgt_hand EQU $01FE .PSG0.lft_hand EQU $01FF .PSG1.chn_a_lo EQU $00F0 .PSG1.chn_b_lo EQU $00F1 .PSG1.chn_c_lo EQU $00F2 .PSG1.envlp_lo EQU $00F3 .PSG1.chn_a_hi EQU $00F4 .PSG1.chn_b_hi EQU $00F5 .PSG1.chn_c_hi EQU $00F6 .PSG1.envlp_hi EQU $00F7 .PSG1.chan_enable EQU $00F8 .PSG1.noise EQU $00F9 .PSG1.envelope EQU $00FA .PSG1.chn_a_vol EQU $00FB .PSG1.chn_b_vol EQU $00FC .PSG1.chn_c_vol EQU $00FD .PSG1.rgt_hand EQU $00FE .PSG1.lft_hand EQU $00FF .ISRVEC EQU $0100 .BTAB EQU $0200 .GRAM EQU $3800 .GROM EQU $3000 .STIC.X EQU $0000 .STIC.Y EQU $0008 .STIC.A EQU $0010 .STIC.C EQU $0018 .STIC.VIDEN EQU $0020 .STIC.MODE EQU $0021 .STIC.CS EQU $0028 .STIC.BORD EQU $002C .STIC.HDLY EQU $0030 .STIC.VDLY EQU $0031 .STIC.EDGE EQU $0032 .HEADER EQU $5000 .ISRRET EQU $1014 .EXEC EQU $1000 .UART EQU $00E0 .ECSRAM EQU $4000 .IV.ALD EQU $0080 .IV.FIFO EQU $0081 .ECSCBL.POLL EQU $CF01 .ECSCBL EQU $CF00 NULL EQU $0000 ; ------------------------------------------ ; EXEC ROUTINES ; ------------------------------------------ X_RESET EQU $1000 X_RET_R5 EQU $1003 X_ISR EQU $1004 X_ISRRET EQU $1014 X_CHK_KBD_OR_CBL EQU $101D X_INIT EQU $1026 X_READ_ROM_HDR EQU $10AB X_DEF_ISR EQU $1126 X_RAND1 EQU $167D X_RAND2 EQU $169E X_INIT_MOB EQU $16B2 X_INIT_MOBS EQU $16B4 X_FILL_ZERO EQU $1738 X_FILL_MEM EQU $1741 X_PACK_BYTES EQU $174F X_PACK_BYTES.1 EQU $1750 X_UNPK_BYTES EQU $1757 X_UNPK_BYTES.1 EQU $1758 X_GETNUM EQU $18FF X_PRNUM_LFT EQU $189E X_PRNUM_ZRO EQU $18AD X_PRNUM_RGT EQU $18C5 X_PRINT_R1 EQU $1867 X_PRPAD_R1 EQU $186C X_PRINT_R5 EQU $187B X_PRPAD_R5 EQU $1871 X_EXT_SIGN_LO EQU $1668 X_EXT_SIGN_HI EQU $1669 X_CLAMP EQU $1670 X_SET_BIT EQU $16DB X_CLR_BIT EQU $16E6 X_POW2 EQU $1745 X_TIMER_STOP EQU $1838 X_TIMER_START EQU $1844 X_PLAY_NOTE EQU $1ABD X_HUSH EQU $1AA8 X_PLAY_MUS1 EQU $1B27 X_PLAY_MUS2 EQU $1B5D X_PLAY_MUS3 EQU $1B95 X_PLAY_SFX1 EQU $1BBB X_PLAY_SFX2 EQU $1BBE X_SFX_OK EQU $1EAD X_STOP_SFX EQU $1EB4 X_PLAY_RAZZ1 EQU $1EBA X_PLAY_RAZZ2 EQU $1EBD X_PLAY_RAZZ3 EQU $1EC1 X_PLAY_RAZZ4 EQU $1EC4 X_PLAY_RAZZ5 EQU $1EC5 X_PLAY_CHEER1 EQU $1ED5 X_PLAY_CHEER2 EQU $1ED6 X_PLAY_WHST1 EQU $1F1B X_PLAY_WHST2 EQU $1F1E X_PLAY_WHST3 EQU $1F22 X_MPY EQU $1DDC X_DIV EQU $1DFB X_DIVR EQU $1DF8 X_SQRT EQU $1E23 X_SQUARE EQU $1DDB X_DO_GRAM_INIT EQU $1F2F X_NEW_GRAM_INIT EQU $1F35 Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 18, 2014 Share Posted June 18, 2014 By the way, in case it wasn't clear, the base address for each symbol is the value in their corresponding EQU directive. Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 18, 2014 Author Share Posted June 18, 2014 I added the new header in, and added 1000 to the error values: JSR R5, .EXEC.1730 ; 51C9 0004 0114 0330 and still get these errors: JSR R5, .EXEC.1730 ; 51C9 0004 0114 0330baseball.asm:412: ERROR - undefined symbol .EXEC.1730 Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 18, 2014 Share Posted June 18, 2014 Sorry if I was not clear. You need to change something like ".EXEC.730" to "$1730". Essentially, convert the offset symbol to an absolute address. Remember, it's not just adding $1000; it is adding the value defined as the base address for the symbol. In the case of ".EXEC.730" we can infer it from the constant directive: .EXEC. EQU. $1000 Quote Link to comment Share on other sites More sharing options...
tacrec Posted June 18, 2014 Author Share Posted June 18, 2014 OK, got it. I don't see EQU's for .STIC.X.0, .STIC.A.1, etc. Those are the remaining errors. Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted June 18, 2014 Share Posted June 18, 2014 That's because they are ".STIC.X" and ".STIC.A"; you must add the offset to their corresponding base. Quote Link to comment Share on other sites More sharing options...
