gorf68 Posted May 24, 2014 Share Posted May 24, 2014 I'm looking for examples of one-button controlled games. E.g. things like Blitz on the VIC-20, or more recently flash games like Canabalt, or even the notorious Flappy Bird. I'm thinking of making a compilation of these type of games for the Vectrex. I've almost finished a Flappy Bird de-make and it didn't take long to write, so it got me thinking of other simple single-button games. Any ideas? Quote Link to comment Share on other sites More sharing options...
Jess Ragan Posted May 24, 2014 Share Posted May 24, 2014 Star Trigon (by Namco) is one. You slingshot from planet to planet, drawing lines behind you which can be used to contain and capture small space moles. Jetpack Joyride is another, where you run for as long as possible with a stolen jetpack. You control the jetpack with taps of the touchscreen, giving you a remarkable level of control for such limited input. 1 Quote Link to comment Share on other sites More sharing options...
Reaperman Posted May 24, 2014 Share Posted May 24, 2014 I bet it'd be fun to play two randomly selected one-button games at once using different halves of the screen. Quote Link to comment Share on other sites More sharing options...
DaytonaUSA Posted May 24, 2014 Share Posted May 24, 2014 One button games? Nearly everything on the 2600...? Quote Link to comment Share on other sites More sharing options...
BigO Posted May 24, 2014 Share Posted May 24, 2014 (edited) Pretty sure the OP must have meant one button and nothing else: i.e. no joystick. Don't some of the games on Air-Sea Battle play that way? [Edit]: I think I was thinking of Canyon Bomber I have an arcade machine called "Bombs Away" from 1976 that has just one button. Edited May 24, 2014 by BigO Quote Link to comment Share on other sites More sharing options...
50TBRD Posted May 24, 2014 Share Posted May 24, 2014 Similar to Star Trigon is Mr. Ninja for mobile. Homerun Derby. Quote Link to comment Share on other sites More sharing options...
50TBRD Posted May 24, 2014 Share Posted May 24, 2014 http://www.youtube.com/watch?v=OFuf_bR5K3s Quote Link to comment Share on other sites More sharing options...
Richard H. Posted May 26, 2014 Share Posted May 26, 2014 (edited) Mancopter Edited May 26, 2014 by Richard H. 1 Quote Link to comment Share on other sites More sharing options...
carlsson Posted May 26, 2014 Share Posted May 26, 2014 (edited) SpeedSki (VIC-20) by Dub Scroggin is played in a such way the skier always is moving to the right, unless you hold down a button which makes him move to the left. When you release the button, the skier resumes moving to the right. http://www.atarimagazines.com/compute/issue38/026_1_SPEED_SKI.php I'm sure you could come up with more games with more or less convoluted steering, e.g. a Frogger clone where a short tap on the button moves the frog forwards. If you hold the button for a second, a marker will alternate between left or right, and you release the button to move sideways. It would hamper the game speed though, unless holding down the button makes everything else stop. I suppose your motivation for one button games (no joystick) is to make them easier to play for people who are not used to or capable of handling both a stick and button(s) at once, so a convoluted method of steering with just a button might be counter-intuitive. Edited May 26, 2014 by carlsson Quote Link to comment Share on other sites More sharing options...
50TBRD Posted May 26, 2014 Share Posted May 26, 2014 http://www.onebuttongames.com/games/10/nano-ninja.html This website is dedicated to one button games. I thought this game was very interesting where the button did different things depending on the level. It throws a star, it makes you float, it holds you in place, makes you jump, etc. Space is the key was a little different too. 1 Quote Link to comment Share on other sites More sharing options...
+thegoldenband Posted May 26, 2014 Share Posted May 26, 2014 Sharp Shot on Intellivision. BTW a thread like this could be a great resource for disabled gamers; I'm sure there are other resources out there already, but probably none geared towards older games. Quote Link to comment Share on other sites More sharing options...
BigO Posted May 26, 2014 Share Posted May 26, 2014 http://www.onebuttongames.com/games/10/nano-ninja.html This website is dedicated to one button games. I thought this game was very interesting where the button did different things depending on the level. It throws a star, it makes you float, it holds you in place, makes you jump, etc. Space is the key was a little different too. That "Space Is the Key" reminded me a lot of Sears Steeplechase for the 2600 (except, of course, you don't set the jump height with the paddle). Quote Link to comment Share on other sites More sharing options...
famicommander Posted May 26, 2014 Share Posted May 26, 2014 Sonic the Hedgehog is a great one button game. Sometimes I play it with my CX-40, just because I can. Quote Link to comment Share on other sites More sharing options...
Don Calaca Posted March 20, 2017 Share Posted March 20, 2017 What about http://c1ic.mx/ In that site you use a single button to navigate and play, in the arcade section you have a bunch of mini games with the Atari 2600 style. http://c1ic.mx/arcade/ I hope these game are what you are looking for. 1 Quote Link to comment Share on other sites More sharing options...
toptenmaterial Posted March 20, 2017 Share Posted March 20, 2017 Does Dragster (2600) only have a one button operation? Quote Link to comment Share on other sites More sharing options...
Rom Collector Posted March 20, 2017 Share Posted March 20, 2017 Does Dragster (2600) only have a one button operation? No, it uses the joystick to change gears. Quote Link to comment Share on other sites More sharing options...
mr_me Posted March 20, 2017 Share Posted March 20, 2017 Sharp Shot on Intellivision. BTW a thread like this could be a great resource for disabled gamers; I'm sure there are other resources out there already, but probably none geared towards older games. The Sharp Shot games were meant to be played with no buttons and voice activation. They were programmed for a tv gameshow called TV Powww where callers scream into their telephone to play for prizes. The Intellivisions at the TV studios had to be modifed for voice activation. Quote Link to comment Share on other sites More sharing options...
