Gabriel Posted June 3, 2014 Share Posted June 3, 2014 So... Desert Bus as a rom image for the Genesis instead of a SegaCD disc image. Does it exist? Is a quick and easy isolation of the mini-game to a cart possible? Quote Link to comment Share on other sites More sharing options...
mkiker2089 Posted June 3, 2014 Share Posted June 3, 2014 Someone could port it at least. There's a fairly good (if you can call anything about this "game" good) for the Atari 2600. And yes, I own the abomonation. Collecting is a disease, don't judge me. Quote Link to comment Share on other sites More sharing options...
Lynxpro Posted June 6, 2014 Share Posted June 6, 2014 We need Desert Bus for the Jaguar! And then link the consoles so each player can take turns driving and being a passenger. 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted June 6, 2014 Share Posted June 6, 2014 So... Desert Bus as a rom image for the Genesis instead of a SegaCD disc image. Does it exist? Is a quick and easy isolation of the mini-game to a cart possible? Probably not unless someone has the source and all the tools the original developers had. You'd have much better luck recreating it in BasiEgaXorz. http://devster.monkeeh.com/sega/basiegaxorz/ UPDATE: For instance, this guy re-created Crazy Cars on the Genesis with BEX http://crazycarscpc.free.fr/indexEN.htm Quote Link to comment Share on other sites More sharing options...
+thegoldenband Posted June 6, 2014 Share Posted June 6, 2014 Is the entire game loaded into RAM? If so, and there's no in-game streaming from the disc, maybe there's a way to extract the code from an emulator RAM dump, though obviously it'd need to be extensively modified at best. Quote Link to comment Share on other sites More sharing options...
Tenorman Posted June 6, 2014 Share Posted June 6, 2014 Is the entire game loaded into RAM? If so, and there's no in-game streaming from the disc, maybe there's a way to extract the code from an emulator RAM dump, though obviously it'd need to be extensively modified at best. Yeah, even after that you'd have to modify to relocate everything to run from a cart and you'd have to modify the code to use none of the Sega CD specific hardware. You'd probably also have timing issues to fix because the 68000 in the Genesis is slower than the one in the Sega CD. It would probably be easier just to re-program it entirely. 1 Quote Link to comment Share on other sites More sharing options...
LynxVGL Posted June 9, 2014 Share Posted June 9, 2014 Java version here: http://desertbus-game.org/ Quote Link to comment Share on other sites More sharing options...
Flojomojo Posted June 11, 2014 Share Posted June 11, 2014 I would prefer to play this on mobile, so you can take it anywhere. Including on the (real life) bus. Android version: https://play.google.com/store/apps/details?id=com.tueidj.DesertBus iOS version: Desert Bus Charity site (as Lynx points out, they also host a Java version): https://desertbus.org Quote Link to comment Share on other sites More sharing options...
