JasonlikesINTV Posted October 10, 2014 Share Posted October 10, 2014 PCB is held down with some sort of glue that has an odor to it. I would recommend for new releases to reachout to intvnut and ask about using JLP cases for game. JLB cases are awesome for holding PCB secure without glue. Was your cart shell one of the older ones lacking the insert line reference? I got one like that as well as normal one. Apparently the internal retention points of the older shells were inadequate, so they glued them in. Pics coming on Sunday. My other cart was not like this. I'm sure they only did this with those older shells. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted October 10, 2014 Share Posted October 10, 2014 (edited) Was your cart shell one of the older ones lacking the insert line reference? I got one like that as well as normal one. Apparently the internal retention points of the older shells were inadequate, so they glued them in. Pics coming on Sunday. My other cart was not like this. I'm sure they only did this with those older shells. The pcb has square cuts on the side, the cart case has round mounting poins. Hence it would not hold well. This is why they must have glued. In the future I would recommend using JLP cart shells as they are much nicer and hold the PCB very securely and don't smell like construction adhesive In eagle I used the drill tool to make rounded slots on the edge of the PCB when doing this. Edited October 10, 2014 by grips03 Quote Link to comment Share on other sites More sharing options...
+Darrin9999 Posted October 10, 2014 Share Posted October 10, 2014 Mine worked fine on a Radio Shack Tandyvision Quote Link to comment Share on other sites More sharing options...
retroillucid Posted October 10, 2014 Share Posted October 10, 2014 ....... I just need to figure out how not to die so much when getting the diamond. Don't stop walking, go and jump without stoping (Hope that make sense) Quote Link to comment Share on other sites More sharing options...
+5-11under Posted October 10, 2014 Share Posted October 10, 2014 Apparently about 20% of the Mattel shells are different than any of the ones I looked at. These 20% lack the two main side holders for a standard width PCB. Instead, they rely on the screw holes for holding the PCB in place. My PCB doesn't surround the screw holes, and relied on the side holders. Open a few shells and you'll see what is happening. The next revision of the PCB will either be extended vertically to use the screw holes for support, or extended horizontally enough to use all four side holders. I was hoping CollectorVision would be able to save these 20% of the shells for the next revision of the PCB, but I guess that wasn't able to happen. 1 Quote Link to comment Share on other sites More sharing options...
+grips03 Posted October 10, 2014 Share Posted October 10, 2014 (edited) Apparently about 20% of the Mattel shells are different than any of the ones I looked at. These 20% lack the two main side holders for a standard width PCB. Instead, they rely on the screw holes for holding the PCB in place. My PCB doesn't surround the screw holes, and relied on the side holders. Open a few shells and you'll see what is happening. The next revision of the PCB will either be extended vertically to use the screw holes for support, or extended horizontally enough to use all four side holders. I was hoping CollectorVision would be able to save these 20% of the shells for the next revision of the PCB, but I guess that wasn't able to happen. I see what you mean. On my Astrosmash cart shell it has the square / rectangle pegs your pcb would use. The Sydney cart shell lacks these, hence the glue. I wish a less smelly glue was used. If sticking with the recycled shells, an extended pcb will certainly help as this is what Mattel did. This might mess up your programming jig, but perhaps there is a deeper connector that can be used, or switch to a finer pitch card edge that fits between the new screw hole positions. Edited October 10, 2014 by grips03 1 Quote Link to comment Share on other sites More sharing options...
Demo-Zee Posted October 10, 2014 Share Posted October 10, 2014 Spoke to Toby and sending the cart back for a replacement today. Kudos to them for being really good, communicating and responding quickly. 2 Quote Link to comment Share on other sites More sharing options...
+thegoldenband Posted October 10, 2014 Share Posted October 10, 2014 Pressing one of the keypad buttons (2?) makes you duck, I think. In fact, pressing keypad buttons does odd things, it seems. Haven't read any docs or looked at the overlays yet. If you press certain buttons at the same time -- 5 and 8, maybe? -- Sydney does a bizarre little jog in place, like a cartoon character revving up their feet before running. And yeah, I can't get the diamond. It's great feat just to get to the top of the skull. Is that the small-then-big jump? I think it's a really tight timing thing... like you have to be on just the right pixel and hit the buttons with just the right timing to pull it off. It took me quite a few tries too, though I ultimately got a bit of a feel for it. After playing for a bit, I noticed that the manual drops a big hint about things to discover (don't recall the exact language). Perhaps there's some hidden content in the game? Easter eggs, new wrinkles in later levels, difficulty settings, that sort of thing? I impishly tried inputting 768737 at the title screen, but the first number just triggers the game... Quote Link to comment Share on other sites More sharing options...
+grips03 Posted October 11, 2014 Share Posted October 11, 2014 for those who carts don't work, try adjusting how much the cart sits inside the Intv. I've noticed if I slide the cart out slightly on one side it works. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted October 11, 2014 Share Posted October 11, 2014 39,100 so far. Fun little game. 1 Quote Link to comment Share on other sites More sharing options...
retroillucid Posted October 11, 2014 Share Posted October 11, 2014 39,100 so far. Fun little game. I'm happy to hear you're having fun with the game Quote Link to comment Share on other sites More sharing options...
+grips03 Posted October 11, 2014 Share Posted October 11, 2014 (edited) I'm happy to hear you're having fun with the game Two bugs so far. 1) Top left and right action button do nothing. 2) When hero dies due to touching something he is suppose to jump or dodge (bat) , it does not reset the timer at the top of the screen. However it does make the hero repeat the screens in the section he is playing, i.e. grass, cave, etc. This means the player will most likely run out of time before he completes that section, therefore dying again. Running out of time does restart the timer, hence one is able to complete the section. High score is now: 59,200 Edited October 11, 2014 by grips03 Quote Link to comment Share on other sites More sharing options...
wolfy62 Posted October 12, 2014 Share Posted October 12, 2014 Thanks for the bug info, but mostly.......great score!!! Quote Link to comment Share on other sites More sharing options...
+grips03 Posted October 12, 2014 Share Posted October 12, 2014 (edited) New high score 63,900. The timer goes so fast I'm not sure I'll be able to get much higher than this. What are others getting? I can make it pretty far in level 4, but I always die, due to lack of time. edit: I still am about 1 second too slow. I get to screen 5 in grass section on level 4 and then an inch from the end I die. Jumping the bird/bat helps, but still not sure I'll get to the end of level 4. Edited October 12, 2014 by grips03 1 Quote Link to comment Share on other sites More sharing options...
Eric7100 Posted October 12, 2014 Share Posted October 12, 2014 Guess what just arrived... two copies of Smurf Rescue... I mean... Sydney Hunter! Quote Link to comment Share on other sites More sharing options...
+save2600 Posted October 12, 2014 Share Posted October 12, 2014 Guess what just arrived... two copies of Smurf Rescue... I mean... Sydney Hunter! Just arrived on Sunday? Have to admit... SH looks a hell of a lot more interesting than Smurf Rescue. I know the gameplay is similar, but still. And it's buggy per Grips' post above? Top two side buttons aren't used? Weird. Quote Link to comment Share on other sites More sharing options...
atari5200dude82 Posted October 12, 2014 Share Posted October 12, 2014 (edited) I got mine Yesterday and thanks. I played it 4 times, Awesome game. works well. Thanks to all who were involved. Better than the little blue guy> Edited October 12, 2014 by atari5200dude82 Quote Link to comment Share on other sites More sharing options...
mylok Posted October 12, 2014 Share Posted October 12, 2014 Received my copies a few days ago. Nice release. Fun little game that reminds me of some other game from back in the day. Can't remember the name... Thanks to everyone who helped make this game. Quote Link to comment Share on other sites More sharing options...
Eric7100 Posted October 13, 2014 Share Posted October 13, 2014 Just arrived on Sunday? It arrived on Saturday, but I found it on Sunday. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted October 13, 2014 Share Posted October 13, 2014 Can you guys post high scores? Anyone getting past level 4? Quote Link to comment Share on other sites More sharing options...
JasonlikesINTV Posted October 13, 2014 Share Posted October 13, 2014 Tested both of mine on standard Intellivision and they worked fine. I did find a Sydney Hunter cart variant, though Pics coming Sunday Was your cart shell one of the older ones lacking the insert line reference? I got one like that as well as normal one. Apparently the internal retention points of the older shells were inadequate, so they glued them in. Pics coming on Sunday. My other cart was not like this. I'm sure they only did this with those older shells. Here's the 'variant' I spoke of. The older shells without the insert line are a little rarer, so it's fun to see homebrews make it into them once in a while. I never realized that the guts were much different, but I suppose Harvey's boards are a bit unique in that they sort of butt up against the screw holes instead of fitting around them. You can see the glue in the pic. 2 Quote Link to comment Share on other sites More sharing options...
+Rev Posted October 13, 2014 Author Share Posted October 13, 2014 There is a handful of mouse trap cbs like that. Totally random. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted October 13, 2014 Share Posted October 13, 2014 Here's the 'variant' I spoke of. The older shells without the insert line are a little rarer, so it's fun to see homebrews make it into them once in a while. I never realized that the guts were much different, but I suppose Harvey's boards are a bit unique in that they sort of butt up against the screw holes instead of fitting around them. You can see the glue in the pic. Cool! now I'll not have to disassemble my Space Raid cartridge just to see how it looks Quote Link to comment Share on other sites More sharing options...
mammothservices Posted October 13, 2014 Share Posted October 13, 2014 1 copy Coleco style...I'll send payment today. Thanks! Quote Link to comment Share on other sites More sharing options...
scalpel Posted October 13, 2014 Share Posted October 13, 2014 Can you guys post high scores? Anyone getting past level 4? I played first time today 10 minutes, just close to finish the level 2 only... but I will continue soon Quote Link to comment Share on other sites More sharing options...
