anyone know where i can find ss and ds 5.25 inch alignment disks?
Once again, not at all. Devices like Kryoflux that work at the flux transition level can only process the digital characteristics of the signal, not the amplitude of the signal. Let alone there is no way that you could write back the signal that is not exactly track aligned. See Bob's description above about the alignment disk signal:
You need a very special mechanism to create that kind of disk.
