Creating 7800basic compatible maps with the Tiled app
I thought I'd review the steps on how to create a tiled background image for use with 7800basic, specifically for a map that will work with the 160A display mode along with 'set doublewide on' in your code. It works great and is a big time saver.
Before you start you'll of course need all of your graphics images completed. If you make any changes to your tileset graphics in the future, the changes will automatically be reflected in the map. Tiled does not create an image file, it creates an XML file that maps out and links to the different graphics images that you have. If you dramatically change your graphics images you will have to update your map file (or files).
Please Note (from post #5, RevEng):
The tutorial here assumes 160A mode (as stated) as well as the "set doublewide on" setting. Normally the width of one character in 160A mode is 4 pixels wide, but adding "doublewide" changes that to 8 pixels wide. This is why I used "8" for the "tile width" in Tiled.
If you wanted to adjust this tutorial for another mode, you can just lookup the width of one character in that mode in the table I linked to, and adjust for "set doublewide on" if you use it. That will be your value for "tile width". The "tile height" will be your zone height, and you can adjust the map size as you prefer.
First, download the Tiled app.
Once you've installed it, select File | New Map.
Make sure you select the correct options for your new map. Select an orthogonal orientation, XML format, 20x12 map size, and 8x16 tile size.
Now your ready to load up your tileset graphics. You can load multiple sets.
Click on browse to select your tileset. Make sure you set your options as seen in the screenshot.
Your first tileset is now loaded. I generally increase the size to 400% to make it easier to see.
You can now left click on a tile to use on the map, or hold down the CTRL button and select multiple tiles at a time.
You can now draw on the map screen. If you hold the left button mouse down you can drag the background tile to fill the map screen.
You can load multiple tilesets, each one will get their own tab. I generally increase the map size to 200% to make it easier to see.
Once you're happy with your map design you can save it as a tmx file and use it in your 7800basic program.
  • Like 5
Excellent info here! I just have a small point to add.
The tutorial here assumes 160A mode (as stated) as well as the "set doublewide on" setting. Normally the width of one character in 160A mode is 4 pixels wide, but adding "doublewide" changes that to 8 pixels wide. This is why Atarius Maximus used "8" for the "tile width" in Tiled.
Thanks for the clarification, RevEng. I updated the first post with this info.
Sure, that's fine. You can also add the graphics tutorial if you like.
The first draft of both pages are done:
randomterrain.com/7800basic-creating-maps.html
randomterrain.com/7800basic-graphics.html
Links to those pages have been added here:
randomterrain.com/atari-2600-memories.html#7800basic
  • 4 years later...
Yeah, the article you linked to specifies the way to do it. You can check any point, or set of points, on the sprite to see if they're over a particular tile-type.
Cool thanks. Another question does 7800Basic allow for nested GOSUBs? ie:
main_loop
  gosub drawplayer
  goto main_loop
drawplayer
 if playerdead then gosub deadplayer
 return
deadplayer
  lives=lives-1
  return
  • 2 years later...
Yes, the general procedure will be the same but you may need to make a few modifications based on if you use 320A or 320B as RevEng mentions above.  The original example assumes 160A with double-wide turned on to get 8 pixels per tile.
320A would have 8 pixel tiles without double-wide, or 16 pixel tiles with it.
320B would have 4 pixel tiles without double-wide, or 8 pixel tiles with it.
I think 320C would be the same as A, and 320D the same as B but I haven't looked at either very closely.
