artrag Posted October 14, 2014 Share Posted October 14, 2014 (edited) I've a small update to the stardust project (if we can call in this way). Now the image has resolution 84x48 and pressing right/left you can scroll the screen allowing a limited sort of "panning" effect of the tunnel. This is done by updating the sole PNT (768 bytes) having, pre-loaded in advance the whole VRAM with 84x48/2 = 2016 bytes per frame (corresponding to 252 tiles per frame). The rom (almost empty for now) has been tested and will work with bluemsx, meisei and openmsx (this latter needs you select as mapper plain 64K rom) stardust64.rom I was unable to attach an AVI file to this post, so for now the only way to see how it looks like is to run the rom in an emulator, sorry. [edit] Here the (crappy) video on youtube http://youtu.be/FuOT49ONNk0 Edited October 17, 2014 by artrag 3 Quote Link to comment Share on other sites More sharing options...
Elia Spallanzani fdt Posted November 11, 2022 Share Posted November 11, 2022 4 Quote Link to comment Share on other sites More sharing options...
pixelpedant Posted November 11, 2022 Share Posted November 11, 2022 Wow. Nice! Still, I think Multicolor's biggest threat on the TI-99 is just that everything it can do, bitmap mode can do better. Which is to say, behave like a true bitmap mode, but at higher resolution (64x192 "fat pixels", instead of 64x48). But this is a beautiful design, to show off a low res look with a palette very similar to that of the TMS9918. Quote Link to comment Share on other sites More sharing options...
SteveB Posted November 11, 2022 Share Posted November 11, 2022 Is there a way of using this mode from XB? Some library to load like XB256? Quote Link to comment Share on other sites More sharing options...
R.Cade Posted November 11, 2022 Share Posted November 11, 2022 On 8/6/2014 at 2:42 AM, TheMole said: Well, on the MSX you have Insect's Planet... Actually, Insects's Planet. That's hard to say out loud... Quote Link to comment Share on other sites More sharing options...
pixelpedant Posted November 12, 2022 Share Posted November 12, 2022 18 hours ago, SteveB said: Is there a way of using this mode from XB? Some library to load like XB256? Well, no library of relevant subprograms as far as I know, in the way that TML furnishes XB with bitmap mode tools, and T40XB furnishes XB with text mode tools. For what it's worth, UCSD Pascal can switch to multicolor mode on command (with use of the included SET_SCREEN routine). But once invoked, populating the screen image and pattern table as desired is left as an exercise for the user. Nonetheless, VDP reads and writes are supported by TI's UCSD Pascal implementation (i.e., without your own assembly subroutine), so this is doable, in principle, it seems to me. Though pointless for a definition of "pointless" that exceeds even conventional norms of our community. 1 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted November 12, 2022 Share Posted November 12, 2022 I would love to see multicolor mode used in more TI homebrews. 1 Quote Link to comment Share on other sites More sharing options...
pixelpedant Posted November 12, 2022 Share Posted November 12, 2022 Ever since I saw Spade Carrier for MSX1, I have been with you on that. 4 Quote Link to comment Share on other sites More sharing options...
SteveB Posted November 13, 2022 Share Posted November 13, 2022 How could such a library work? I see two options: 1. Writing a library with the routines MCINIT, PUTPIXEL and GETPIXEL (, ...) 2. Writing a more complex library with a CPU-RAM buffer While the first would be easier, it would not offer much advantages over the more powerful full bitmap mode. In order to have a fast drawing and blitting of objects I would use a linear CPU-RAM buffer 48x64 bytes (3kb) and do the tile-magic when pushing the buffer to VDP RAM. You may now paint a scene back-to-front to enable some pseudo 3D (like Wolfenstein3D did, objects were 2d in a 3d room, like paperboard figures). Your thoughts? 2 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted November 13, 2022 Share Posted November 13, 2022 (edited) My thoughts is that multicolor made more sense in the TMS 9918, which didn't have the full-screen bitmap mode, than it did in the TMS 9918A, where the bitmap mode was supported. The did of course not want to remove it again then, or it would not have been backwards compatible. Like pixelpedant wrote above, you can "officially" enter multicolor mode with Pascal, but that's about it. Unofficially you can also use bitmap mode, but then you have to play some tricks with the system. Edited November 13, 2022 by apersson850 2 Quote Link to comment Share on other sites More sharing options...
pixelpedant Posted November 14, 2022 Share Posted November 14, 2022 It's also worth keeping in mind that the 9918/9918A was designed to work with 16KB of RAM or less. So while video modes which contribute to and expand your options in 4KB and 8KB configurations might seem pointless in hindsight, in principle this was a consideration, even as of the 9918A. 3 Quote Link to comment Share on other sites More sharing options...
SteveB Posted November 17, 2022 Share Posted November 17, 2022 I don't really get it ... Multicolor mode This mode is selected by setting bit 4 of VDP register 1 as 1. Bit 3 must be 0, as well as bit 7 of register 0. VR0: 0 VR1: 0 1 In this mode, the screen is divided into 48 rows of 64 boxes. Each box is 4x4 pixel and can be independently assigned a color. The screen image table is still >300 bytes long, but each byte now represent a "character" made of 4 boxes. The boxes are arranged as: 0 1 2 3 The color of the boxes are defined in the character pattern table (!). Each entry in the table is 8 bytes long but only 2 bytes are used to define the colors of the 4 boxes that make up a character: >01 >23. To avoid wasting 6 bytes in each entries, the characters on 4 consecutive rows use the same entry, with an offset of 2 bytes: characters on row 0, 4, 8, 12, 16 and 20 use bytes 0 and 1, characters on row 1, 5, 9, 13, 17 and 21 used bytes 2 and 3, characters on row 2, 6, 10, 14, 18 and 22 used bytes 4 and 5, characters on rows 3, 7, 11, 15, 19 and 23 use bytes 6 and 7. This reduces the size of this table to 1536 bytes (24 rows x 32 columns x 8 bytes). With an image table of >300 ... how do I fill the screen with 768 different characters ... when each character is between 0 and 255 ... what do I do on position >100 ? Start with >00 and the magic happens in the hardware to recognize this as character >100 in the pattern table? Quote Link to comment Share on other sites More sharing options...
+Torrax Posted November 17, 2022 Share Posted November 17, 2022 You are on the right track. Just setup the Screen Image Table (SIT) with the chars 0 to 255 repeated three times. 1 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 18, 2022 Share Posted November 18, 2022 2 hours ago, Torrax said: You are on the right track. Just setup the Screen Image Table (SIT) with the chars 0 to 255 repeated three times. Though there are certainly different ways of managing this, what you posted is what the E/A manual suggests for bitmap mode. For multicolor mode, it is 4 times 0 – >1F, 4 times >20 – >3F, 4 times >40 – >5F, ..., 4 times >A0 – >BF. This puts each “character” code in a 1-character-wide-by-4-character high arrangement in the 32-character-x-24-row graphics mode or 2x8 multicolor “pixels” (MPs) in the 64-MP-x-48-row multicolor mode. Each 8-byte entry in the pattern table manages the colors of those 16 MPs (1 nybble each). ...lee 2 Quote Link to comment Share on other sites More sharing options...
+Torrax Posted November 18, 2022 Share Posted November 18, 2022 Oh fudge... Me bad!! Pulled out my VDP Programmers Guide and TMS 9118/9128/9129 Data Manual to refresh my memory. Best site to check out is: https://www.unige.ch/medecine/nouspikel/ti99/tms9918a.htm And read the Multi-Color mode section. Way much better to understand than the relevant sections in the two manuals above. 1 Quote Link to comment Share on other sites More sharing options...
speccery Posted November 18, 2022 Share Posted November 18, 2022 Motivated by this discussion, I created a really simple and stupid assembler program to test multicolour mode. Attached assembler source and cart image MULTICOLOR.bin (tested with js99er only as I'm Mac user). While working at it, I noticed that in the table on TI tech pages there is a typo: the location of text mode and multicolour bits in VR1 is swapped. The register layout is like this: * VR1: 7 6 5 4 3 2 1 0 * VR1: 16K Blank Int Text Multi 0 Size4 Mag 2x Bit 7 is MSB, bit 0 LSB. Thus the sane bit order, not the TI one. Below is a screenshot. It just draws some vertical lines, which rotate from one frame to the next and then it draws a "sprite" i.e. just a multicolour bitmap on top. The code is not optimised at all. After working on the ARM chips, the TMS9900 code really goes on pedestrian speeds The code contains a routine I wrote MULTICOLADDR which calculates from X and Y the address of a pair of pixels in the multicolour mode memory layout. (If you wonder inconsistent spelling, the word color comes out of my spell checker as colour). If you want to mock around with the code, use XDT99 to assemble it. I unzip the result to get multicolor.bin, the cartridge image from the zipped rpk image. * Assemble with: * xas99.py -L multicolor.lst -R -c multicolor.asm * unzip -o multicolor.rpk MULTICOLOR.bin multicolor.asm 4 2 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted November 18, 2022 Author Share Posted November 18, 2022 56 minutes ago, speccery said: I created a really simple and stupid assembler program to test multicolour mode You should try to double-buffer it to remove the flicker, by writing alternate frames to different VDP addresses (>0800 and >1000), and switching to the new buffer after waiting for vsync. 3 Quote Link to comment Share on other sites More sharing options...
speccery Posted November 18, 2022 Share Posted November 18, 2022 20 minutes ago, Asmusr said: You should try to double-buffer it to remove the flicker, by writing alternate frames to different VDP addresses (>0800 and >1000), and switching to the new buffer after waiting for vsync. Yes I will do that. This was literally a simple quick and dirty test only. I think the rendering should be done to a system RAM buffer, and then have an optimized routine to push the data to the VDP to avoid the constant need to set the VDP write address as I do now. The RAM buffer would also be needed to draw more involved graphics, since each byte has two pixels and therefore read operations are needed on blit edges. Anyway this is a fun little exercise. 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted November 18, 2022 Author Share Posted November 18, 2022 51 minutes ago, speccery said: Yes I will do that. This was literally a simple quick and dirty test only. I think the rendering should be done to a system RAM buffer, and then have an optimized routine to push the data to the VDP to avoid the constant need to set the VDP write address as I do now. The RAM buffer would also be needed to draw more involved graphics, since each byte has two pixels and therefore read operations are needed on blit edges. Anyway this is a fun little exercise. I agree about the RAM buffer. The question is if you should store 1 or 2 pixels per byte in the buffer? With 2 pixels per byte you could transfer the buffer to VDP RAM almost one byte (2 pixels) per instruction (e.g. movb *r0+,*r15), by having one register pointing to the first row of the RAM buffer, another pointing to the next row and so on up to 8 registers. Only after transferring 8 rows would you have to update the registers. This way you should be able to transfer at least 30 frames per second, but that's just the transfer time and doesn't consider the time to update the buffer and run the game in general. On the other hand, if you store 1 byte per pixel, you would first have to combine 2 pixels into a byte, which would take 3 instructions (movb, sla, socb) before sending the byte to the VDP, so approximately 4 times slower, maybe 10 FPS. But if you want to be able to draw objects to the buffer at any of the 64 horizontal positions, and in particular if you want to scroll the view by 1 horizontal pixel instead of 2, it would be a lot easier to handle if you stored one pixel per byte. I would like to see a game that scrolled a multicolor background in 8 directions (including vertical). Multicolor mode permits the use of hardware sprites, but it would also be cool to see 'sprites' drawn in multicolor mode. 3 Quote Link to comment Share on other sites More sharing options...
SteveB Posted November 19, 2022 Share Posted November 19, 2022 (edited) I've been thinking what functions I would need / expect from a Multicolor Mode library: Minimal: MCINIT - Switch to Multicolor Mode and create the buffer PUTPIXEL(row,col,color) - Set Pixel in (row,col) to color GETPIXEL(row,col,color) - Get the color of Pixel in (row,col) MCSYNC - Writes buffer to VRAM (waiting for vsynch?) MCDONE - Switch video back to standard mode Lines: HLINE(row,col,color,len) - Draw a horizontal line VLINE((row,col,color,len) - Draw a vertical line LINE(row1,col1,row2,row3,color) - Draw a line between to points SQUARE(row1,col1,row2,row3,color) - Draw a square BLANK(color) - fills the whole screen in one color Shapes: BLIT(row,col,address) - Draws a pattern found at address to the given point. Pattern format: Byte 1: Pattern rows Byte 2: Pattern columns Byte 3 - (Byte1 x Byte2 +2): Pixel-Color inkl. a transparent color Open Questions Which color numbers to use (0 = transparent to >F = white? Instead of BASIC 1 - 16) Would it be more practical to have an index instead of an address for the pattern to have one OBJ-file with the pattern-definitions? Scrolling functions? Is the redundancy LINE vs HLINE/VLINE and CLEAR vs. SQUARE a significant speedup worth the effort? As with Rasmus' posting .. one or two pixel per byte in the buffer .. what's best with this kind of usage? Defining a "Window" for drawing? Four additional compares, but less hassle in the main program. (added) It is hard to judge if this is practical and complete without trying... what are your thoughts? Edited November 20, 2022 by SteveB added Question for drawing-window. 4 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 19, 2022 Share Posted November 19, 2022 1 hour ago, SteveB said: Which color numbers to use (0 = transparent to >F = white? Instead of BASIC 1 - 16)? The VDP wants 0 – >F. Basic translates to/from zero basis. ...lee 1 Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted November 20, 2022 Share Posted November 20, 2022 Perhaps it’s time for a multicolor-mode game development contest? 😀 2 Quote Link to comment Share on other sites More sharing options...
SteveB Posted November 20, 2022 Share Posted November 20, 2022 Please make this two contests ... one in assembler and one in XB or other language ... And for the latter it will be a long way to a library. At least if I'll be doing it without any previous 9900 assembler experience... 2 Quote Link to comment Share on other sites More sharing options...
speccery Posted November 20, 2022 Share Posted November 20, 2022 Here's another version about my silly multicolour test program (only tested on js99er - the single stepping disassembler behaves weirdly when debugging). This second version has two phases: - First phase is the same slow color bar thing as the earlier one, but now with double buffering in VDP memory and code to wait for VSYNC as per guidance from @Asmusr - Second phase is in my opinion more interesting. The code has what I call a playfield, which is 128*64 pixel bitmap on memory. From this playfield a give 64*48 pixel view is rendered to the display. The playfield window is "bounced" around and at each vertical bounce the horizontal direction is updated. Best to take a look to understand. The code does not yet know how to update the playfield from an odd pixel location, so horizontal scrolling bouncing is in steps of 2 pixels still. This code is now optimised (see below), although still running from cartridge memory. The playfield format is a linear frame buffer, with two pixels per byte, thus 4096 bytes for the whole playfield, out of which 1536 are copied to screen. @Asmusr was wondering about the best pixel format, I think the packed one is probably good, since it allows 16-bit loads from the playfield, which might be useful when adding pixel level horizontial positioning. Here is the inner loop: Spoiler SCANLINELP: LI R10,32 ; Now blast 8 lines of graphics on screen ! MOVB *R2+,*R0 MOVB *R3+,*R0 MOVB *R4+,*R0 MOVB *R5+,*R0 MOVB *R6+,*R0 MOVB *R7+,*R0 MOVB *R8+,*R0 MOVB *R9+,*R0 DEC R10 JNE -! ; Now adjust the pointers for the next line, needed if pitch != 32 MOV R1,R10 ; R10 = pitch SLA R10,3 ; R10 = pitch*8 (we just did 8 lines) AI R10,-32 ; R10 = pitch - 32 A R10,R2 A R10,R3 A R10,R4 A R10,R5 A R10,R6 A R10,R7 A R10,R8 A R10,R9 AI R11,-8 JNE SCANLINELP MULTICOLOR.bin multicolor.asm 7 Quote Link to comment Share on other sites More sharing options...
Elia Spallanzani fdt Posted November 20, 2022 Share Posted November 20, 2022 4 Quote Link to comment Share on other sites More sharing options...
