Asmusr Posted January 15, 2023 Author Share Posted January 15, 2023 3 hours ago, arcadeshopper said: on the NABU this is split screen half bitmap and half multicolor Which part is multicolor? 1 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5190626 Share on other sites More sharing options...
+Lee Stewart Posted January 15, 2023 Share Posted January 15, 2023 10 hours ago, arcadeshopper said: on the NABU this is split screen half bitmap and half multicolor <snip> That looks like it is all Bitmap to me. Multicolor pixels are equivalent to 4x4 Bitmap pixels. The entire screen is displaying Bitmap pixels. ...lee Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5190741 Share on other sites More sharing options...
SteveB Posted January 15, 2023 Share Posted January 15, 2023 As my MultiColor library is now about 70% complete I wanted to share a short demo with you. Though I am working on a write-through mode, the library actually expects you to paint your frame in a CPU memory buffer and the push it to VRAM when ready. You helped me very much to speed up that sync. This demo shows some line-drawing and the use of sprites in MultiColor Mode in XB and normal Speed: This is the code in SXB: Spoiler CALL LOAD("DSK4.MCOLOR.OBJ") CALL SCREEN(2) CALL MCOLOR(4,0) CALL CHAR(40,"0001010100030509090103030301010380C0D0D098D0E8D8C0C0E0E060404060") CALL SPRITE(#1,40,16,50,50,5,10) FOR I=1 TO 20 CALL MCCLR(4) CALL HLINE(24-i,32-i,11,i*2) CALL VLINE(25-i,32-i,11,i*2) CALL HLINE(24+i,33-i,11,i*2) CALL VLINE(24-i,32+i,11,i*2) CALL LINE(8,30-i,32,30+i,9) CALL LINE(8,1,i,64-i,15) CALL MCSYNC NEXT I REPEAT CALL KEY(3,K,S) UNTIL s<>0 END ... and this in Standard XB Spoiler 100 CALL LOAD("DSK4.MCOLOR.OBJ") 110 CALL SCREEN(2) 120 CALL LINK("MCOLOR",4,0) 130 call char(40,"0001010100030509090103030301010380C0D0D098D0E8D8C0C0E0E060404060") 140 call sprite(#1,40,16,50,50,5,10) 150 FOR I=1 TO 20 160 CALL LINK("MCCLR",4) 170 CALL LINK("HLINE",24-i,32-i,11,i*2) 180 CALL LINK("VLINE",25-i,32-i,11,i*2) 190 CALL LINK("HLINE",24+i,33-i,11,i*2) 200 CALL LINK("VLINE",24-i,32+i,11,i*2) 210 CALL LINK("LINE",8,30-i,32,30+i,9) 220 CALL LINK("LINE",8,1,i,64-i,15) 230 CALL LINK("MCSYNC") 240 NEXT I 250 CALL KEY(3,K,S) 260 IF NOT (s<>0) THEN 250 270 END Much of the time is spent in that CALL from XB, so once finished, I need to create a version to use with Harry's Compiler. 10 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5190836 Share on other sites More sharing options...
GDMike Posted January 16, 2023 Share Posted January 16, 2023 5 hours ago, SteveB said: As my MultiColor library is now about 70% complete I wanted to share a short demo with you. Though I am working on a write-through mode, the library actually expects you to paint your frame in a CPU memory buffer and the push it to VRAM when ready. You helped me very much to speed up that sync. This demo shows some line-drawing and the use of sprites in MultiColor Mode in XB and normal Speed: This is the code in SXB: Reveal hidden contents CALL LOAD("DSK4.MCOLOR.OBJ") CALL SCREEN(2) CALL MCOLOR(4,0) CALL CHAR(40,"0001010100030509090103030301010380C0D0D098D0E8D8C0C0E0E060404060") CALL SPRITE(#1,40,16,50,50,5,10) FOR I=1 TO 20 CALL MCCLR(4) CALL HLINE(24-i,32-i,11,i*2) CALL VLINE(25-i,32-i,11,i*2) CALL HLINE(24+i,33-i,11,i*2) CALL VLINE(24-i,32+i,11,i*2) CALL LINE(8,30-i,32,30+i,9) CALL LINE(8,1,i,64-i,15) CALL MCSYNC NEXT I REPEAT CALL KEY(3,K,S) UNTIL s<>0 END ... and this in Standard XB Reveal hidden contents 100 CALL LOAD("DSK4.MCOLOR.OBJ") 110 CALL SCREEN(2) 120 CALL LINK("MCOLOR",4,0) 130 call char(40,"0001010100030509090103030301010380C0D0D098D0E8D8C0C0E0E060404060") 140 call sprite(#1,40,16,50,50,5,10) 150 FOR I=1 TO 20 160 CALL LINK("MCCLR",4) 170 CALL LINK("HLINE",24-i,32-i,11,i*2) 180 CALL LINK("VLINE",25-i,32-i,11,i*2) 190 CALL LINK("HLINE",24+i,33-i,11,i*2) 200 CALL LINK("VLINE",24-i,32+i,11,i*2) 210 CALL LINK("LINE",8,30-i,32,30+i,9) 220 CALL LINK("LINE",8,1,i,64-i,15) 230 CALL LINK("MCSYNC") 240 NEXT I 250 CALL KEY(3,K,S) 260 IF NOT (s<>0) THEN 250 270 END Much of the time is spent in that CALL from XB, so once finished, I need to create a version to use with Harry's Compiler. Does rxb have bitmap or dot drawing? Might be worth investigating Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5190990 Share on other sites More sharing options...
senior_falcon Posted January 16, 2023 Share Posted January 16, 2023 2 hours ago, GDMike said: Does rxb have bitmap or dot drawing? Might be worth investigating No, but XB 2.9 G.E.M. does. Option 7 for The Missing Link. But can it be compiled? Of course. 2 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5191033 Share on other sites More sharing options...
RXB Posted January 16, 2023 Share Posted January 16, 2023 Trying to run XB with Bit Map mode or Multicolor mode almost requires being compiled as not much XB code is left as 80% of the work is Assembly. This is why you see more CALL LINK routines then you see XB code. (The amount of time the CPU is running Assembly not GPL/XB code) It is kind of odd as might as well go full assembly instead of XB as it is not really XB anymore. 1 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5191123 Share on other sites More sharing options...
SteveB Posted January 16, 2023 Share Posted January 16, 2023 On 1/15/2023 at 7:50 PM, SteveB said: Though I am working on a write-through mode, the library actually expects you to paint your frame in a CPU memory buffer and the push it to VRAM when ready. I spent an evening implementing the "write-through" ... and it really sucks. Provided someone would use the library, would you prefer a speed-up in all drawing or the ability to draw directly on the screen? Trick question ... you are all speed-buffs. Instead of painting pixel by pixel, calculating each pixel buffer-address anew (and updating half a byte in the VDP RAM), I might just INC to go down or AI 64 to go right ... the columns based buffer is so much easer to use than the VDP RAM layout. I'll sleep over it, but I guess I will dump the write-through idea in favor of a better frame-rate and update the buffer outside of SETPIX() directly. Object now or ... 3 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5191448 Share on other sites More sharing options...
+arcadeshopper Posted January 17, 2023 Share Posted January 17, 2023 On 1/4/2023 at 12:21 AM, SteveB said: My calculation based on the data sheet is just as wrong ... but together we will get to the ancient core .. From the author: "it actually uses TWO graphics modes, and changes it mid frame. it is a very complicated bit of software, compared to other games. halfway down the screen, we flip the graphics mode. this allows use to use a simpler graphics 1 mode for the betting table. Roulette was my first game. I wrote it with the guidance and help of Ken Shimizu" Unfortunately the source is lost.. 3 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5191790 Share on other sites More sharing options...
Tursi Posted January 18, 2023 Share Posted January 18, 2023 15 hours ago, arcadeshopper said: From the author: "it actually uses TWO graphics modes, and changes it mid frame. it is a very complicated bit of software, compared to other games. halfway down the screen, we flip the graphics mode. this allows use to use a simpler graphics 1 mode for the betting table. Roulette was my first game. I wrote it with the guidance and help of Ken Shimizu" Unfortunately the source is lost.. Ah, graphics 1 is the normal 24x32 character graphics mode that we normally use on the TI - so he's probably using bitmap on the top and switching to graphics mode for the bottom. Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5192146 Share on other sites More sharing options...
sometimes99er Posted January 18, 2023 Share Posted January 18, 2023 50 minutes ago, Tursi said: Ah, graphics 1 is the normal 24x32 character graphics mode that we normally use on the TI - so he's probably using bitmap on the top and switching to graphics mode for the bottom. Yes, but then no multicolor mode, which this thread is all about. 😉 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5192155 Share on other sites More sharing options...
Asmusr Posted January 18, 2023 Author Share Posted January 18, 2023 You could get the same result, or better, from using bitmap mode on the whole screen. 1 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5192266 Share on other sites More sharing options...
+arcadeshopper Posted January 18, 2023 Share Posted January 18, 2023 16 minutes ago, Asmusr said: You could get the same result, or better, from using bitmap mode on the whole screen. here's the effect Capture 2023-01-18 at 07.44.24.835.mp4 1 1 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5192280 Share on other sites More sharing options...
HOME AUTOMATION Posted January 18, 2023 Share Posted January 18, 2023 That wheel spin action is well done! 2 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5192343 Share on other sites More sharing options...
GDMike Posted January 18, 2023 Share Posted January 18, 2023 1 hour ago, HOME AUTOMATION said: That wheel spin action is well done! My eyes are rolling 1 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5192386 Share on other sites More sharing options...
SteveB Posted January 22, 2023 Share Posted January 22, 2023 (edited) Another demo at actual XB speed of the multicolor library I am working on... Bisbee.AVI Imagine sitting in a train to Bisbee, AZ and look out of your window ... about one frame per second with clearing the entire screen, painting the sky and 10 shapes in each and every frame... CALL LOAD("DSK4.MCOLOR.OBJ") CALL SCREEN(2) CALL MCOLOR(10) DIM A(5),T(10),X(10),Y(10),D(10) // Shapes-Address A, Types, X/Y Pos, Delta movement CALL SHAPE(A(0),16,6,"00022000000001010000020000330011222CCCCCCCCCCCC1") CALL SHAPE2("0022222CC222222103300002200000B1000003330000000E") CALL SHAPE(A(1),12,5,"00333000010000000220001BCCCCCCCCCCCB0000C333333B0033C00000BB") CALL SHAPE(A(2),8,4,"0220000000CC00112222222B3330000B") CALL SHAPE(A(3),6,12,"00FF000FFFF00FF0F00F0FFF00FFFF0FFFFFFFFFFFFFFFF0FFFFF0FFFFFF0FFFFF000FF0") CALL SHAPE(A(4),6,5,"0BBB00BBBBB0BBBBB0BBBBB00BBB00") CALL SHAPE(A(5),4,20,"444A4AAA4AAAAAAAAAAAAAAA4AA44A4A44AA44AA444A444444444444444A44AA44AA4AAA4AAA4AAA") FOR I=0 TO 9 READ T(I),Y(I),X(I),D(I) NEXT I REPEAT CALL MCCLR(10) CALL SQUARE(0,0,8,63,4) FOR I=0 TO 9 CALL BLIT(A(T(I)),Y(I),X(I)) X(I)=X(I)-D(I) IF X(I)<-6 THEN X(I)=66 NEXT I CALL MCSYNC CALL KEY(3,K,S) UNTIL S=1 END DATA 4,2,55,0.2 DATA 3,1,62,0.5 DATA 3,2,24,0.5 DATA 5,7,40,0.6 DATA 2,7,30,0.7 DATA 2,8,5,0.6 DATA 1,13,60,0.8 DATA 1,11,17,0.7 DATA 0,24,20,1.8 DATA 0,28,50,2 PS: Which video format do I need to embed the video? Edited January 22, 2023 by SteveB 3 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5194544 Share on other sites More sharing options...
+OLD CS1 Posted January 22, 2023 Share Posted January 22, 2023 26 minutes ago, SteveB said: PS: Which video format do I need to embed the video? I find an MP4 encoded with h.264 and aac works. It is listed as one of the HTML5 native video/audio codecs. To encode in ffmpeg, I use -c:v libx264 -c:a aac -ac 2 -ar 44100 1 1 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5194558 Share on other sites More sharing options...
SteveB Posted January 23, 2023 Share Posted January 23, 2023 classic99.mp4 seems to work ... thank you! 2 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5194794 Share on other sites More sharing options...
+InsaneMultitasker Posted January 23, 2023 Share Posted January 23, 2023 I see this instead of the video... Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5194911 Share on other sites More sharing options...
ti99iuc Posted January 23, 2023 Share Posted January 23, 2023 (edited) @InsaneMultitasker Are you using Mozilla Firefox as browser? maybe this could help:https://support.mozilla.org/en-US/questions/1048378 I tried on Brave and Chrome and it works for me. Edited January 23, 2023 by ti99iuc 1 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5194929 Share on other sites More sharing options...
+OLD CS1 Posted January 23, 2023 Share Posted January 23, 2023 1 hour ago, InsaneMultitasker said: I see this instead of the video... Firefox does not like video without an audio track. His post works fine in Edge. I suspect it will work in other Chromium browsers, like Chrome and Opera. They seem a little more lax on things (including security.) 1 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5194947 Share on other sites More sharing options...
HOME AUTOMATION Posted January 23, 2023 Share Posted January 23, 2023 Plays fine for me, embedded in chrome.🎥 1 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5194950 Share on other sites More sharing options...
Elia Spallanzani fdt Posted January 23, 2023 Share Posted January 23, 2023 I see only gray and red halos that make you think of nightmares (brave browser). Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5194958 Share on other sites More sharing options...
+InsaneMultitasker Posted January 23, 2023 Share Posted January 23, 2023 50 minutes ago, OLD CS1 said: Firefox does not like video without an audio track. His post works fine in Edge. I suspect it will work in other Chromium browsers, like Chrome and Opera. They seem a little more lax on things (including security.) Roger that. I'll try Edge. Don't want to derail the thread any further, it's just that I can count on one, maybe two, hands how many times I've seen that error message here on AA during the past 10 years, and thought it might be a video issue. Thx. 1 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5194976 Share on other sites More sharing options...
SteveB Posted February 14, 2023 Share Posted February 14, 2023 After many hours of learning and coding I am happy to publish version 1.0 of my Multicolor Library. MColor_V1.0.zip Included in this package are four example programs and a 22 page manual, covering both TiCodEd SXB and standard XB. When using TiCodEd please copy the file Lib/MultiColor.xbpkg to the Lib directory of TiCodEd and select this package on the Project page. The mentioned "Lowercase LINK" and Cactus-Speedbutton will only be available in the upcomming TiCodEd release 2.5, where the package will also be included. I am working on the release and there are two features I am not yet happy with. Thanks to everyone who supported my project here in this thread and a special thank to Harry and Lee. I hope someone finds this usefull for a project in Multicolor Mode. Suggestions for enhancements are always welcome here. Quix.mp4 PS: I kept "Writethrough" direct drawing as the internal use PUTPIX covered all checks, which would have been implemented all over the place to avoid VRAM corruptions. This way you can safely draw outside of the window, it just gets ignored. 18 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5209164 Share on other sites More sharing options...
+Vorticon Posted February 15, 2023 Share Posted February 15, 2023 This is an awesome extension to sxb. Now to think of a good use for the multicolor mode... 1 Quote Link to comment https://forums.atariage.com/topic/228454-multicolor-mode-the-mode-nobody-wanted/page/9/#findComment-5209585 Share on other sites More sharing options...
