DocRotCod Posted August 7, 2014 Share Posted August 7, 2014 So I hooked up an extra XEGS from my garage today to test out. It has a strange issue I was hoping someone here could help with. When turning it on and starting Missile Command, the first time you play it, it goes at WARP speed - totally unplayable. After you 'die' the first time, it slows way down. None of my other XEGS units do this. I opened the unit and I don't believe it has ever been serviced or tampered with, and I do not see any evidence of broken traces, legs, etc. Any ideas what to look for are appreciated! Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 7, 2014 Share Posted August 7, 2014 Do you have SIO2PC, SIO2SD or otherwise have the means to be able to run downloaded programs or transfer stuff from that machine and upload here? Quote Link to comment Share on other sites More sharing options...
DocRotCod Posted August 7, 2014 Author Share Posted August 7, 2014 Yes I have all the means to do whatever needs to be done on this. Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 7, 2014 Share Posted August 7, 2014 COPYMC.BAS Here's a Basic program that will output the Missile Command ROM to a file on disk. If needed, edit line 30 to change the filename. It'll take a while to run, it uses Basic to write out the file (sleepy time here so I had to rush it). If you can upload the resulting MISCMD.DAT file (probably have to Zip it first or just rename file extension to BIN) we could check if your game Rom is OK. Quote Link to comment Share on other sites More sharing options...
DocRotCod Posted August 7, 2014 Author Share Posted August 7, 2014 Thanks for your help. I had a bit of trouble getting the file back out to the PC so I just made a bootable ATR in SDX format. I hope that works. Thank you for your efforts I really appreciate it. XEGSTEST.zip Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted August 7, 2014 Share Posted August 7, 2014 5.84 MB for an 8k rom is pretty drastic... Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 8, 2014 Share Posted August 8, 2014 (edited) That dump is no good - do you have a SpartaDos cartridge inserted or something? It has to be run with no cartridge present - it came up with mostly zeros and a bit of program code in the middle that looks like Dos stuff. Here's a DOS 2.5 image you can boot - if you can run against that then upload it again once the file has been written to it: Dos 2.5.atr Edited August 8, 2014 by Rybags Quote Link to comment Share on other sites More sharing options...
