Smokeless Joe Posted August 7, 2014 Share Posted August 7, 2014 (edited) I downloaded AspeQt for Mac OS from: http://frederik.hol.st/atari/8-bit/AspeQt4Mac/ It runs fine on the following systems: iMac, 2.7 GHz Intel Core i5, OS 10.9.4 MacBook, 2.2 GHz Intel Core 2 Duo, OS 10.7.5 but it does not run on: Mac mini, 1.66 Intel Core Duo, OS 10.6.8 On the Mac mini, the icon for AspeQt has a circle with a line through it, like this: If I try to run it I get the following message: This is very similar to trying to open a PowerPC program on an Intel Mac, only the error is a little different. Any ideas what's going on? My guess is that AspeQt requires some sort of 64-bit functionality, which the iMac and Macbook have, while the Mac mini is a strictly 32-bit system. Thanks, -Joe Edited August 7, 2014 by Smokeless Joe Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 7, 2014 Share Posted August 7, 2014 My guess is that AspeQt requires some sort of 64-bit functionality, which the iMac and Macbook have, while the Mac mini is a strictly 32-bit system. Correct. You'll need at least 64-bit userland to run these builds of Aspeqt, unless someone manages to compile 32-bit versions using a 32-bit build of QT. 1 Quote Link to comment Share on other sites More sharing options...
Smokeless Joe Posted August 7, 2014 Author Share Posted August 7, 2014 Well, shucks. On the plus side, the very same Mac mini running Windows XP seems to run AspeQt adequately. But I was really hoping to have a dedicated Mac-Atari setup. -Joe Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 7, 2014 Share Posted August 7, 2014 You could have a shot at running the Win32 version under WINE. I had no luck getting Aspeqt to talk to the FTDI driver this way, but your mileage may vary. Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted August 7, 2014 Share Posted August 7, 2014 You could have a shot at running the Win32 version under WINE. I had no luck getting Aspeqt to talk to the FTDI driver this way, but your mileage may vary. That's one of those "Maybe it will work, maybe it won't" type situations. Unlike flashjazzcat's situation, the Windows version of AspeQt seems to run BETTER under WINE for me than the native Mac version. So give it a try - what've you got to lose? Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 7, 2014 Share Posted August 7, 2014 I downloaded AspeQt for Mac OS from: http://frederik.hol.st/atari/8-bit/AspeQt4Mac/ It runs fine on the following systems: iMac, 2.7 GHz Intel Core i5, OS 10.9.4 MacBook, 2.2 GHz Intel Core 2 Duo, OS 10.7.5 but it does not run on: Mac mini, 1.66 Intel Core Duo, OS 10.6.8 On the Mac mini, the icon for AspeQt has a circle with a line through it, like this: icon.png If I try to run it I get the following message: error.png This is very similar to trying to open a PowerPC program on an Intel Mac, only the error is a little different. Any ideas what's going on? My guess is that AspeQt requires some sort of 64-bit functionality, which the iMac and Macbook have, while the Mac mini is a strictly 32-bit system. Thanks, -Joe Hi Joe, I asked Frederick if the binaries are 64 bit, I'll let you know when I get an answer so that there is no doubt about it. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted August 7, 2014 Share Posted August 7, 2014 File tool output on the download linked by the OP: Quote Link to comment Share on other sites More sharing options...
gozar Posted August 8, 2014 Share Posted August 8, 2014 Well, shucks. On the plus side, the very same Mac mini running Windows XP seems to run AspeQt adequately. But I was really hoping to have a dedicated Mac-Atari setup. -Joe I ran Ape under VirtualBox on OS X for a while until I got a hold of a cheap laptop running Windows XP. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted August 8, 2014 Share Posted August 8, 2014 File tool output on the download linked by the OP: So there we go.... Quote Link to comment Share on other sites More sharing options...
