Asmusr Posted February 16, 2016 Author Share Posted February 16, 2016 yes use mess, classic99 or js99er Greg That doesn't really answer the question. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 16, 2016 Share Posted February 16, 2016 That doesn't really answer the question. The same answer goes for using any new hardware based program on v9t9 or pc99 as well Greg Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 16, 2016 Author Share Posted February 16, 2016 The same answer goes for using any new hardware based program on v9t9 or pc99 as well Greg Yes but TI-99/SIM seems to be the only emulator capable of running on a Raspberry Pi. Actually that's not true because I was running advmess on my Raspberry PI a few years ago and even though it's not as good as MESS today it might be able to run more programs than TI-99/SIM (but it would not have support for 512K carts). Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 16, 2016 Share Posted February 16, 2016 Yes but TI-99/SIM seems to be the only emulator capable of running on a Raspberry Pi. Actually that's not true because I was running advmess on my Raspberry PI a few years ago and even though it's not as good as MESS today it might be able to run more programs than TI-99/SIM (but it would not have support for 512K carts). Agreed, so perhaps a "fix ti/sim" topic is in order? it has source code available Greg Quote Link to comment Share on other sites More sharing options...
Willsy Posted February 16, 2016 Share Posted February 16, 2016 Have you tried classic99 via wine? 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted February 16, 2016 Share Posted February 16, 2016 Actually that's not true because I was running advmess on my Raspberry PI a few years ago and even though it's not as good as MESS today it might be able to run more programs than TI-99/SIM (but it would not have support for 512K carts). Recalling the thread http://atariage.com/forums/topic/232622-raspberry-pi-and-emulation/?p=3129498... @retrofan11: Considering MESS or not, it's pretty simple to decide: If you're simply looking for an emulation running under Linux without wine, dosbox, or any other virtual environment, take MESS. If you want to run an emulation on a Raspberry Pi, don't take MESS. advmame/advmess is from 2005 or before, and I started working on MESS in 2007, so nothing of my work is included, and you may have a chance to pick a version where the floppy support is broken. Quote Link to comment Share on other sites More sharing options...
ti99sim Posted February 17, 2016 Share Posted February 17, 2016 Agreed, so perhaps a "fix ti/sim" topic is in order? it has source code available Greg There should be new release of ti99sim "soon". I've cleaned up a few things (display glitches, possible crashes, etc) and re-written a bit more (disk I/O, filesystem support, and added read-only HxC disk image support). One thing that I've fixed recently is support for 512K carts and video issues with bitmap mode. Once I've verified that it still builds and runs properly on the Raspberry Pi, I'll uploaded to the website. If a "fix ti/sim" topic is created, I'll keep an eye on it. 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 17, 2016 Share Posted February 17, 2016 Awesome! Maybenu just a topic for the emulator like we have for classic99 and js99er Sent from my LG-H811 using Tapatalk Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted February 17, 2016 Share Posted February 17, 2016 One note, the largest current carts are actually 2048K now (and use the same bank scheme as the 512K carts) extended two more bits.. Quote Link to comment Share on other sites More sharing options...
ti99sim Posted February 17, 2016 Share Posted February 17, 2016 That shouldn't be a problem. I'll see if I can up the maximum size before I release it. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted February 17, 2016 Share Posted February 17, 2016 Here are two files that may be helpful. They test the bank switching on a 2048K cartridge image using non-inverted banking and on a 128K image using inverted banking. Inverted cartridges only exist up to 128K, but are quite common in the 16-128K range. banktestR128_3.bin banktest2048_8.bin Quote Link to comment Share on other sites More sharing options...
Tursi Posted February 17, 2016 Share Posted February 17, 2016 The entire bank switch testing suite, and the scripts that build it, are on my page here: http://www.harmlesslion.com/software/banktest 1 Quote Link to comment Share on other sites More sharing options...
ti99sim Posted February 17, 2016 Share Posted February 17, 2016 A quick test of the bank switch testing suite looks promising: the candidate release version supported all of the files without any issues. I've also tested the tiworkshop and 8in1 cartridges and everything seems to be working. The support for both styles is actually the same. The cartridge conversion program simply packs the ROM images in reverse order (a simple cheat, but it works). This seems to pass the bank switch test without any issues. Unless someone knows of a reason this won't work. I think the bank switch support is ready to go. 2 Quote Link to comment Share on other sites More sharing options...
