TXG/MNX Posted September 21, 2014 Share Posted September 21, 2014 Hello, What would be the best option to use to decompress a serie of pictures in sequence ice, lzjag, bpeg, arj ? I am interested to know which packer would be optimal for this. Quote Link to comment Share on other sites More sharing options...
ggn Posted September 21, 2014 Share Posted September 21, 2014 If you're not going to share more info then I would suggest you trying every packer out there and compare sizes. Different packers yield different results depending on what's required of them. 2 Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted September 21, 2014 Share Posted September 21, 2014 Depends on the kind of picture. For photos/complex graphics, and if you can tolerate some quality loss, BPEG will give much better compression ratios than others formats. You can also try Ray's BIQ stuff (at the end of the page): http://web.archive.org/web/20070206115827/http://freenet-homepage.de/ray.tscc/misc.htm For simple graphics or if you need perfect quality, try ICE, LZ, ARJ, etc. and see which one works best with your pictures. 2 Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted September 22, 2014 Author Share Posted September 22, 2014 Hi, Didn't know this BIQ stuff only the jaguar supports not there: at present BIQ supports 8bpp greyscale, 8bpp colormapped (!) and 24bpp RGB images.support for 16bpp RGB / 16bpp CrY (jaguar) is planned for the future. But compression ration seems pretty good. I mainly use 256 color BMP files size 320x200 and 160x200 I want to decompress them as quick as possible so within 1 frame when possible. Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted September 22, 2014 Share Posted September 22, 2014 Then BPEG isn't suitable. Try the different lossless compressors and see which one is the fastest. Quote Link to comment Share on other sites More sharing options...
Chilly Willy Posted September 22, 2014 Share Posted September 22, 2014 You might consider ELM's Tiny JPEG: http://elm-chan.org/fsw/tjpgd/00index.html It can decompress to RGB565, so it shouldn't be too hard to rewrite for other 16 bit modes. Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted September 22, 2014 Share Posted September 22, 2014 I doubt it would be fast enough to decompress in one frame time, when BPEG which is optimized for the GPU can't do that IIRC. Quote Link to comment Share on other sites More sharing options...
Chilly Willy Posted September 22, 2014 Share Posted September 22, 2014 He's not going to get ANYTHING for images with decent compression that will decode in one frame... that's the realm of video compressors where they compress over several/many frames to get the compression while being roughly fast enough to decode in one frame. If he wants that, he should be looking at cinepak, not any single image compression scheme. Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted September 22, 2014 Share Posted September 22, 2014 I'd say the only way you'd do that inside of a frame is with deltas. That's just too much data to process in 1/60th of a second. 3 Quote Link to comment Share on other sites More sharing options...
Songbird Posted September 23, 2014 Share Posted September 23, 2014 I used LBM / IFF (also known as Deluxe Paint format) for compressed 256-color graphics in Protector, but even relatively small graphics took more than 1 frame to decompress. 320x200 is 64KB uncompressed with 8 bits per pixel. What's your target medium (cart vs. CD), and how many frames do you need? Quote Link to comment Share on other sites More sharing options...
GT Turbo Posted September 23, 2014 Share Posted September 23, 2014 This is RLE compressed, you can use the same routine than Degas Elite PC1 format. I think you can add some lines for 8 bitplanes, here come one routine i coded some years ago : http://www.atari-wiki.com/?title=Fast_Degas_PC1_decompressor_code 1 Quote Link to comment Share on other sites More sharing options...
ggn Posted September 24, 2014 Share Posted September 24, 2014 For quick depack times lz77 is probably the best solution. Although packing ratio might not be satisfactory. Quote Link to comment Share on other sites More sharing options...
Chilly Willy Posted September 24, 2014 Share Posted September 24, 2014 For quick depack times lz77 is probably the best solution. Although packing ratio might not be satisfactory. Yeah, I use lz77 when I can. It's good on some things, but not really great on most images. Compressing is a bit slow, but decompressing is really fast. Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted September 26, 2014 Author Share Posted September 26, 2014 I decided to start with ice packer, thats also used in Native from Duranik and seems pretty quick, there is dsp version and source. I did see that the pictures from that game were very small in compression so that would fit my need I guess but I will do more tests in the future to see if I stay with ice or switch. Quote Link to comment Share on other sites More sharing options...
GT Turbo Posted September 26, 2014 Share Posted September 26, 2014 If you want a lz77 dsp unpacking rout for the Jag, just ask http://www.jagware.org/index.php?showtopic=98&pid=4627&mode=threaded&start=&do=findComment&comment=4627 GT Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted September 26, 2014 Author Share Posted September 26, 2014 That was an old thread :-) I see I visited this aswell someway I lost it. Thanx, there was also a talk about lz78 I remember is that an even better decompressor ? There are many formats so I get a little confused by lz77, lz78 etc.. It seems to me both can get the same packing ratio only the way it works is different. I did read about lz4, it should not compress aswell as lz77 but would be very fast (how much would the packing ratio be compared to lz77) ? Is there an lz4 decoder for the dsp ? Or @GT Turbo could you write one ... Quote Link to comment Share on other sites More sharing options...
GT Turbo Posted September 26, 2014 Share Posted September 26, 2014 Hi Txg everything is possible, just finding free time See which unpacking rout you need and send a message We will see what we can do for you Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted September 26, 2014 Author Share Posted September 26, 2014 Ok let you know for now its ice i am not a good coder yet learning goes slow reading books docs and look in examples to see how things work but i get there by myself :-) 1 Quote Link to comment Share on other sites More sharing options...
GT Turbo Posted September 28, 2014 Share Posted September 28, 2014 I have started with Gfa basic, and after i started to learn asm, it was very difficult at the beginning, but when you got some knowledges with this langage, it's a powerful langage, giving speed and technics If you have questions, just ask, there are a lot of experimented coders in 68000 here Quote Link to comment Share on other sites More sharing options...
