Omegamatrix Posted September 28, 2014 Share Posted September 28, 2014 Here is a test rom I made that shows the value of RIOT ram, SP, A, X, Y, etc... all at power-on. This rom could be useful for future emulator development. In this rom I didn't attempt to check the value of the timer (or TIMINT) as that would best be done with a rom strictly devoted to that one task. If you are wondering, the ram is laid out exactly like how it is Stella. I feel most programmers will intuitively understand this format, and know what they are seeing without explanation. If you don't, then just start-up Stella and take a look inside the debugger to get a better idea. Here you go! StartupValues.zip 14 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted November 28, 2017 Share Posted November 28, 2017 I get all 0 for the RAM when I test this with my PAL Darth Vader. What console were you using? Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted November 28, 2017 Share Posted November 28, 2017 I get all 0 for the RAM when I test this with my PAL Darth Vader. What console were you using? How are you running the ROM on the console? Are you using a harmony or a "naked" melody board? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted November 28, 2017 Share Posted November 28, 2017 A Harmony with the ROM directly flashed onto it. Does that still affect the initial state? Quote Link to comment Share on other sites More sharing options...
DirtyHairy Posted November 28, 2017 Share Posted November 28, 2017 (edited) A Harmony with the ROM directly flashed onto it. Does that still affect the initial state? I don't think so, but I don't know for sure. The only way to find out would be to dirty the RAM and then to reset the console by a quick power cycle: if memory is all zeroes again, then the harmony runs init code even if the ROM is flashed directly. Edited November 28, 2017 by DirtyHairy Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted November 29, 2017 Author Share Posted November 29, 2017 A Harmony with the ROM directly flashed onto it. Does that still affect the initial state? It shouldn't. I also flashed directly to my Harmony for development testing. I found my consoles were not all zero values for the riot ram, however my colecovision with a 2600 adapter always had all zero values at startup. 2 Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted March 8, 2018 Share Posted March 8, 2018 It shouldn't. I also flashed directly to my Harmony for development testing. I found my consoles were not all zero values for the riot ram, however my colecovision with a 2600 adapter always had all zero values at startup. Interesting thread Omegamatrix! Wondering if this analyzer could be easily adapted to dump SARA and analyze her startup values instead of the RIOT RAM? No one is making CBS RAM carts but Superchip carts are still being manufactured so it should be possible to see SARA's initial state to gauge a similar comparison as per this thread: http://atariage.com/forums/topic/276328-gates I expect SARA to be zeroed but your cross console results are intriguing, maybe not all SARA chips act the same either. Which consoles RIOT were not zeroed if you happen to remember? Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted March 8, 2018 Author Share Posted March 8, 2018 Interesting thread Omegamatrix! Wondering if this analyzer could be easily adapted to dump SARA and analyze her startup values instead of the RIOT RAM? No one is making CBS RAM carts but Superchip carts are still being manufactured so it should be possible to see SARA's initial state to gauge a similar comparison as per this thread: http://atariage.com/forums/topic/276328-gates I expect SARA to be zeroed but your cross console results are intriguing, maybe not all SARA chips act the same either. Which consoles RIOT were not zeroed if you happen to remember? It can't easily be adapted as the Super Chip ram is on the cartridge, not on the console. Also all the consoles I tried had non-zerod ram (4 switch, 6 switch, Atari Jr.). The exception was a Colecovision with a 2600 adapter. Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted March 8, 2018 Share Posted March 8, 2018 It can't easily be adapted as the Super Chip ram is on the cartridge, not on the console. Also all the consoles I tried had non-zerod ram (4 switch, 6 switch, Atari Jr.). The exception was a Colecovision with a 2600 adapter. Why couldn't you just set it to read high RAM instead of page 0 - if someone were to burn a superchip cart with your program adjusted like that couldn't it show the state of SC RAM on power-up? My Vader appears to consistently retain the state of whatever was last in the RIOT using your program. Possibly another piece of the puzzle, your colecovision adapter might have RAM characteristics more like the superchip and CBS RAM, for being more contemporary with them. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted March 8, 2018 Share Posted March 8, 2018 I thought that it's been verified that the stack pointer is $FD on cold start? Quote Link to comment Share on other sites More sharing options...
+stephena Posted March 8, 2018 Share Posted March 8, 2018 I thought that it's been verified that the stack pointer is $FD on cold start? It has, and Stella (at least) defaults to this value for SP. But if you enable randomization of SP, then of course it will be randomized. 1 Quote Link to comment Share on other sites More sharing options...
+SvOlli Posted April 5, 2018 Share Posted April 5, 2018 I thought that it's been verified that the stack pointer is $FD on cold start? Not on my PAL jr. There it changes on every start. Quote Link to comment Share on other sites More sharing options...
