Virtual Serial Host Version 1.0 PCB's available
recently I released Virtual Seral host 1.1 hardware
Virtual Serial drive has a little bit of history, but in a nutshell it allows non offending PRODOS software to be served over an Apple II serial port from a PC
Virtual serial host does the same thing minus a PC, via a cigarette packet sized stand alone device with an SD card, It is not compatible with all or most apple II software, if interested in its benefits please run the AII to PC serial link in ADTpro software to see if its worth while.
no warranty implied!
what I am offering in this thread is a blank version 1.0 production ready PCB, But!!!
The DE9 connector is wired backwards on these pcb's so you will have to patch around that
the PCB's are unpopulated, though aside from the backwards serial port are functional
the PCB's use 1 less capacitor to squelch line noise, works fine but for final I added 100uf
unpopulated PCB's 2.00$ + postage, good luck and have fun
one populated 1.1 version in plastic case + 128meg SD card +power supply, assembled ... 45$ shipping included in the COSUA
