+Saturn Posted October 7, 2014 Share Posted October 7, 2014 Hi, trying to create a cinepak disk and so far I've been shooting blanks (coaster factory over here) Based on the steps below, can anyone enlighten me as to what is missing or what I'm doing wrong? Open QuicktimeClick File-Open FileNavigate to file and double click itIn new, smaller Quicktime window, click File-ExportRename if neededSave as type: All filesExport: Movie to QuickTime MovieUse: Default SettingsClick the Options buttonClick Video SettingsCompression type: CinepakFrame Rate: 15 (can be adjusted to 24 & below)Depth: Millions of colorsQuality: Medium (variable that may need to be adjusted)Data Rate: Restrict to: 1500 kbps (variable that may need to be adjusted)Click OKClick Video SizeUse custom sizewidth: 320 (the Jaguar will clip off anything beyond this resolution)height: 200 (the Jaguar will clip off anything beyond this resolution)Click OKClick Sound SettingsFormat: Linear PCMChannels: Stereo (or Mono)Rate: 21.252 (this provides the best audio)Quality: Normal (variable that may need to be adjusted)Sample Size: 8 bitsthe 2 checkboxes under that, I always leave unchecked, but try some things with it too Click OK and you are ready to save Open JagCinePak.exe from JagMOD's siteDown where it says 'Track Number" put 4 (actually found this step to be pointless for what we are using)Drag your video.mov into the window(Windows color scheme will be changed on later versions, 7, etc. Don't panic!)(7 additional files will be created where the original was dragged from:FilmToAIFF.logMovieToFilm.logSmoothToChunky.log*name*.aif*name*.crg*name*.srg*name*.t04)Delete all but *name*.t04 (and the original video file, of course)Rename *name*.t04 to TRACK04.RAWPut TRACK04.RAW inside the CDEnc folderPut a blank CD-R in the burnerRun "scanbus.bat"Edit "burnunen.bat" w/ the device numbers and file name (in one place)Quick save and run itTest the unencrypted disk using a bypass method This is where I stop, as the test fails. These steps are based on . I took screenshots of all the steps and used them to compile the (incomplete) steps above. It looks like RubixCube6's "CDenc" folder has additional files. To my knowledge, his site's been down for some time so I can't download the package as directed here.Are these files available anywhere else? Or, is there a 'Cinepak Player Module' that's possibly specific to this technique that I'm missing? (mentioned in this post) Any help is appreciated Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted October 7, 2014 Share Posted October 7, 2014 Your video datarate is very high 1500kbps the cd can handle max with audio 300 if youre lucky... 1 Quote Link to comment Share on other sites More sharing options...
+Saturn Posted October 7, 2014 Author Share Posted October 7, 2014 So, if I slow down the bitrate, that alone will produce a viewable video? So far all I've gotten is the dark blue image onscreen. Worth a shot, I guess. Been keeping Verbatim's stock pretty high lately anyway Quote Link to comment Share on other sites More sharing options...
Chilly Willy Posted October 7, 2014 Share Posted October 7, 2014 (edited) Your video datarate is very high 1500kbps the cd can handle max with audio 300 if youre lucky... Given the setting he mentioned, the bitrate is with audio + the overhead of .mov container. The theoretical limit for 1X CD with ECC is 1228.8 kbps, and the Jaguar CD is 2X and doesn't use ECC, making the limits even higher. The settings did indicate he was using the truecolor version of cinepak. Maybe the Jaguar player only like the 8-bit paletted version. EDIT: The Jag cinepak readme says 16 bit rgb or cry format. Edited October 7, 2014 by Chilly Willy Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted October 7, 2014 Share Posted October 7, 2014 You can use 24-bit video but not high framerate maybe 10 fps without audio. 16-bit or 256 color are possible aswell. It all depends on the footage you got The windows cinepak convertor has less options as the mac. I bought an imac just to run the 35kb tool for cinepak ... Need to play around with it. I read cinepak in cry would give 10% more speed so that would be nice to just handle a liitle more quality. Quote Link to comment Share on other sites More sharing options...
+Saturn Posted October 8, 2014 Author Share Posted October 8, 2014 Just tried it with a Data Rate restricted to 300 kbps. No change, still with the dark blue screen. Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted October 8, 2014 Share Posted October 8, 2014 Did you place a cinepak player track on the cd aswell ? Quote Link to comment Share on other sites More sharing options...
+Saturn Posted October 8, 2014 Author Share Posted October 8, 2014 No, I don't have one. Was asking if one existed or was needed in my original post but didn't see an answer to that particular question. Here's the contents of my burnunenc.bat: cdrecord -speed=1 -dev=1,1,0 -pad -tao -audio -multi warning.wavcdrecord -speed=1 -dev=1,1,0 -pad -tao -audio TRACK04.RAW pm_dummy.raw trk_2b.rawclscall hyperterm.battype Text.txt | cb What other files are in the CDenc folder from the video? He has 3 or 4 iirc. Quote Link to comment Share on other sites More sharing options...
+Saturn Posted October 8, 2014 Author Share Posted October 8, 2014 After looking around, the only Jaguar Cinepak Player I could find is the "heavily modified" version on Orion's site I'm not sure if it's BJL only or if a n00b could incorporate it into this method. Do you know if the old/regular version is out there for download anywhere? Quote Link to comment Share on other sites More sharing options...
+Saturn Posted October 8, 2014 Author Share Posted October 8, 2014 (edited) No, I don't have one. Was asking if one existed or was needed in my original post but didn't see an answer to that particular question. Here's the contents of my burnunenc.bat: cdrecord -speed=1 -dev=1,1,0 -pad -tao -audio -multi warning.wav cdrecord -speed=1 -dev=1,1,0 -pad -tao -audio TRACK04.RAW pm_dummy.raw trk_2b.raw cls call hyperterm.bat type Text.txt | cb What other files are in the CDenc folder from the video? He has 3 or 4 iirc. The missing files are clearly shown here about half way down the page. Same ones from the video, TRACK02.RAW & TRACK03.RAW. (The link to download the zipped package on that page is dead, too.) Does anyone have these and can upload them? Edited October 8, 2014 by Saturn Quote Link to comment Share on other sites More sharing options...
GT Turbo Posted October 10, 2014 Share Posted October 10, 2014 Cinepak, only done poor quality video, bad sound and eat a lot of cpu time, so if you want to see a video, use our dvd player instead 4 Quote Link to comment Share on other sites More sharing options...
+Saturn Posted October 10, 2014 Author Share Posted October 10, 2014 LOL, I'm actually loving the crap quality and want to convert more & more to it Trying all this in an effort to convert 3-4 minute music videos to play on my Jag while I'm blasting the weights. I was informed of the 'original' player in Orion's pack in the src folder so I'm putting together my own repository of info, atm. Love this stuff 2 Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted October 10, 2014 Share Posted October 10, 2014 When you compare it with Full HD blueray it's even worst But the cinepak is mostly restricted to the CD-ROM speed on the jaguar. You could play it pure from RAM but short samples. I wonder how good it would be if a full movie could be played at RAM speed. Ofcourse it uses cpu but who cares when watching a movie... audio could be pretty decent I think, but on CD-ROM you need to balance video/audio within the available bandwith. @GT TURBO But maybe you can show us a HD-READY video player based on MP4 running on GPU/DSP :grin: 2 Quote Link to comment Share on other sites More sharing options...
+Saturn Posted October 10, 2014 Author Share Posted October 10, 2014 @GT TURBO But maybe you can show us a HD-READY video player based on MP4 running on GPU/DSP :grin: Yes, please 1 Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted October 10, 2014 Share Posted October 10, 2014 Sure. Would you like fries with that? 4 Quote Link to comment Share on other sites More sharing options...
Fredifredo Posted October 10, 2014 Share Posted October 10, 2014 Cinepak with JagCF should be funny no more 2x CD speed bitrate ... Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted October 10, 2014 Share Posted October 10, 2014 Yes but this JagCF will that be released ??? I thought this would be like the jaguar on fpga project just a project to show... Quote Link to comment Share on other sites More sharing options...
GT Turbo Posted October 10, 2014 Share Posted October 10, 2014 Mp4 in slow motion, only Jaguar can do it Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted October 10, 2014 Share Posted October 10, 2014 Show us how slow it would be ... 1 Quote Link to comment Share on other sites More sharing options...
Chilly Willy Posted October 11, 2014 Share Posted October 11, 2014 Technically speaking, any system can decode full h.264 HD... just not in real-time. If you're talking about real-time video on a console like the Jaguar, you've really only got two realistic choices: cinepak, and roq. Both can be encoded by FFMPEG, and decoder source is available. I recently made a ROQ player for the N64 to get an idea how well it works. I'll probably try my hand at that on the Jaguar once I get all the dev tools worked out. 3 Quote Link to comment Share on other sites More sharing options...
GT Turbo Posted October 11, 2014 Share Posted October 11, 2014 Yes, Jaguar like sinclair can decode any kind of files, but not in real time or 'french real time '. We have done a 68000 Png decoder (Full asm) and even on a 95 Mhz 68060 Png picture take seconds to be decompressed, so if it's for precalculating 'real time video', it's not really interresting, delta packing is surely a better choice for 'low speed console' I love the Jaguar like all others Atari machines i've got, but sometimes we have to use 'alternatives' for having a good experience 2 Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted October 11, 2014 Share Posted October 11, 2014 Nice build a png decoder for gpu :-) Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted October 11, 2014 Share Posted October 11, 2014 @Chilly Willy what resolution and fps would a roq file play when there is a code for gpu player? Quote Link to comment Share on other sites More sharing options...
+Saturn Posted October 12, 2014 Author Share Posted October 12, 2014 I've encoded some music videos to 320x200 at restricted data rates of 300kbps and 280kbps in an older version of QuickTime Player as it seems the newest version 7.7.5 doesn't include the Cinepak codec. None of them will play though. Still getting that dark blue screen on my coasters. I know the bypass carts work. Have switched between using Protector SE and BSG but the results are the same. When I convert Player.bin to Player.RAW (T00), then add the videos (T01, T02, etc.) it looks like they aren't found by the player. These are all on Session 2 of course w/ the normal Warning.wav as the only track on Session 1. Do the video tracks have to be a certain length? This doesn't seem to be a factor in the JagAds 2.0 or the Atari Big Disk that myAtari sells so I'm just grasping at straws. Here are the commands I use in batch to convert Player.bin: MAKETRK -b1c0000 -z Player.binPADCD +100000 Player.T00 Player.RAW Here's the burnunenc.bat: cdrecord -speed=1 -dev=1,1,0 -pad -tao -audio -multi warning.wavcdrecord -speed=1 -dev=1,1,0 -pad -tao -audio Player.RAW Video.RAW trk_2b.raw To my knowledge, this should work I'm thinking it's either my player or my converted videos. Can anyone help? Also, do the files in Orion's src folder for the original Cinepak player need to be incorporated somehow? (as they seem imperative to the function of Player.bin) I'm struggling to keep my goal of making a working disk alive but every attempt fails. Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted October 12, 2014 Share Posted October 12, 2014 Will help out soon but this week I got to much work and appointments I must attend :-( I will look at your footage original and converyed to see if there are issues. I believe Quicktime 7.5 or higher has issues... Need to verify what version I use butI am not near my dev kit now... 1 Quote Link to comment Share on other sites More sharing options...
