bluemonday Posted March 11, 2015 Share Posted March 11, 2015 Yes, it remembers your settings. Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted March 12, 2015 Share Posted March 12, 2015 That is great. I will have to try one of these out to compare with the 1970VX. Quote Link to comment Share on other sites More sharing options...
qq1975b Posted March 12, 2015 Share Posted March 12, 2015 The 1970NX and NXp are more common than the VX one. Quote Link to comment Share on other sites More sharing options...
venom4728a Posted March 15, 2015 Share Posted March 15, 2015 FYI, Tested 1970vx with 130xe / vbxe(standard core) output wired to 15pin hd vga and it does not work. So an up-scaler is still needed for the 8 bits. Robert Quote Link to comment Share on other sites More sharing options...
firebottle Posted August 14, 2015 Share Posted August 14, 2015 (edited) I just found an NEC Accusync LCD51V at a rummage sale. It synced down to 15khz using both NTSC & PAL on my Amiga 1200. I don't have a custom DIN to VGA cable for the ST yet, but I don't see why it wouldn't work with it. Atari ST's have seperate H & V sync? Edited August 14, 2015 by firebottle Quote Link to comment Share on other sites More sharing options...
NightSprinter Posted August 14, 2015 Share Posted August 14, 2015 I believe so. There's pins for the separate syncs, as well as a pin for Composite Sync (non "e" models without RF modulator) or Composite Video (STe and ST units with the RF modulator). Quote Link to comment Share on other sites More sharing options...
eccofonic Posted August 30, 2015 Share Posted August 30, 2015 Made a makeshift connection using the cable from a Monitor Master, a VGA ribbon cable from an old 8400gs card, and some jumper wires. The NEC Accusync LCD51V worked fine with a 1040ST. Low res looks good, but medium res looks a little odd, like vertical pixels are missing. Quote Link to comment Share on other sites More sharing options...
galax Posted August 31, 2015 Author Share Posted August 31, 2015 Yeah medium res isn't perfect, it seems to interpret it as a 640 pixel wide signal wheras the ST display is 640 pixels + the overscan area. Low and high are the only two resolutions I use though, and with a bit of cable soldering the monitor should support high just fine. Quote Link to comment Share on other sites More sharing options...
ryoder Posted November 14, 2015 Share Posted November 14, 2015 I just ordered this for my ST and maybe it will work with the Amiga 600. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=1970vx&N=-1&isNodeId=1 Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted November 14, 2015 Share Posted November 14, 2015 Got a Nec 1970VX off ebay the other day for like $20. Very exited to see how it works. Quote Link to comment Share on other sites More sharing options...
+poobah Posted November 15, 2015 Share Posted November 15, 2015 Also, if you have some Classic Macs in your collection, the Nec 1970's seem to get along nicely with them. I got usable pictures out of a Mac II, IIcx, Centris 610, Performa 6115 and 6200. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted November 16, 2015 Share Posted November 16, 2015 aye same with my mitsubushi E85LCD (which is the same as the NEC in a black case) Quote Link to comment Share on other sites More sharing options...
tjlazer Posted November 16, 2015 Share Posted November 16, 2015 Works great on the Amiga too! Quote Link to comment Share on other sites More sharing options...
ryoder Posted November 22, 2015 Share Posted November 22, 2015 (edited) Working perfectly! Got the Best cable and the NEC refurbished from NewEgg. Very impressed! Edited November 22, 2015 by ryoder Quote Link to comment Share on other sites More sharing options...
ryoder Posted November 23, 2015 Share Posted November 23, 2015 Ok not perfect yet. The green looks fine but when I run a game I see vertical banding especially in non primary colors. The banding changes as I adjust the width of the monitor but I can't get it to disappear completely. Quote Link to comment Share on other sites More sharing options...
Lumpy01 Posted December 8, 2015 Share Posted December 8, 2015 When using a Best VGA cable, I can verify the NEC LCD1970NX supports all three resolutions nicely on my 1040STE. Unfortunately, the earlier mentioned Mitsubishi E85LCD (Same panel?) only handles high resolution. The Mitsu does have a neat secondary VGA input which should work nicely with another Best cable, an Ambery box and a VGA switch for providing the low & medium resolutions. But unless I've missed something, it does not natively support all three resolutions like its NEC cousin. Quote Link to comment Share on other sites More sharing options...
calimero Posted December 11, 2015 Share Posted December 11, 2015 Hi, 1970NX owners, did you see this: http://archive.espec.ws/files/NEC%201970NX.pdfon page 4-5 - SERVICE MENU? In service menu you can adjust numerous parameters! On page 4-9 is eplanation how to fine adjust composite signal... I still did not try this options but I hope that I can adjust Nec 1970NX to display entire Amiga screen! By default Nec 1970NX cut around 16 lines when displaying Amiga 15KHz signal... Quote Link to comment Share on other sites More sharing options...
ryoder Posted December 16, 2015 Share Posted December 16, 2015 (edited) When using a Best VGA cable, I can verify the NEC LCD1970NX supports all three resolutions nicely on my 1040STE. Unfortunately, the earlier mentioned Mitsubishi E85LCD (Same panel?) only handles high resolution. The Mitsu does have a neat secondary VGA input which should work nicely with another Best cable, an Ambery box and a VGA switch for providing the low & medium resolutions. But unless I've missed something, it does not natively support all three resolutions like its NEC cousin. When you run in medium resolution in a game do you see strong vertical color bands with non primary colors? I do and it borders on the unusable.In tos I don't see it because the green displays fine. Certain colors create a banding effect that can be modulates by the fine adjustment but not eliminated. Edited December 16, 2015 by ryoder Quote Link to comment Share on other sites More sharing options...
leech Posted December 16, 2015 Share Posted December 16, 2015 I'm wondering if perhaps I should have gotten one of these instead of the Dell 2001FP, though it does work rather well so far I've only tested it out on my 1040STf, and it has (I think) other problems with it's video. Pretty sure at one point I found a loose capacitor in the machine, and even on a SC1224 it was flickering in random spots, but now I have no idea where it was. I posted about this in another thread anyhow, so don't want to double post here. Tempted to get one of these NEC's anyhow, to see if I like it as much as the Dell. Quote Link to comment Share on other sites More sharing options...
Wally1 Posted December 17, 2015 Share Posted December 17, 2015 does the NEC 1970 NX have built in speakers? thanks Quote Link to comment Share on other sites More sharing options...
Lumpy01 Posted December 24, 2015 Share Posted December 24, 2015 No speakers in the NEC. It would've been nice though. Saves some desktop space. Quote Link to comment Share on other sites More sharing options...
Wally1 Posted December 25, 2015 Share Posted December 25, 2015 so what and how do you use for speakers? thanks! Quote Link to comment Share on other sites More sharing options...
Lumpy01 Posted December 27, 2015 Share Posted December 27, 2015 My 1040STE has left & right RCA audio ports on the back so I used an RCA to 3.5mm headphone adapter/cable and ran it to some amplified computer speakers. Quote Link to comment Share on other sites More sharing options...
calimero Posted December 30, 2015 Share Posted December 30, 2015 I'm wondering if perhaps I should have gotten one of these instead of the Dell 2001FP, though it does work rather well so far I've only tested it out on my 1040STf, and it has (I think) other problems with it's video. Pretty sure at one point I found a loose capacitor in the machine, and even on a SC1224 it was flickering in random spots, but now I have no idea where it was. I posted about this in another thread anyhow, so don't want to double post here. Tempted to get one of these NEC's anyhow, to see if I like it as much as the Dell. If you get NEC 1970 please let us know how it perform in compare to Dell 2001FP! and here is video of NEC 1970 NXp: This video show Atari Falcon030 computer set in RGB mode (15KHz) showing picture on Commodore 1084S monitor and in same time on NEC 1970NXp since NEC support 15KHz input signal (I used ordinary VGA cable, I just disconnect PIN 19 (M0) for detecting VGA display)! Sorry for shaky video; I recorded it from hand with iPhone. Desktop is set to 786x480 pixel (overscan mode). As I change resolution on Falcon desktop you will see that NEC adjust it's own resolution but it will manage to show every Falcon 15KHz desktop resolution. You will also see demo "Joint Venture" running on both monitors (starts at 2:00) in parallel so you can see difference between proper RGB monitor such is Commodore 1084S and LCD Nec. I choose demo "Joint Venture" because there is lot of screens with custom Videl resolutions. Nec show all screens almost perfectly except few screen not being centred (3D tunel, still images...) and screen "RELITY.SYS CORRUPTED" does not have fade effect (?!? how this is even possible? ). Otherwise, NEC is almost perfect: colors on this PVA pannel are great! Black is also great (but there is light bleeding, visible in dark, but I do not mind). Resolution changing is very fast, there is no annoying messages from monitor about wrong resolution... Picture control are also good, monitor save setting for every resolution. Only thing that is missing is maybe "smoothing" option, for smearing pixels in low resolution. Some EIZO monitor has it, but I see that Amiga people complain that on EIZO monitor you can not turn off monitor message about wrong resolution in 15KHz mode... Hope you enjoyed, I will release few more video of NEC 1970NXp in 15KHz mode. btw, VGA mode on Falcon is flawless! 2 Quote Link to comment Share on other sites More sharing options...
ryoder Posted December 30, 2015 Share Posted December 30, 2015 Do you get any jail bars? Quote Link to comment Share on other sites More sharing options...
