toarnold Posted October 15, 2014 Share Posted October 15, 2014 Next dojo in starting jaguar development.I tried to figure out how to use a jerry timer. The exercise was to write a subroutine, getting a timer divider, a cancellation token, and an updateable counter. So it can be called from C: typedef void(*TimerHandler)(uint32_t time, uint32_t *cancellationToken, volatile uint32_t *count); Jerry should update the counter per interrupt until the host writes a value !=0 to the cancellationToken than Jerry has to stop. The ISR (Timer0 [interrupt 2] - remember to start ISR at D_RAM + 32) should look like (compare v8.pdf) dsp_int: load (r28),r29 ;get dsp flags bclr #3,r29 ;interrupt serviced load (r31),r30 ;get return from stack bset #11,r29 ;clear int source flag addq #4,r31 ;update stack addq #2,r30 ;update return address ; custom Code start load (r27),r26 addq #1,r26 store r26,(r27) ; custom Code end jump (r30) ;return from int store r29,(r28) ;set dsp flags The main loop in Jerry is very strait forward: jwaitloop: load (r9),r25 cmpq #0,r25 ; Test cancellation Token jr eq,jwaitloop nop First of all I find out my ISR never was executed, because I am writing the JPIT1 divider from a running Jerry. This didn't work. Set JPIT1 before starting Jerry! The second error was a little bit harder to detect. The program is running, but after a few seconds Jerry terminates himself by aborting the jwaitloop, but r25 was zero! This error can only happens if the interrupts occurs between the cmpq and the jr in the mainloop and the ISR isn't restoring the flags correctly. So I exchanged the last two line of the ISR and place a nop after the jump: store r29,(r28) ;set dsp flags jump (r30) ;return from int nop So my conclusion is. There is an error in the v8.pdf or the DSP. Under some circumstances the pipelined instruction after the jump isn't executed correctly, so the FLAGS restored wrong. Attached is my Visual Studio 2013 solution (it can build by commandline, too), so you can test by yourself - toarnold JerryTimer.zip 1 Quote Link to comment Share on other sites More sharing options...
GT Turbo Posted October 15, 2014 Share Posted October 15, 2014 Just wait a little, i have send a message to the interrupt's master !! SCPCD !! 1 Quote Link to comment Share on other sites More sharing options...
Chilly Willy Posted October 15, 2014 Share Posted October 15, 2014 All Atari code restores the flags AFTER the jump. In fact, it (correctly) points out that if you enable ints any other place but after the jump, another int can occur and corrupt the registers (in particular, r30 - the register you're getting ready to jump through), leading to a crash. For example, here's the int exit code for the Jerry CD audio: clean_up: ; do the housekeeping, per Leonard bclr #3,r29 ; clear IMASK bset #10,r29 ; set I2S interrupt clear bit load (r31),r28 ; get last instruction address addq #2,r28 ; point at next to be executed addq #4,r31 ; update the stack pointer jump (r28) ; and return store r29,(r30) ; restore flags Something else must be causing the crash, not the restore after jump. 2 Quote Link to comment Share on other sites More sharing options...
Zerosquare Posted October 16, 2014 Share Posted October 16, 2014 I've used the "restore after jump" code too and never had problems. So I agree the problem probably lies somewhere else. Writing to the JPIT1 reg from Jerry works fine for me, too. Quote Link to comment Share on other sites More sharing options...
toarnold Posted October 16, 2014 Author Share Posted October 16, 2014 I agree with you and my understanding is the same, But can you try to reproduce the error? In fact in my sample the interrupt occurs every second. So I can't believe a second interrupt occurs. The error occurs randomly between 1..30 seconds on my jag. I don't believe it is a crash, 'cause the code after the jwaitloop executed correctly. Changing the cancellation code to jwaitloop: load (r9),r25 cmpq #1,r25 ; Test cancellation Token jr ne,jwaitloop nop seems to heal the error ... I'learn, so if someone can point me the error I'll very happy . - toarnold Quote Link to comment Share on other sites More sharing options...
Chilly Willy Posted October 16, 2014 Share Posted October 16, 2014 Your setting the flags early doesn't crash because the int doesn't occur until much later. If other ints could occur, it could fail. What I think might be the problem with the correct order is this (from the doc): If Jerry asserts DSP bus request one cycle after a previous bus request it is possible for it to see the end of the previous bus grant for one cycle, and this can mean that Jerry writes occur with the wrong data. The work-around is to ensure that Jerry is off the bus before performing a write, either by leaving a long period of bus inactivity, which is usually greater than the maximum possible period of object processor bus ownership; or to perform a load and perform an operation on the loaded data so that the score-board unit can ensure the load has completed. Quote Link to comment Share on other sites More sharing options...
toarnold Posted October 16, 2014 Author Share Posted October 16, 2014 Writing to the JPIT1 reg from Jerry works fine for me, too. Thx, I found it. I wrote JPIT1 (PreScaler) and JPIT2 (Divider) separately. This is absolute nonsense. One 32-Bit move to JPIT1 did the trick. So Timer1 can be manipulated by Jerry. 2 Quote Link to comment Share on other sites More sharing options...
