two-port 5200 video problem... help?
TheDreadGazeebo
I Picked up a boxed 5200 today from my local Salvation Army, It's in beautiful shape, but when I got it home and hooked it up, all I got was a garbled mess. Hoping someone can point me in the right direction, as I would really like to get this guy working. I have cleaned the pins on the console as well as my games with rubbing alcohol. I have it hooked up via one of these things, and am using the Atari brand power adapter that came with it. I have tried every possible combination of channels/switch positions too.
Here's what I usually get when I try to play some Pac-Man:
And here's what I get once in a blue moon if I wiggle the cartridge just right:
Any ideas what might be wrong here?
Nice find, hope somebody can help. I always thought the 2 port was more stable. Zylon fixed my 4 port and since then no issies except once in a blue moon. Today I knocked the 4 port box slightly while playing jungle hunt just now and it went dead. It would not turn back on. I was so scared. Then I unplugged the box and all the connections and ac and reseated everything until I heard the click and it turned back on. What a relief. Not sure if the box has a fuse or what happened. I've done it once before but it always comes back on after a reset of the connections.
The loss of horizontal sync / weird colors makes it look like the modulator is out of alignment. No advice to give as I've never adjusted the modulator on the 5200.
The service manual has a "Warped Ragged Picture Troubleshooting" section. It might be worth going through those tests.
It seems those tests require an oscilloscope which I don't have access to. However, I noticed these two wires soldered to A15 and A27 on the board. I haven't seen anything like this online, is this a mod or repair, or something from the factory?
qsIpYxk.jpg?1
Not sure of the wire, but some systems had improvements or cost cutting measures taken. The row of 8 IC's right above that wire are where I'd look first. Those are the RAM and it looks like some have been changed out before.
2nd place I'd check would be the 4 largest IC's on the board.
Should I just try swapping out each RAM chip one by one? I'm thinking of picking up a few of these which I found in another thread to try. Are those the correct replacements?
Not sure... The 5200 RAM is listed under custom IC's at Best Electronics so it may be different than the normal computers of the day. I'd have to go and look through my spare parts to see.
Best lists them at $1.50 each currently.
A couple ways of quick testing them is to feel if any get hot while running. A shorted IC will get very hot. (any that have MT as the brand should be replaced ASAP)
What I do is replace them one by one to find which ones are bad. I toss the bad ones and replace all 8 anyway. The leftover good ones I save for spares.
BTW: you may have more than one bad IC.
awesome, thanks for the help. Going to test them out and order some replacements today. By MT do you mean Mostek? all 8 of my chips are made by them, guess I'll just order 8 of those IC's. Does Best Electronics have an order form somewhere, or do you have to e-mail them to place an order?
Edit: so I fired the console up with the case open and checked all of the RAM chips. none of them seemed to heat up at all, but the two largest IC's right below the cartridge slot got pretty warm. is this normal?
Edited by TheDreadGazeebo
None should get more than just warm. Another common culprit for graphic issues is the GTIA, which is lower right.
  • 2 weeks later...
  • 3 weeks later...
  • 6 months later...
  • 7 years later...
On 12/26/2014 at 12:45 PM, ataridave said:
Well, Combat Commando, now I know what's wrong with my 5200. Except, in my case, the 5200 freezes after a minute or so of game play. I don't have any kind of electrical or soldering skills at all, so I'll give it to my older brother, who will give it to a place that recycles electronics.
What was wrong with it? Mines doing the same thing.
@ataridave hasn't been here since 2019, and his post dates from 2014.  Not saying this to be a jerk, but the chances of hearing back from him are pretty small.
What are the symptoms when yours locks up?  Any hot ICs?  We can probably figure this out, but your problem may not be exactly the same as his (whatever that was).
It may play for ten minutes or 1 minute that varies each time. It usually slightly distorts the picture but you can still see the game, and plays the last sound it made while still playing normally solid, like an indefinite beep I guess you’d say. I took it apart and cleaned where the cartridge goes in and had the silver inside cover off and didn’t feel anything inside it getting hot, I pushed down on all the chips like somebody had said in one of these old threads and it’s still the same. The inside looks totally clean and I don’t see anything that’s looks burnt. I hope it’s just that 4 port RF switch box. This 5200 came from an estate sell with 8 boxed games and 2 controllers and it all looks practically new like it didn’t get used much but there was no power supply and no RF switch so I got both off eBay from separate people, they just said tested but as far as that goes I can turn the thing on and play it a minute and turn it off and say I tested it. Maybe they didn’t test that RF switch long enough to make it fail, idk. Both the controllers a fully functional too if that might make a difference but I can’t see where it would on the video part.
