CPUWIZ Posted November 17, 2014 Author Share Posted November 17, 2014 Just need some clarity on how this listings translate exactly: FIRE1 FIRE1A FIRE1B FIRE2 FIRE2A I guess what's throwing me a curve is why three fire listings for Player 1? How exactly does... Player 1 Left Fire Button Player 1 Right Fire Button Player 2 Left Fire Button Player 2 Right Fire Button ...translate? I could possibly see... FIRE1 = Player 1 Left Fire Button FIRE1A = Player 1 Right Fire Button FIRE2 = Player 2 Left Fire Button FIRE2A = Player 2 Right Fire Button ...but then I don't understand what is FIRE1B supposed to denote, and why there is no FIRE2B Pardon my ignorance. I just had an epiphany so there may be a Fire2B, I am just experimenting. Ok, let me make the button situation a bit more clear. Instead of using the funky resistor circuit, I figured out what you need to do in order to make it function properly with a MCU. The 7800 uses the 2 paddle lines for the left and right fire buttons, in conjunction with the original fire button. So if you want a button to be the left fire button on a 7800 game, you would insert "Fire1 + Fire1A" and if you want a right button "Fire1 + Fire1B". But for a 2600 game like Omega Race, you would need to assign Fire, Fire1A and Fire1B to different buttons. Does that make more sense? 2 Quote Link to comment Share on other sites More sharing options...
iesposta Posted November 17, 2014 Share Posted November 17, 2014 I still do not understand, You will have to show a picture of 2 2600 sticks, next to 2 7800 sticks with your corresponding labels pointing to each controller's 5 functions. Remember both the 7800 buttons are the 2600 one fire button. Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted November 17, 2014 Author Share Posted November 17, 2014 OMG, it works!!! I can control all 7 signals on both ports now, for any system that uses a DB9 connector and digital signals. Will update the template now. 8 Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted November 17, 2014 Author Share Posted November 17, 2014 Remember both the 7800 buttons are the 2600 one fire button. That is precisely why you need to specify left as "Fire1 + Fire1A" and right as "Fire1 + Fire1B", so it still works on a 2600. But if you want to use it for a 3 button game on the 2600, you need to use all 3 on their own. Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted November 17, 2014 Author Share Posted November 17, 2014 I know people are mostly not tickled by this (judged by the lack of responses), but I just optimized the hell out of some other section and I bet I can get close to 30 configs working now. So I wrote some code where you can use the SELECT button as a SHIFT button so to speak and select even more configurations. If you are interested in a configuration for another system, just replace the names with the pin numbers and state (HI/LO) of the pin, when a button is pushed. 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 17, 2014 Share Posted November 17, 2014 This is all I could think of. Something compatible with batari BASIC games that use a Genesis controller. The extra Genesis button being designated P1 FIRE 2 and P2 FIRE 2. Alternatly for 7800 use P1 FIRE 2 and P2 FIRE 2 would be the standard 2nd button. This is the closest config I could think of that matches how I think a PSX joystick works for most games. I also took into consideration how the SNES joypad buttons are placed. This config should work for Princess Rescue as well as future games that would use the d-pad for shortcuts and analogue for movement. P.S. I PM'ed you further about getting 256k boards for my Tunnel's & Trolls game. I hope we can work something out! Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted November 17, 2014 Share Posted November 17, 2014 YES! This is fantastic! Great to see this being worked on. CPUWIZ, my prime concern lies with button layout. You can see mine and other's configuration thoughts here. In summary (for me): Ergonomically, holding the controller in the natural position of the hand and using your right thumb (Presuming common use of a PS2 pad)... Button 1/Left button should be Square and Triangle (Tip of thumb usage). Button 2/Right button should be X and O (Closer to palm usage). If someone were using their pointer and middle fingers from their right hand instead (Presuming common use of a [PS2] Arcade joystick)... Button 1/Left button should be Square and X. Button 2/Right button should be Triangle and O. More flushed out reasoning in this post respecting my preference, if interested. It's really preference. I prefer the buttons in the down and right positions as with Virtual Console Classic Controller and GBA games on DS. I always use option 2 on SMAS but many other gamers hate that configuration. To each his own I guess. Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted November 17, 2014 Author Share Posted November 17, 2014 Make some templates, guys, I have full control over both ports now. Only want to make a template for a single cable inserted? Fine with me. Quote Link to comment Share on other sites More sharing options...
Jinks Posted November 17, 2014 Share Posted November 17, 2014 (edited) Can you have two buttons configured to the same input? Like l2 button 1 and x button 1? If not a robotron with l3 player 1 and r3 players 2 directionals. Then a dpad player one directional and r3 player 2 directional and x player one left fire and o player 1 right fire. and the same idea with box player 2 fire left triangle player 2 fire right. Sorry I am so dumb I cant even begin to figure out how to use the template. I would have to go to my computer and use some sorta program? Thats why I cant use symbols and avatar pics cause I do it all on my phone. Edited November 17, 2014 by Jinks Quote Link to comment Share on other sites More sharing options...
Jinks Posted November 17, 2014 Share Posted November 17, 2014 It's really preference. I prefer the buttons in the down and right positions as with Virtual Console Classic Controller and GBA games on DS. I always use option 2 on SMAS but many other gamers hate that configuration. To each his own I guess.This is why when you plsy any mario hame U have these two config choices. Quote Link to comment Share on other sites More sharing options...
Trebor Posted November 17, 2014 Share Posted November 17, 2014 Here's my 1st preference config/setup: Quote Link to comment Share on other sites More sharing options...
RevEng Posted November 17, 2014 Share Posted November 17, 2014 OMG, it works!!! I can control all 7 signals on both ports now, for any system that uses a DB9 connector and digital signals. Will update the template now. Excellent progress with this! Can you use PWM with the pic pins going to DB9 5 and 9? If so, the analog joystick could act as a controller for paddle games. [edit] Missed the earlier comment on PWM requiring a redesign. Bummer! UDLR in one press would be a nice soft reset on a homebrew for sure. Turning that into a hard reset inside the console should be pretty easy too. You'd need a cheap logic gate IC, a bit of wire, and little else. Maybe add a cap to it so a very brief press is ignored. 1 Quote Link to comment Share on other sites More sharing options...
Trebor Posted November 17, 2014 Share Posted November 17, 2014 I would have to go to my computer and use some sorta program? Hi Jinks, Easiest method for me, is saving the template CPUWIZ provided in the opening post and then opening it under Paint (It's free and comes packaged with every version of Windows). You can then select to add text to the picture (highlighted in a red square box below) and place the cursor in the various box areas. To start entering text just click in the location. If you see the location you picked isn't right hit 'Esc' and try again, If after entering text, you do not like how it appears, do an 'undo' (CTRL-Z) and try again. 2 Quote Link to comment Share on other sites More sharing options...
Trebor Posted November 17, 2014 Share Posted November 17, 2014 Here's my 2nd preference/config setup, still keeping the PS2 pad in mind: Here's my 3rd preference/config setup, now keeping a PS2 joystick in mind: 1 Quote Link to comment Share on other sites More sharing options...
toiletunes Posted November 18, 2014 Share Posted November 18, 2014 I am working on some different button configs, I will post them Wednesday. 1 Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted November 18, 2014 Share Posted November 18, 2014 (edited) Excellent progress with this! Can you use PWM with the pic pins going to DB9 5 and 9? If so, the analog joystick could act as a controller for paddle games. The pots in the paddle controllers does not operate as a voltage divider but rather drains a capacitor within the console. PWM would only muck up the signal because the logic gate used to detect paddles is digital. When the paddle signal drops above/below the threshold, the state changes. The program counts the length of time transpired since the paddles were reset and this time constant increases as the pot value increases. A better method would be to wait for the reset signal and then hold the state for a certain length of time based on emulated paddle position. The microcontroller has an idea about what paddle position it wants to emulate and holds the output for the specified length of time. The paddle position could either reflect the absolute position of the analog stick or tilting the analog stick could change the delta on the paddle. Delta method would result in smoother movement onscreen since it is difficult to hold an analog stick at a steady position. Using delta, the paddle would only change position when the analog stick is tilted. Edited November 18, 2014 by stardust4ever Quote Link to comment Share on other sites More sharing options...
PacManPlus Posted November 18, 2014 Share Posted November 18, 2014 Here's my 2nd preference/config setup, still keeping the PS2 pad in mind: PS2CONVERT_TREBOR2.png Here's my 3rd preference/config setup, now keeping a PS2 joystick in mind: PS2CONVERT_TREBOR3.png This would be my preference as well. Damn I wish we could get the Select / Reset buttons in there... I know they are not extended into the joystick lines, but that would be cool Great job CPUWIZ! 2 Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted November 18, 2014 Share Posted November 18, 2014 (edited) Interesting that the PS1 controller used a 7.5v bus. I thought they were 5V or 3.3V like other systems. Edit: apparently they use a standard VCC. The 7.5v is only used to drive the rumble motors. http://pinouts.ru/Game/playstation_9_pinout.shtml Edited November 18, 2014 by stardust4ever Quote Link to comment Share on other sites More sharing options...
RevEng Posted November 18, 2014 Share Posted November 18, 2014 The pots in the paddle controllers does not operate as a voltage divider but rather drains a capacitor within the console. PWM would only muck up the signal because the logic gate used to detect paddles is digital. When the paddle signal drops above/below the threshold, the state changes. The program counts the length of time transpired since the paddles were reset and this time constant increases as the pot value increases. Just nitpicking... its the other way around. The cap typically gets grounded as part of vblank. The cap is then charged at a rate proportional to the pot resistance, and the time the logic "1" threshold is crossed is captured by code during the visible display. I'm not sure how using PWM to feed the cap would muck up the scheme. The brief "1" part of the PWM duty cycle will get sucked up by the cap until its charged enough, no? In any case, throw a low pass filter on that PWM and it will be indistinguishable from an analog voltage level, just like the pot. Quote Link to comment Share on other sites More sharing options...
RevEng Posted November 18, 2014 Share Posted November 18, 2014 Damn I wish we could get the Select / Reset buttons in there... I know they are not extended into the joystick lines, but that would be cool With this project and all of the custom controller projects coming out, someone should bang out a standard for hardware implementation of Select and Reset over the existing lines. I'll start the ball rolling... Taking Shawn Sr.'s suggestion of "U+D+L+R" for Reset is a good start. I think it would be workable if we split that up into "U+D+L" for Select and "U+D+R" for Reset. The nice bit about this is it wouldn't take a lot more than a couple of logic gate ICs to implement, and it could also be implemented in software, in future homebrews. (so people with new controllers but no mod could still benefit) It would probably need to be a first-port only thing, as I see likely collisions with AtariVox and the Keypad controller. The driving controller, regular joystick operation, and paddles shouldn't be able to accidentally trigger the mod. Anybody see any holes? 1 Quote Link to comment Share on other sites More sharing options...
toiletunes Posted November 19, 2014 Share Posted November 19, 2014 (edited) Exhibit 1: The Kid's Controller. This setup will work for AlphaBeam with Ernie, (uses keypad buttons 2,4,6, 8.) Big Bird's Egg Catch (L1 R1) Cookie Monster Munch (2,4,6,8 and 5 = action) and Oscar's Trash Race (2,4,6,8 = Direction, 5 = action, and 1,2,3 = pick the number) Hope this helps, hope this makes sense. Edited November 19, 2014 by toiletunes Quote Link to comment Share on other sites More sharing options...
toiletunes Posted November 19, 2014 Share Posted November 19, 2014 (edited) Exhibit 2 is for one-handed players, or if you're eating a sandwich. Works with the 7800 library. Edited November 19, 2014 by toiletunes Quote Link to comment Share on other sites More sharing options...
toiletunes Posted November 19, 2014 Share Posted November 19, 2014 RotLA also, Towering Inferno (no more switching controller jacks!) Quote Link to comment Share on other sites More sharing options...
toiletunes Posted November 19, 2014 Share Posted November 19, 2014 (edited) Star Raiders L1 = Computer on/off R1 = Shields on/off Square = Fore View Circle = Galactic Map Triangle = Warp more to come... Edited November 19, 2014 by toiletunes Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted November 19, 2014 Author Share Posted November 19, 2014 Fantastic, keep em coming, those are great. Surprised nobody has made a right handed setup yet. Also, don't forget guys, you can put any button anywhere and you can use them multiple times, this is all just assembly code. Quote Link to comment Share on other sites More sharing options...
