thej Posted December 8, 2014 Share Posted December 8, 2014 I have an Apple 2C+ and I need an external 5.25 floppy for it. Will the Apple 5.25 drives work? I assuming they would but the 2c+ has a "smart" port. Would the 5.25 external use that or another port? What uses teh "Smart" port? Thanks in advance !! Quote Link to comment https://forums.atariage.com/topic/232598-external-floppy-drive-question/ Share on other sites More sharing options...
Arbee Posted December 8, 2014 Share Posted December 8, 2014 (edited) "SmartPort" is simply a disk drive port that's capable of daisy chaining, from an end-user POV. In the case of the IIc+ you can connect a UniDisk 3.5 or Apple 3.5 Drive followed by a 5.25 Drive and it'll work. Or you can just connect the 5.25 Drive directly if you have no other external drives. Edited December 8, 2014 by Arbee Quote Link to comment https://forums.atariage.com/topic/232598-external-floppy-drive-question/#findComment-3129151 Share on other sites More sharing options...
Muzz73 Posted January 7, 2015 Share Posted January 7, 2015 Yep... in the case of the //c+, you can use both the UniDisk and the platinum white drives from the IIgs. I seem to think that the white drives had a better interleave ratio, making the drives faster, if memory serves me (which doesn't always happen these days). If someone can verify that, then it might be a good idea to keep an eye open for the platinum drives. Quote Link to comment https://forums.atariage.com/topic/232598-external-floppy-drive-question/#findComment-3148220 Share on other sites More sharing options...
Arbee Posted January 11, 2015 Share Posted January 11, 2015 On the IIgs at least that's right: the UniDisk 3.5 is fixed to 4:1 interleave since it's intended for use with base 1 MHz A2s. The Apple 3.5 Drive runs at 2:1 interleave on the IIgs. The IIc+ is an odd case so I don't know what interleave it uses/prefers for various drives. Quote Link to comment https://forums.atariage.com/topic/232598-external-floppy-drive-question/#findComment-3150664 Share on other sites More sharing options...
