+eebuckeye Posted December 18, 2014 Share Posted December 18, 2014 While I am looking for a 4MB card for my IIgs I have been trying to upgrade my Apple 256k memory expansion card to 1MB. I ordered these: http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?search_type=jamecoall&catalogId=10001&freeText=41256&langId=-1&productId=41398&storeId=10001&ddkey=http:StoreCatalogDrillDownView and I received a mix of these chips: NEC D41256C-12 9529B8A04 SIEMENS 8942 HYB 41256-12 SIEMENS 8936 HYB 41256-12 SIEMENS 8938 HYB 41256-12 SIEMENS 8937 HYB 41256-12 F MB81256-12 9348 M95 CD Of course the original chips installed for 256MB are TI TMS4256-12NL IGE8901. I installed the memory and received a few errors with the official Apple IIgs diag disks (in fact one of the errors pointed to one of the original 256k chips - UA8). I did have both jumpers installed. I performed the memory diag test with no extra chips installed and the base 256k passed. I moved the memory to another expansion card that looks like it has never been used before. When I run the diags it says the incorrect memory amount is installed. Again I placed both jumpers on the card and made sure the pins were shorted with an ohm meter. I also tested both cards with two different IIgs systems and received the same errors. The chips were installed correctly with pin 1 in the right location and I actually had another engineer look over the install and card. This is starting to drive me nuts. :-) At this point I just want to get 1MB working. Any suggestions? Thank you! 1 Quote Link to comment https://forums.atariage.com/topic/232899-apple-iigs-256k-1mb-memory-upgrade-problem/ Share on other sites More sharing options...
jamesk Posted December 18, 2014 Share Posted December 18, 2014 I know when I ordered DRAM from Jameco to fix a IIc, several of the chips didn't work. I had diagnostic failures and some of the chips got real hot. Jameco sent out replacements without any hassle. So it may just be that they sent you some bad chips. I don't know if mixing manufactures would pose an issue. Quote Link to comment https://forums.atariage.com/topic/232899-apple-iigs-256k-1mb-memory-upgrade-problem/#findComment-3135663 Share on other sites More sharing options...
Muzz73 Posted January 7, 2015 Share Posted January 7, 2015 (edited) I seem to think that some IIgs RAM cards (but not all) used odd RAM, too. I heard somewhere that they need RAS/CAS addressing instead of CAS/RAS or some silly thing. I don't even know what all of that means, but I was told that back in the early 90s. Edited January 7, 2015 by Muzz73 Quote Link to comment https://forums.atariage.com/topic/232899-apple-iigs-256k-1mb-memory-upgrade-problem/#findComment-3148213 Share on other sites More sharing options...
+eebuckeye Posted January 7, 2015 Author Share Posted January 7, 2015 I finally was able to get it work by trying multiple sets of chips (trial and error). It did not seem to like any of the Siemens chips. Quote Link to comment https://forums.atariage.com/topic/232899-apple-iigs-256k-1mb-memory-upgrade-problem/#findComment-3148300 Share on other sites More sharing options...
