phoenixdownita Posted December 19, 2014 Share Posted December 19, 2014 (edited) I looked at the motherboard on my XEGS and I can't find the C77/C78 capacitors that should be removed to support 127kb/s. I venture that for XEGS that is not required. Anyone can confirm? Also, regarding the 4k7 pullup that is recommended from DataOut to +5V, is that required at all in a XEGS? For those who don't know what I am taking about: http://sio2sd.gucio.pl/wiki/HighSpeed_en In that link it only covers 800XL, 65XE and 130XE. Thanks. Edited December 19, 2014 by phoenixdownita Quote Link to comment Share on other sites More sharing options...
BillC Posted December 19, 2014 Share Posted December 19, 2014 I looked at the motherboard on my XEGS and I can't find the C77/C78 capacitors that should be removed to support 127kb/s. I venture that for XEGS that is not required. Anyone can confirm? Also, regarding the 4k7 pullup that is recommended from DataOut to +5V, is that required at all in a XEGS? For those who don't know what I am taking about: http://sio2sd.gucio.pl/wiki/HighSpeed_en In that link it only covers 800XL, 65XE and 130XE. Thanks. I checked the Jerzy Sobola schematics for the XEGS, and while there are no C77/C78 there are inductors L15/L16 that are drawn with a capacitor off a center tap. I have examined these inductors and they do have 3 solder connections, it appears the capacitors are integrated into them. Quote Link to comment Share on other sites More sharing options...
atari8warez Posted December 19, 2014 Share Posted December 19, 2014 I looked at the motherboard on my XEGS and I can't find the C77/C78 capacitors that should be removed to support 127kb/s. I venture that for XEGS that is not required. Anyone can confirm? Also, regarding the 4k7 pullup that is recommended from DataOut to +5V, is that required at all in a XEGS? For those who don't know what I am taking about: http://sio2sd.gucio.pl/wiki/HighSpeed_en In that link it only covers 800XL, 65XE and 130XE. Thanks. I really don't think you need to remove those capacitors to achieve full speed on SIO. I always use my SIO2PC at 125,000 bps with AspeQt without any hesitation or hangs during I/O and none of my Ataris have those capacitors removed. So I don't know why this should a requirement for an SIO2SD to function at full speed. Quote Link to comment Share on other sites More sharing options...
