traindriver69 Posted December 26, 2014 Share Posted December 26, 2014 hi all I want to run a .bas file called T1020.BAS to try and workout what is wrong with my atari 1020 printer,I have a 1050 disc drive and a SIO2PC cable.but that only recognizes ATR files did try converting the .BAS to ATR with a windows program called text 2 atr and put the program on a disc but could not get it to run on the 800. or if some one could tell me how to get the listing for this program so that i could type it in manually that would be an option. many thanks in advance Quote Link to comment Share on other sites More sharing options...
Bryan Posted December 26, 2014 Share Posted December 26, 2014 I'm assuming you're using APE.. An ATR is a disk image which will contain it own files. To use a individual files, you'll need to set up a directory mirror. The other alternative is to create a fresh ATR and drop the file into it. Quote Link to comment Share on other sites More sharing options...
traindriver69 Posted December 26, 2014 Author Share Posted December 26, 2014 hi how do i create a fresh atr and drop the bas file into it. Quote Link to comment Share on other sites More sharing options...
russg Posted December 26, 2014 Share Posted December 26, 2014 (edited) hi all I want to run a .bas file called T1020.BAS to try and workout what is wrong with my atari 1020 printer,I have a 1050 disc drive and a SIO2PC cable.but that only recognizes ATR files did try converting the .BAS to ATR with a windows program called text 2 atr and put the program on a disc but could not get it to run on the 800. or if some one could tell me how to get the listing for this program so that i could type it in manually that would be an option. many thanks in advance I assume you downloaded the BASIC file, but can't figure how to run it. It needs to be on a .ATR (drop it on an .ATR) to access it. There's a PC program called 'makeatr.exe'. You 'drop' a file onto an ATR using that program. You run makeatr, then 'OPEN' an .ATR on your SIO2PC. Then (INSTERT) a file. Close the .ATR and exit makeatr. Now you have your T1020.BAS on an .ATR you can access on your real computer with SIO2PC and the .ATR you made. You have to have a .ATR to open and use. Here's 'makeatr.' Unzip it on your PC and then run it like above. You may have to 'install' it first, probably. You also have to have a DOS .ATR to be able to LOAD a BASIC file. I guess you can do DOS, put the T1020.BAS on a DOS .ATR. makeATR_v0.06.zip Edited December 26, 2014 by russg Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted December 27, 2014 Share Posted December 27, 2014 On an 800, you will also need a Basic cartridge. 1 Quote Link to comment Share on other sites More sharing options...
russg Posted December 27, 2014 Share Posted December 27, 2014 I assume you downloaded the BASIC file, but can't figure how to run it. It needs to be on a .ATR (drop it on an .ATR) to access it. There's a PC program called 'makeatr.exe'. You 'drop' a file onto an ATR using that program. You run makeatr, then 'OPEN' an .ATR on your SIO2PC. Then (INSTERT) a file. Close the .ATR and exit makeatr. Now you have your T1020.BAS on an .ATR you can access on your real computer with SIO2PC and the .ATR you made. You have to have a .ATR to open and use. Here's 'makeatr.' Unzip it on your PC and then run it like above. You may have to 'install' it first, probably. You also have to have a DOS .ATR to be able to LOAD a BASIC file. I guess you can do DOS, put the T1020.BAS on a DOS .ATR. A little mistake there. You use makeatr to open an .atr that you have someplace on your pc. makeatr doesn't access sio2pc. Quote Link to comment Share on other sites More sharing options...
russg Posted December 27, 2014 Share Posted December 27, 2014 (edited) A little mistake there. You use makeatr to open an .atr that you have someplace on your pc. makeatr doesn't access sio2pc. As a matter of fact, if the .ATR in question is open in APE/ASPEQT, it will not open in makeatr. At least, that's what would happen in Win. 8.1. It makes sense, you can't alter an .ATR while it is open in an emulator or APE/ASPEQT. Edited December 27, 2014 by russg Quote Link to comment Share on other sites More sharing options...
Level42 Posted December 27, 2014 Share Posted December 27, 2014 I've always been baffled by the fact that APE And AspeQT -can- create a new disk image, but -can not- handle dragging and dropping files in that freshly created image.... Using MakeATR works fine but it's a cumbersome and slow detour. Quote Link to comment Share on other sites More sharing options...
Level42 Posted December 27, 2014 Share Posted December 27, 2014 I've always been baffled by the fact that APE And AspeQT -can- create a new disk image, but -can not- handle dragging and dropping files in that freshly created image.... Using MakeATR works fine but it's a cumbersome and slow detour. By the way if you don't have the Basic cartridge for the 800 you can always use Turbo Basic. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted December 28, 2014 Share Posted December 28, 2014 By the way if you don't have the Basic cartridge for the 800 you can always use Turbo Basic. You can't use normal Turbo-BASIC on an 800 (without Incognito). It uses RAM under the OS. There is a special version of TBASIC that does work on an 800, but you have less free RAM to use. I think it's the same TBASIC that works with Sparta 3.2. Quote Link to comment Share on other sites More sharing options...
BillC Posted December 28, 2014 Share Posted December 28, 2014 You can't use normal Turbo-BASIC on an 800 (without Incognito). It uses RAM under the OS. There is a special version of TBASIC that does work on an 800, but you have less free RAM to use. I think it's the same TBASIC that works with Sparta 3.2. According to this post there are 4 versions of TurboBASIC, I doubt if TurboBASIC 3.2Q will work with an 800 since SpartaDOS 3.2 is XL/XE only. Quote Link to comment Share on other sites More sharing options...
traindriver69 Posted December 29, 2014 Author Share Posted December 29, 2014 hi all still struggling i have tried different ways to do this but cant get it to work latest way i tried was formatting a floppy in my 1050 and creating dos on it then copying that as an atr image then adding the bas file to that and than run it through ape but once its loaded into the atari i get the ready sign if i type dos the atari locks up i am a novice at this so please any help. Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted December 29, 2014 Share Posted December 29, 2014 (edited) hi all still struggling i have tried different ways to do this but cant get it to work latest way i tried was formatting a floppy in my 1050 and creating dos on it then copying that as an atr image then adding the bas file to that and than run it through ape but once its loaded into the atari i get the ready sign if i type dos the atari locks up i am a novice at this so please any help. At the ready prompt type in the name of the BAS program RUN "D1:T*.BAS" Edited December 29, 2014 by rdea6 Quote Link to comment Share on other sites More sharing options...
traindriver69 Posted December 29, 2014 Author Share Posted December 29, 2014 Many many thanks now working Quote Link to comment Share on other sites More sharing options...
+Larry Posted December 31, 2014 Share Posted December 31, 2014 BTW Frost Basic T32Q will work with early (small) versions of MyDos such as as 3.07. I haven't tried it on an 800, but I don't see why that would make any difference. Larry Quote Link to comment Share on other sites More sharing options...
