leonk Posted March 23, 2015 Share Posted March 23, 2015 Soldered on LCD is common back in the day. You cut the ribbon when you sega nomad mod. No big deal. Just need to know the solder points. On a side note. I'm truly amazed at the amazing things coming out these days for retro gamers. If 2014 was the year of the NESRGB then 2015 is the year of the Lynx lcd mod (in terms of top technical achievement, in my book anyway). Congrats on an amazing product. My offer still stands on beta testing lcd only mod for GG! Quote Link to comment Share on other sites More sharing options...
HunterZero Posted March 23, 2015 Share Posted March 23, 2015 Is there a guide somewhere that lists the different Atari Lynx 1 and 2 motherboard revisions? Quote Link to comment Share on other sites More sharing options...
McWill Posted March 23, 2015 Share Posted March 23, 2015 Soldered on LCD is common back in the day. You cut the ribbon when you sega nomad mod. No big deal. Just need to know the solder points. On a side note. I'm truly amazed at the amazing things coming out these days for retro gamers. If 2014 was the year of the NESRGB then 2015 is the year of the Lynx lcd mod (in terms of top technical achievement, in my book anyway). Congrats on an amazing product. My offer still stands on beta testing lcd only mod for GG! No, not just cutting the ribbon. It's much more easier! You just pull off the ribbon carefully like tape, because we need the solder points on the PCB. When I have finished the quick guide for the LYNX-I, I'll post it. Quote Link to comment Share on other sites More sharing options...
McWill Posted March 23, 2015 Share Posted March 23, 2015 Is there a guide somewhere that lists the different Atari Lynx 1 and 2 motherboard revisions? Have a look here: https://atarilynxdeveloper.wordpress.com/2013/09/01/lynx-model-2-hardware-revisions/ Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted March 23, 2015 Share Posted March 23, 2015 Yes, some are soldered (or glued, I forget) on with Lynx 1. Great job getting the screen working on Lynx 1! Quote Link to comment Share on other sites More sharing options...
evilevoix Posted March 24, 2015 Share Posted March 24, 2015 Very nice, I may want to do this to my LYNX. I have 2 Model ones. 1 Quote Link to comment Share on other sites More sharing options...
Emehr Posted March 27, 2015 Share Posted March 27, 2015 I'm trying something out for my VGA connector. I'm not sure I want to cut into my Lynx case yet so I found something that just barely fits in the slot left by the Brightness dial. If this works I'll post more pics. The one problem with the design is it isn't keyed so I'll need to put a label on the adapter cable that says "This side up" or something. 6 Quote Link to comment Share on other sites More sharing options...
GadgetUK Posted March 27, 2015 Share Posted March 27, 2015 Brilliant - pin header there! I will do the same! Quote Link to comment Share on other sites More sharing options...
Emehr Posted March 27, 2015 Share Posted March 27, 2015 Success! I soldered another female pin header to two of the holes left by brightness dial to act as support for the main header sticking out of the slot. It helps hold everything together without having to use a glue. It does cause the header to angle a little bit but it isn't very noticeable. 1 Quote Link to comment Share on other sites More sharing options...
McWill Posted March 27, 2015 Share Posted March 27, 2015 I'm trying something out for my VGA connector. I'm not sure I want to cut into my Lynx case yet so I found something that just barely fits in the slot left by the Brightness dial. If this works I'll post more pics. The one problem with the design is it isn't keyed so I'll need to put a label on the adapter cable that says "This side up" or something. vga1.jpgvga2.jpgvga3.jpg Fantastic solution ! Quote Link to comment Share on other sites More sharing options...
7800fan Posted March 28, 2015 Share Posted March 28, 2015 I've thought about using such connector but I wanted one that's keyed. If I can find cheap HDMI port, Playstation video port, or something small with many pins. Quote Link to comment Share on other sites More sharing options...
Atariboy Posted March 31, 2015 Share Posted March 31, 2015 Has anyone installed a Sega controller jack to go along with the tv/out, like Candle's mod was going to have? Quote Link to comment Share on other sites More sharing options...
KevinMos3 Posted March 31, 2015 Share Posted March 31, 2015 image.jpg I couldn't help but notice your PowerPC 6116CD Macintosh. I have one just like it and love it. Mine's upgraded with 264MB RAM, 500MHz Sonnet G3 CPU, CD burner, 50GB HD, and I have both the High Performance Video card and the Capture Card. It runs Mac OS 9.1 great. Also, I love your VGA output solution. Kinda makes me regret cutting my Lynx, even though I did a very clean install. I still need to post pics of it. 1 Quote Link to comment Share on other sites More sharing options...
Emehr Posted March 31, 2015 Share Posted March 31, 2015 I couldn't help but notice your PowerPC 6116CD Macintosh. I have one just like it and love it. Mine's upgraded with 264MB RAM, 500MHz Sonnet G3 CPU, CD burner, 50GB HD, and I have both the High Performance Video card and the Capture Card. It runs Mac OS 9.1 great. Also, I love your VGA output solution. Kinda makes me regret cutting my Lynx, even though I did a very clean install. I still need to post pics of it. Thanks! What I really want to do is make a docking connector for VGA and controller system functions but there definitely isn't enough space in the Brightness slot for that. I'm considering a DB-25 port on the back of the Lynx below the cart port (if there's enough room, I'm not sure yet). Failing that, I may just go with more pin headers with some way of keying it. Yes, that's my first computer! Bought in 1996. Sounds like yours is very nicely upgraded. I didn't realize you could go that high with the RAM. I added a 250MHz Sonnet G3 upgrade to mine back in 2004 and it remained my main desktop computer until 2006. The highest OS I've put in it is 8.6 due to the limited RAM I have in it (80MB, IIRC). It shares the display/keyboard/mouse with my Blue & White G3. I played a lot of games and learned C programming on that Mac so it's a keeper. I boot it up every now and then. It's the only PowerPC Mac in my collection with its own distinct startup chime. Quote Link to comment Share on other sites More sharing options...
mqark Posted April 2, 2015 Share Posted April 2, 2015 @McWill Is there any chance you can show us your prototype GameGear mod? [i know this is an Atari forum...] I'm thrilled to mod my Lynx, but the GameGear could really do with it too. Best, Mark. Quote Link to comment Share on other sites More sharing options...
McWill Posted April 2, 2015 Share Posted April 2, 2015 @McWill Is there any chance you can show us your prototype GameGear mod? [i know this is an Atari forum...] I'm thrilled to mod my Lynx, but the GameGear could really do with it too. Best, Mark. Hi Mark, for the tests at present it is the same board as the LYNX mod. But the firmware isn't the same. But there will be a lot of changes of the PCB design, cause of the holes for the screws etc. When I've finished the GG or NOMAD mod PCB, I'll make an update. All the tests (LYNX, GG, NOMAD) take a lot of time! But I also will make a video of all when I've finished 5 Quote Link to comment Share on other sites More sharing options...
jbserra Posted April 2, 2015 Share Posted April 2, 2015 Payment sent. I came to this site only a few months ago for some ROMs to set up an emulator and play an old Lynx game I coded and now I'm re-addicted. Can't wait for the multi-cart! Amazing what you guys are putting together for this system. Thanks McWill! Quote Link to comment Share on other sites More sharing options...
7800fan Posted April 3, 2015 Share Posted April 3, 2015 Mah poor wallet!!! I have 2 Game Gears (one single ASIC and one twin) that could use a new LCD. Both have been recapped but the game still looks shit on it. Old LCD doesn't look as good when you compare to modern LCD like those in 3DS and cell phones. (I also have Majesco GG, it looks slightly better and it will remain stock) I also might do another LCD Lynx mod. Sooooo..... no sushi for about 2 months? I will miss that nice spicy calamari sushi. Quote Link to comment Share on other sites More sharing options...
MIV Posted April 4, 2015 Share Posted April 4, 2015 @McWill Question about the Nomad mod: will this connect by tapping into the composite out port, as the present LCD mods do now, OR will connect a different way? Quote Link to comment Share on other sites More sharing options...
leonk Posted April 4, 2015 Share Posted April 4, 2015 Re Nomad mod: I did composite mod on mine using new 3.5" LED LCD and new power inverter and it's awesome. Too bad gamegear doesn't have composite out. So got to wait. I know of at least 10 customers of mine that would want GG lcd / no rgb port. Quote Link to comment Share on other sites More sharing options...
McWill Posted April 4, 2015 Share Posted April 4, 2015 @McWill Question about the Nomad mod: will this connect by tapping into the composite out port, as the present LCD mods do now, OR will connect a different way? I prefer digital, not analog video. The old display has digital data lines. So you have a better control of each pixel on the LCD, but you have to solder some more wires. 1 Quote Link to comment Share on other sites More sharing options...
MIV Posted April 5, 2015 Share Posted April 5, 2015 I prefer digital, not analog video. The old display has digital data lines. So you have a better control of each pixel on the LCD, but you have to solder some more wires. Excellent! I was hoping\expecting you were going say that. You're going to have to make a lot of these, as I also have a LYNX, GG, and more than 1 Nomad... Quote Link to comment Share on other sites More sharing options...
7800fan Posted April 6, 2015 Share Posted April 6, 2015 Just a crazy idea. New LCD for Microvision!!! Be able to play it in the dark! Microvision LCD is stupidly simple compared to Lynx and GG LCD. 16 rows and 16 columns all directly controlled so it is possible to tap into all 32 lines, compute the image, and feed it into new LCD. Maybe even with variable color (ie instead of black squares on white, have white on black or other color combination) I'll take the GG LCD first when it's out. The RGB mod out there does not handle 2 different sizes gracefully and when fed to monitor (or with new LCD), Game Gear games ends up shrunk while SMS retains full size. I've asked, the creator of RGB board admitted there's not enough processing power left in his FPGA to manually resize GG images to eliminate black borders. Quote Link to comment Share on other sites More sharing options...
Michael David Morsette Posted April 6, 2015 Share Posted April 6, 2015 You know I would actually love a microvision LCD replacement. I have been so frustrated over the failing screens on the microvision, and it is nearly impossible to find a screen that isn't failing. An original microvision and a modded one.... That would be perfect. Quote Link to comment Share on other sites More sharing options...
Serblander Posted April 8, 2015 Share Posted April 8, 2015 Ok, i just had my Lynx II modded with this and i have found a pretty big problem that we noticed at last night's ComLynx event. When I hooked this up to all my other Lynx's for playing Checkered Flag, Slime World, etc, it made all the other units look like utter crap! I mean EVERYONE was fighting over wanting to use this instead of the 'classic' Lynx screens! But seriously, it looks like i have to mod my other Lynx's in due time otherwise when i take them to EB Expo, PAX Aus, etc, there's going to be a brawl to see who ends up with the LCD piece On another note, we hooked up McWill's VGA mod to the projector and played on that as well, and WOW! What a great picture (especially with California Games)! You really have outdone yourself mate Unfortunately, the pics do not do this justice - you have to see it for yourself (HIGHLY RECOMMENDED)! I just posted up some pics from last night's ComLynx Party here: http://atariage.com/forums/topic/237081-comlynx-party-night/ with pics of it on the projector as well as Lynx II comparisons and a close of the gorgeous & vivid looking LCD screen from 8-P Slime World 4 Quote Link to comment Share on other sites More sharing options...
