McWill Posted May 5, 2020 Share Posted May 5, 2020 On 4/23/2020 at 9:15 PM, marcelhartman said: I installed a new screen to my Lynx I with a C104193-001 rev.B board. Check all the wiring and seems to be fine, but i got a static screen and you can here the game playing (not my actual image, just an example) Strangly enough i found a topic that had to do with the TPR bridge on the MCWill board and soldered the bridge. The screen turn on fine and seems to be working. But... the picture is upsidedown.... ?Does anybody got a clue what went wrong? Please check if you've installed a LYNX-I mod kit! I guess you used a LYNX-II mod kit. The firmware is different ? Quote Link to comment Share on other sites More sharing options...
Sarigane Posted May 11, 2020 Share Posted May 11, 2020 On 5/5/2020 at 10:28 AM, McWill said: Please check if you've installed a LYNX-I mod kit! I guess you used a LYNX-II mod kit. The firmware is different ? Hello McWill, I have exactly the same issue, I bought a Lynx II screen and as my Lynx II didn't manage to get the proper voltage for the screen, I decided to put it in my Lynx I... Now I also have an upside down image. And I just found out your answer... too late I guess ! Is it possible to make our screen work without having to reinstall it upside down ? Thanks for your precious help ! Quote Link to comment Share on other sites More sharing options...
McWill Posted August 26, 2020 Share Posted August 26, 2020 On 5/11/2020 at 11:24 PM, Sarigane said: Hello McWill, I have exactly the same issue, I bought a Lynx II screen and as my Lynx II didn't manage to get the proper voltage for the screen, I decided to put it in my Lynx I... Now I also have an upside down image. And I just found out your answer... too late I guess ! Is it possible to make our screen work without having to reinstall it upside down ? Thanks for your precious help ! The LYNX-I mod kits are only for the LYNX-I and the LYNX-II mod kits are only for the LYNX-II ? You can see white stickers on the PCB and LCD ribbon of the LYNX-I mod kit. Otherwise it is a LYNX-II mod kit! Quote Link to comment Share on other sites More sharing options...
md66pt Posted April 18, 2022 Share Posted April 18, 2022 Hi guys, I got a Lynx I from eBay for spares and repair, with a damaged McWill Kit. On the LCD board is missing the voltage regulator, but no problem, I have spares. But a big problem is one missing cap right beside of the regulator near the connector for the ribbon cable. Anyone knows the correct capacity? And even a bigger problem, is that the part below the regulator is shorted but I can not find anything if I search for "BOXAA" as is printed on it. Would be great if anyone could help me, so I can repair the board hopefully. Maybe if McWill is reading this?? Two photos attached. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
McWill Posted September 4, 2022 Share Posted September 4, 2022 (edited) I guess someone caused a short circuit to the LYNX when this mod kits was installed. Perhaps the 5-Volt mod wasn't done. So a faulty diode damaged the LYNX mod kit. The main IC was broken, not the voltage regulator or something else. This board needs to be repaired with a new programmed main IC. Edited September 4, 2022 by McWill Quote Link to comment Share on other sites More sharing options...
Mr_Wiggles Posted September 23, 2022 Share Posted September 23, 2022 Hello! Just picked up a V2 Lynx II screen from Retomoding installed and no backlight you can see a faint image on the LCD. I installed a V1 that I have and it works fine in the system. I also connected a spare LCD “LQ035NC111” to the V2 board and still no backlight with the faint image. I have a 5v regulator installed the current input voltage is 4.93 if that helps. Any Ideas? Quote Link to comment Share on other sites More sharing options...
Mr_Wiggles Posted October 13, 2022 Share Posted October 13, 2022 All good. McWill bailed me out. Needed to bridge the two points marked BL. Quote Link to comment Share on other sites More sharing options...
Tzibu Posted December 5, 2022 Share Posted December 5, 2022 On 10/13/2022 at 2:43 PM, Mr_Wiggles said: All good. McWill bailed me out. Needed to bridge the two points marked BL. I have the same kind of problem. Did you solder those silver pads or the copper ones under them? Did it also fix the problem with backlight button? It doesn't work with me. mcwill2.mp4 Quote Link to comment Share on other sites More sharing options...
Tzibu Posted December 5, 2022 Share Posted December 5, 2022 2 hours ago, Tzibu said: I have the same kind of problem. Did you solder those silver pads or the copper ones under them? Did it also fix the problem with backlight button? It doesn't work with me. mcwill2.mp4 Well it seems that I had REV2.1 guide for REV3 board. Did everything that REV3 guide wanted and now it has backlight, but it's all white now. Quote Link to comment Share on other sites More sharing options...
Tzibu Posted December 5, 2022 Share Posted December 5, 2022 (edited) 1 hour ago, Tzibu said: Well it seems that I had REV2.1 guide for REV3 board. Did everything that REV3 guide wanted and now it has backlight, but it's all white now. Yeah the ribbon cable of screen was broken because of the battery "hold" screw. Changed the tft and now it works. EXCEPT! Backlight button doesn't change screen modes. mcwillli.mp4 Edited December 5, 2022 by Tzibu Quote Link to comment Share on other sites More sharing options...
Mr_Wiggles Posted December 6, 2022 Share Posted December 6, 2022 (edited) I didn’t connect the extra wire for the backlight button. Edited December 6, 2022 by Mr_Wiggles Quote Link to comment Share on other sites More sharing options...
Tzibu Posted December 7, 2022 Share Posted December 7, 2022 On 12/6/2022 at 7:52 PM, Mr_Wiggles said: I didn’t connect the extra wire for the backlight button. But don't you need that for changing the modes? Quote Link to comment Share on other sites More sharing options...
Mr_Wiggles Posted December 7, 2022 Share Posted December 7, 2022 You only need to if you want scan lines or are installing the VGA out. Quote Link to comment Share on other sites More sharing options...
McWill Posted December 19, 2022 Share Posted December 19, 2022 On 12/7/2022 at 9:41 PM, Tzibu said: But don't you need that for changing the modes? Yes, you need a wire to pad4 of the LYNX mod kit. Then you can switch between Scanlines on and off. Quick Guide_ATARI-LYNX-II_REV3_0.pdf Quote Link to comment Share on other sites More sharing options...
ErroneousHyphen Posted May 18, 2023 Share Posted May 18, 2023 Is there anywhere currently to get these for a Lynx 2? I noticed console5 is out of stock. Im located in Australia, if anyone can assist Quote Link to comment Share on other sites More sharing options...
xhul Posted May 18, 2023 Share Posted May 18, 2023 (edited) 52 minutes ago, ErroneousHyphen said: Is there anywhere currently to get these for a Lynx 2? I noticed console5 is out of stock. Im located in Australia, if anyone can assist Hello there, and welcome to the forums =] I can't answer your question, but in case you didn't know, the BennVenn IPS LCD supports VGA-out as well. This shop happens to ship it from Australia: https://k-retro.com/atari-lynx-lcd-mod-and-vga-kits/32-112-bennvenn-ips-lcd-mod-kit-lynx-2.html#/12-lcd_kit_extras-add_protection_zener_diode However, the documentation for the VGA-out wiring doesn't seem to be very accessible. I would recommend asking on the BennVenn's discord before actually purchasing one, link at the bottom of this page: https://bennvenn.myshopify.com/ Cheers. Edited May 18, 2023 by xhul Quote Link to comment Share on other sites More sharing options...
Magic Northman Posted December 4, 2023 Share Posted December 4, 2023 I bought one of McWill's LCD-kits for my LYNX II several years ago and he also installed it. Everything worked like a charm until the beginning of this month. All I get now is a screen full of pixels. I already changed the batteries and the cartridge several times - no change. Does anyone know how to contact McWill? I would like to send my LYNX II to him to have this issue fixed. Unfortunately I cannot sent him any personal messages??? Or does anyone know a possibility where to have a LYNX repaired in Germany? Quote Link to comment Share on other sites More sharing options...
