+Lee Stewart Posted January 19, 2021 Share Posted January 19, 2021 On 1/13/2021 at 3:06 PM, ralphb said: I've released version 3.1.0 of xdt99, in which I only updated xas99. Very nice, indeed! This release has obviated the necessity for my bank-addressing workarounds and I no longer need to quiet warnings. Many thanks for this release! ...lee 1 Quote Link to comment Share on other sites More sharing options...
+9640News Posted January 20, 2021 Share Posted January 20, 2021 On 1/13/2021 at 3:06 PM, ralphb said: I've released version 3.1.0 of xdt99, in which I only updated xas99. The new features, which are partially incompatible with 3.0.0, are: BANKS. To define a bank, use BANK <b>, [<addr>]. If an address is given, it sets the base address for other BANK directives without address. Again, BANK ALL starts at the lowest address after all other banks, and raises the base address. SAVES. I've reverted the "minimal" address range when using SAVE and now generate values for the entire range. For example, a SAVE >2000,>4000 yields a file of 8K. To get the previous behavior back, use the minimize option -M. AUTO. A new directive AUTO determines the program location where all auto-generated constants should be places. Omitting AUTO is an error. Auto-constants are now bank-aware, so AUTO should be placed in each bank where auto-constants are used. After AUTO, no further auto-constants must be used. BANK CROSS-CHECKS. I now disabled cross-checks by default. To enable them, use -X. MACROS. Labels should now be retained. Also, the listing now contains information about source units/macros entered and resumed, e.g. **** **** > source1.asm COPY "source2.asm" **** **** > source2.asm ... < source1.asm ... .mac r0, r1 **** **** > MAC ... < source1.asm COLORS. The output of warnings and errors now uses color. On Linux and macOS, color is on by default. Since older version of Windows don't support so-called ANSI esc sequences, it's off by default. To enable/disable color manually, use --color on/off. MISC. Some additional warnings about incorrect operand usage, and more. Ralph, Tim and I were discussing the other day about the ability to use other non TI/Geneve programs to assemble MDOS with the direction moving forward to a github repository. The biggest issue here lies in the GenPROG Linker and the linking process and the uses of the PAGES command to build the 18 x 8K segments of MDOS as a single program image file. I'm guessing there are roughly 100'ish source files creating 50 various object files that are pieced together during the linking process. I don't know the xdt99 tools that well or if you have reviewed the GenPROG package to know if there would be a workaround, or I will use the word "simpler" changes that could be done to the source to move things to an xdt99 platform for assembly and linking process to create the final image. If you have some thoughts on the matter, it would be appreciated. Beery Quote Link to comment Share on other sites More sharing options...
ralphb Posted January 20, 2021 Author Share Posted January 20, 2021 14 hours ago, BeeryMiller said: Tim and I were discussing the other day about the ability to use other non TI/Geneve programs to assemble MDOS with the direction moving forward to a github repository. The biggest issue here lies in the GenPROG Linker and the linking process and the uses of the PAGES command to build the 18 x 8K segments of MDOS as a single program image file. I'm guessing there are roughly 100'ish source files creating 50 various object files that are pieced together during the linking process. I don't know the xdt99 tools that well or if you have reviewed the GenPROG package to know if there would be a workaround, or I will use the word "simpler" changes that could be done to the source to move things to an xdt99 platform for assembly and linking process to create the final image. That would actually be very interesting to implement! But even though I do own a Geneve, I haven't done anything with it yet -- postponed that after SDD is ready. ? Assembling multi files at one is possible right now, also linking everything together to object code or binary. Not sure if the Geneve uses the same format, though. Also, chunking that into 8K segments is possible, but might need some extra handling. I don't have the GenPROG package, at least IIRC. Could you send that to me, please? Also I'd need more documentation about the actual Geneve format. I might have asked before, but are there any good sources for this? (Feel free to PM me, since this info might be offtopic.) I also do have a stuffed Geneve binder, maybe that contains file specs? Not that I could work on that immediately, but it'd be nice to switch between projects at times ... 4 Quote Link to comment Share on other sites More sharing options...
+9640News Posted January 20, 2021 Share Posted January 20, 2021 Ralph, I sent you a private message and included @InsaneMultitasker on the message as well along with MDOS 6.50 source and where you can find all the information on the GenPROG package. It will be some good bedtime reading <grin>. Beery 2 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted February 25, 2021 Share Posted February 25, 2021 xas99.py -R -b -L tipi.list -o tipi.bin rom.a99 > *** <2> **** - ***** Warning: Unused constants: BASESTK Took me a while to figure out BASESTK was one of my symbols, cause it's in lowercase in my source... A nice feature would be if the location of the definition could be included in the warning. Quote Link to comment Share on other sites More sharing options...
ralphb Posted March 1, 2021 Author Share Posted March 1, 2021 On 2/25/2021 at 6:47 AM, jedimatt42 said: xas99.py -R -b -L tipi.list -o tipi.bin rom.a99 > *** <2> **** - ***** Warning: Unused constants: BASESTK Took me a while to figure out BASESTK was one of my symbols, cause it's in lowercase in my source... A nice feature would be if the location of the definition could be included in the warning. Should be very possible ... I figured you could just search for the symbol, but that's more difficult if you have multiple sources. As for the case, xas99 is case-insensitive, but converts everything to uppercase internally. Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted March 2, 2021 Share Posted March 2, 2021 6 hours ago, ralphb said: Should be very possible ... I figured you could just search for the symbol, but that's more difficult if you have multiple sources. As for the case, xas99 is case-insensitive, but converts everything to uppercase internally. Yep, I should have grep -i *.a99 but was tired and making mistakes. As one does. 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted November 5, 2021 Author Share Posted November 5, 2021 (edited) I'm currently working, among other things, on improving the cycle counting. But there is one instruction where the TMS 9900 datasheet gives me headaches: BLWP. The datasheet states that BLWP needs 6 memory accesses (third column), plus 0 to 2 accesses depending on the addressing mode t of its argument (table A). Now for the case "BLWP @addr" we have 1 access for the opcode, 1 access for the target address value (i.e., LC + 2), and we have 3+3 accesses for writing to R13, R14, R15 (with read-before-write). That is a total of 8 memory accesses, instead of the listed 7. Also, we need to read two more words at the address the targets points to. These accesses cannot be right then. But if we assume that BLWP doesn't do read-before-write, we have 5 accesses, plus 2 for reading WP and LC words at the target. But is it possible that BLWP doesn't do read-before-write? (Compare to "BL @addr": 1 access for opcode, 1 for target, 1+1 for R11. Here we seem to have read-before-write.) Edited November 5, 2021 by ralphb 1 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted November 5, 2021 Share Posted November 5, 2021 Hi Ralph, for those advanced topics I recommend the "9900 Family Systems Design" book: https://ftp.whtech.com/datasheets and manuals/Datasheets - TI/9900-FamilySystemsDesign-1stEdition/9900-FamilySystemsDesign-04-Hardware Design.pdf, pages 4-89 (PDF pages 89+). Here is a photo (I was too lazy to type). As you can see, there is no read-before-write for R13-R15. 2 Quote Link to comment Share on other sites More sharing options...
ralphb Posted November 5, 2021 Author Share Posted November 5, 2021 Thanks, Michael. I didn't know that there was a more detailed datasheet available than the Microprocessor Data Manual. 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted November 5, 2021 Share Posted November 5, 2021 And here is BL, also without read-before-write. But note the comment. The Branch instructions have a pecularity: Usually, if the source operand indicates an address, the instruction processes the contents of that address. However, BL and B do not quite work this way; they branch to the address as if it were immediate. Hence, the CPU fetches the contents of that address, discards them, and does the branch. 2 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted November 5, 2021 Share Posted November 5, 2021 Just now, ralphb said: Thanks, Michael. I didn't know that there was a more detailed datasheet available than the Microprocessor Data Manual. In fact, I made heavy use of that in MAME for the microprogram implementation in the 9900 emulation. 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted November 5, 2021 Author Share Posted November 5, 2021 1 minute ago, mizapf said: And here is BL, also without read-before-write. Wow, interesting. I should really read that book you linked, as it might correct some of my reverse-engineered assumptions. 2 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted November 5, 2021 Share Posted November 5, 2021 I never noticed the cycle counting in the list file before. Are you assuming a work space in scratch pad? Quote Link to comment Share on other sites More sharing options...
ralphb Posted November 6, 2021 Author Share Posted November 6, 2021 16 hours ago, Asmusr said: I never noticed the cycle counting in the list file before. Are you assuming a work space in scratch pad? Yes, right now it uses some fixed assumptions, like workspace in scratchpad, and everything else not. I hope to improve this, but indirect addressing is a problem. I plan to offer some pragmas (special comments) where the user can supply the missing information, if they care to. Since I don't do symbolic execution, this is only useful for small snippets, obviously. 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted November 7, 2021 Author Share Posted November 7, 2021 (edited) On 11/5/2021 at 7:35 PM, mizapf said: Here is a photo (I was too lazy to type). As you can see, there is no read-before-write for R13-R15. Now that I actually peruse that document, I see one read access for the opcode, 3 write accesses for register R13-R15, and one read access for the new PC. But what about reading the new WP? Same for BL, I only see two accesses, but not the reading of the target. Am I reading those lists wrong? I'm just counting the lines where it says "Memory access". ? EDIT: I should mention that 5 memory accesses (plus reading of the argument) is consistent with my datasheet, but what is it about WP? 2 accesses for BL is also correct, but where does the reading of the target word happen? Edited November 7, 2021 by ralphb Quote Link to comment Share on other sites More sharing options...
+mizapf Posted November 7, 2021 Share Posted November 7, 2021 The operand is read during the "data derivation sequence". This is the most obvious difference to the 9995, which has an "address derivation sequence" instead. That means for BLWP @>A000: 1 Read the BLWP instruction itself 2 Do something internal DDS: 3 Internal 4 Internal 5 Read the word after BLWP (>A000) 6 Internal 7 Read the word at >A000 (new WP) 8 Internal 9 Internal 10 Write current status register to nWP+30 (R15) 11 Internal 12 Write current PC+2 to nWP+28 (R14) 13 Internal 14 Write current WP to nWP+26 (R13) 15 Internal 16 Read word at >A002 into PC 17 Internal 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted November 7, 2021 Author Share Posted November 7, 2021 Thanks for the explanation, Michael. I now found it as well, under "Symbolic". I was wondering about LI and such, but "Immediate" isn't "Symbolic". Quote Link to comment Share on other sites More sharing options...
+mizapf Posted November 7, 2021 Share Posted November 7, 2021 Yes, @>xxxx or @XXXX is "symbolic". This is what I meant above: The instructions BL and B somewhat misuse the mode by branching to that address (as if it were immediate) instead of using the contents of that address. This was improved in the 9995 where only the address is determined and not automatically read from. 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted November 7, 2021 Author Share Posted November 7, 2021 (edited) OK, that computes, so that leaves only one question: How fast are CRU accesses? In the datasheet, it's just listed as one memory access, but what does that mean on the TI 99? Are there any waitstates involved? EDIT: And any difference between reading and writing? Edited November 7, 2021 by ralphb 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted November 7, 2021 Share Posted November 7, 2021 CRU accesses should not produce wait states in the TI-99/4A console, as MEMEN* is high (not active) and the wait state logic is not active (see snippet of the schematics). The data sheet of the 9900 do not say anything about READY with respect to CRU, but the 9995 does allow for wait states in CRU access. 1 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted November 7, 2021 Share Posted November 7, 2021 This is why I always thought CRU should be checked on a particular bit as faster then many ways we see people do it with things like KSCAN Register 12 always has a copy of the CRU bits so would it not be faster to check that bit then to scan the entire keyboard? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted November 7, 2021 Share Posted November 7, 2021 Register 12 holds the CRU base address, not a copy of CRU bits. 1 Quote Link to comment Share on other sites More sharing options...
ralphb Posted November 11, 2021 Author Share Posted November 11, 2021 Here's another puzzle for STCR: The Hardware Design manual describes C decode cycle for reading CRU bits and C' cycles for shifting the result so that it is right-aligned, among other cycles. According to the manual, Quote C' = 8-C-1 if C<= 8 C' = 16-C else. Not sure if they really mean 8-C-1 or 8-(C-1), because the former might become negative. The total decode cycles for C and C' is then Quote C + C' = C + 8-C-1 = 7 if C <= 8 (or C + 8-(C-1) = 9) C + C' = C + 16-C = 16 else If we assume a register as argument, we get for the total clock cycles 22 + 4 + 2(C + C') = 26 + 2 * 16 = 58 clock cycles for C>8. This is mostly consistent with the datasheet, but that lists 60 clock cycles for C=16. For C < 8, we get 26 + 2*7 (or 2*9) = 40 (or 44), whereas the datasheet lists 42. And for C=8 we still get 40 or 44, and the datasheet lists 44. So what is the logic behind the datasheet? Or are the formulas in the Hardware Design manual incorrect? 2 Quote Link to comment Share on other sites More sharing options...
ralphb Posted November 12, 2021 Author Share Posted November 12, 2021 (edited) Also, for the shift operations SLA etc., if the jump of count != 0 in decode cycle 3 or 4 (I think it's 4)? EDIT: Actually, let me state that more precisely: If count != 0, do we have 5, 6 or 7 decode cycles, without C? Edited November 12, 2021 by ralphb Quote Link to comment Share on other sites More sharing options...
