Hey guys:
I kept my Apple IIc since I acquired it in 1984. I just recently tried to connect it (composite) to an LCD monitor that has a composite input. Strangely enough, the text screens do not show up on this monitor (reports 'no signal'), but once a graphics screen is displayed (i.e. a game, etc.) the image shows up. If I exit the game/program/whatever that has the graphics (hi-res) screen, the image disappears again.
I imagine that the signal isn't strong enough (when in text mode) to drive the composite image. Is there any way to fix this simply? Can I use one of the signals from the 15-pin video port instead? I looked up the pinout from that port but saw signals I had never heard of before. :(
Thanks,
Bob
(I also need to find a way to clean the head on my internal floppy drive - it hasn't been cleaned since 1986 or so)...
Edited by PacManPlus
https://forums.atariage.com/topic/234035-strange-issue-with-my-apple-iic/
I would have thought the only difference between the text and graphics modes, from the perspective of a display, is the color burst... strange that it would reject an image just for not having a color burst o.o;
Not strange - and that's exactly the problem. "Modern" LCD displays are less forgiving of Woz's indiscretions than older TV sets. Bob - you could try with any other composite-in device you have in your house to verify.
Sometimes it helped to feed the signal through a VCR(!) as they tended to clean up the signal somewhat. One of those amplifiers might do some normalization, but I wouldn't count on it. Your best solution will be to find a more forgiving monitor.
This sounds like a nice simple project..
A NTSC booster, with a wider Tolerance Input, and a tighter Tolerance Output.
I would guess that PAL and SECAM don't have such Issues???
MarkO
