Joeyjoejoejr Posted January 31, 2015 Share Posted January 31, 2015 (edited) This will probably only work on *nix systems, but I wanted to automate the setup of new projects and be able to build binaries and run them in Stella. https://github.com/joeyjoejoejr/cookiecutter-atari2600 It has a basic project pulled from the amazing tutorials in this forum and uses the python library http://cookiecutter.readthedocs.org/en/latest/. Assuming you have the prerequisites, python, ruby(system defaults are fine) cookiecutter, DASM and Stella you should be able to create your project, and then run the default kernel with "make run" I hope someone else who hasn't build out their own workflow might find this a useful starting place. Edited January 31, 2015 by Joeyjoejoejr 1 Quote Link to comment Share on other sites More sharing options...
