issue with "Demo IIe Interrupt Code"
Probably....
Unless you have an Apple //c or ][gs, with standard Hardware to generate an Interrupt, you will need to make sure you Target Machine has Additional Hardware to make that happen.. e.g. The MOS6522 or equivalent on the Mouse Card/Interface is used for generating Interrupts. Mocking Board, Echo ][+, John Bell MOS6522 Card, etc...
Interrupts are tricky on the Apple ][, because all the Disk ][ Access are Timing Critical, so Interrupts are Disabled while performing Disk Access.
Apple DOS 3.3 is very poor with Interrupts, ProDOS has better support for Interrupts.
vertical blank signal detection can be done by the above posted links..
MarkO
FWIW, even though interrupts are disabled for disk access, any interrupt you set up would return to normal operation after disk access is completed.
You do have to use a free running timer on the VIA (6522) instead of repeatedly setting up a one shot timer that is reset by the interrupt.
If you don't the timer will be out of sync once disk access finishes.
The original version of my music player for the Oric used a one shot timer.
@g0blinish
If you are going to work on a multi-part demo I suggest using ProDOS on the Apple. Not only is it more interrupt friendly but it's much faster. With a little creativity you could play some background music on a Mockingboard while you are loading. A song with long notes could do the trick. Also remember that ProDOS would let your demo run from a hard drive or CFFA board which would make loading multi-part demos easy to hide behind music played on a Mockingboard. A few long notes is all you need to queue up some more code.
This is definitely one area where serial disk access has an advantage over most parallel setups of the day.
The CPU doesn't have to stop everything to do disk access.
Some of the C64 demos do an impressive job of this. They have code that loads data into the drive RAM and sends it to the computer a little at a time each frame.
@g0blinish
thank you, but I don't know how to detect which DOS on .dsk image with Merlin.
or which at attached .dsk
mouse multitasking demo v1.1 24Feb14.zip
ProDOS will give a Banner at Boot Time.. DOS 3.3 and the other pre-ProDOS systems are fairly quiet..
This Disk appears to be Apple DOS 3.3.. Setup by DogCow, no less!!
With Source Code...
MarkO
Edited by MarkO
Hmm... I can't get Merlin to Boot Up in AppleWin v1.25.0.3.. Trying v1.23.0.0.. OK!!!
I guess I also need to Drag my Apple Mouse Card out and put it in one of my Test Bench Machines to try the Code posted earlier in this thread.......
MarkO
I found prodos.dsk with a label you provided.
Does makes sence to copy objective file created with Merlinassembler and run again?
here is prodos with binary and source.
maybe i am lamer and better to try another option.
prodos.zip
Edited by g0blinish
You don't have to use ProDOS, it's just many times faster than DOS 3.3 and a lot more capable.
As long as you aren't using any DOS calls and aren't using any addresses used by either DOS your code should run on both.
If Merlin works under ProDOS then it might be worth making the switch just for the speed but you certainly don't have to.
  • 2 weeks later...
FWIW, I found out slot 7 has a SYNC signal so simple hardware could generate a SYNC interrupt.
On Pin # 19..
Also, only on Slot #7, on Pin #35, COLOR REF, 3.5MHz of the Video Generator..
IIRC, the Apple ][e AUX Slot has both of these signals too....
MarkO
On Pin # 19..
MarkO
I know, I was looking at the pinouts to see why a video overlay card had to go in slot 7.
Since Slots 1-6 are NC on Pins #19 and #35, you could do some "surgery" and fix another Slot....
MarkO
MarkO
I considered hacking together a Mockingboard / Video board for slot 4 but that whole part where everyone else would have to do the same to get it to work got in the way.
I suggested a similar mod on another machine (an even shorter jumper wire) and it didn't go over well. People seem to be allergic to solder.
I would go for that!!!! The more you get on a Card, the less Slots that are used...
Design a Circuit Board in Eagle.
Post it to OSHPark, under CC x.x license.
Reduce the "Barrier to Entry" tremendously!!!!
WE ALL WIN!!!!!
Personally, I am only Allergic to the Paste, but that Chip Quik sure smells good... It even mentions, "Has a pleasant odor" on their Web Page.. ;)
Have you joined the FaceBook Group for Apple II Enthusiasts?? There is a thread on using the WIZnet 5100 Module in an Apple ][. I am looking for some SN74LS139's to make the 5100 Mapped into the Apple ][ Memory Space...
MarkO
Delorted, wrong thread.
Sorry... Too Late....
A hybrid Mockingboard/Logo board with a 9938 would be about the bee's knees, but then one would need software of course...
I suppose if one managed to dig up some NES hackers and MSX hackers it could be done, and of course I'm up to trying what I can, but I'm not a very good programmer.
The Floggings will Continue, Until Moral Improves... Or ELSE!!!!
MarkO
Edited by MarkO
WE ALL WIN!!!!!
Well, I looked up the parts needed to build a 9928 overlay board to combine video with the Apple output.
The outputs from the 9928 need amps, there are two other chips to decode the Apple video and do the overlay but the circuit is much simpler than the one from back in the day.
I need better docs on the 9938 to consider using it.
The biggest problem with Mockingboard compatibility is chip size. When you have 2 VIAs, 2 AYs, a 9928, RAM, some glue logic, amps, etc... you need a pretty large card.
If I didn't have to worry about Mockingboard compatibility, I would directly map the AYs. Having to program the AYs through the VIAs is slower and requires more code. I think just updating one AY register in my music player requires 8 extra instructions.
MarkO
If you still have a local RadioShack they might have the chips. They are under $4 on ebay, Mouser and Digikey have them... not a tough part to find really.
I just looked at that project. It looks interesting. Seems to me the IIe timing is slightly slower than the II+ on some signals.
Not sure if that has anything to do with the problem he's having or not. Without a logic analyzer it's pretty tough to know what is going on.
I know, it's insane. An AY8910 is an AY8910, but the Arcade Board's AY8910 is easier to work with than the one in the Mockingboard because it's right on the bus.
There's another option - do it BOTH ways - but that might require a LOT of glue logic.
If I were to design a board from scratch, I'd put the VDP starting at C0x0, and the PSG at C0x8 (not C0x5 like on the current design), and map read/write to the same address like the Logo board, not different addresses like the Arcade Board. That would at least gain the ability to rework it for a V9938 without breaking compatibility with a TMS9918 version. I'd argue even a GS could benefit from a V9938 card.
