ataridave Posted March 2, 2015 Share Posted March 2, 2015 I have no use for the original Atari Flashback 1, BUT I have heard rave reviews of it's 7800-styled controllers. Do these controllers work on either the Atari 2600 or the Atari 7800? Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted March 2, 2015 Share Posted March 2, 2015 The Flashback 1 system was based on the "Nintendo-on-a-Chip" that many other TV-games from the same time period used. Because it was really an NES clone internally, the Flashback 1 controllers are electrically compatible with the NES, but not any of Atari's own systems. 1 Quote Link to comment Share on other sites More sharing options...
mitchd61 Posted March 2, 2015 Share Posted March 2, 2015 I have no use for the original Atari Flashback 1, BUT I have heard rave reviews of it's 7800-styled controllers. Do these controllers work on either the Atari 2600 or the Atari 7800? I love the controllers from the Flashback 1. I found a couple on ebay that had been modified to work with the 2600/7800 and they are fantastic. You might try searching there. 1 Quote Link to comment Share on other sites More sharing options...
ataridave Posted March 2, 2015 Author Share Posted March 2, 2015 OK, thanks! Quote Link to comment Share on other sites More sharing options...
+pboland Posted March 6, 2015 Share Posted March 6, 2015 I love the controllers from the Flashback 1. I found a couple on ebay that had been modified to work with the 2600/7800 and they are fantastic. You might try searching there. I too like the Flashback 1 controllers. I'm even thinking of modding them to work with a NES. I figure it shouldn't be too hard since the two systems are basically the same. It should just be a cable swap. Quote Link to comment Share on other sites More sharing options...
Emehr Posted March 6, 2015 Share Posted March 6, 2015 Yeah, I was thinking of modding Flashback controllers for either NES or the 7800. I can't think of many NES games that would benefit from that design, though, except maybe Top Gun or other 1st/3rd person games. I wouldn't mind using the Flashback 1 case for a project too, since the actual ported games on it are junk. Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted March 6, 2015 Share Posted March 6, 2015 I'm seriously thinking of using the FB1 case as an enclosure for a Raspberry Pi. I just need to measure it to make sure it will fit, and design a bridge board so I can mount the connectors properly inside the case. As for the controllers, they're so small and light that they'd be great for traveling. You could pick up an inexpensive NES-to-USB adapter board and install it right inside the controller, which would give you a USB or MicroUSB controller cable that you can plug directly into a laptop or tablet. 1 Quote Link to comment Share on other sites More sharing options...
ave1 Posted November 13, 2018 Share Posted November 13, 2018 (edited) Today I'm replying to a very old topic for the purpose of explaining how the FB1 controller can be used on Atari 80's consoles (including the 7800). So here goes: In my 1st episode on my Wired-Up Retro YouTube channel I talked about trying to see if there could be a way that I could get Flashback 1 controllers working on the 7800. I talked about using Camerica products like the Camerica Freedom Stick and the Camerica Freedom Connection to get NES controllers working on Atari systems. Then in the 2nd episode I accomplished the task on the 7800. I used the receiver (with Genesis plugs attached) from the Camerica Freedom Stick, the Freedom Connection, an NES Fourscore, an Edladdin Seagull78 controller adapter, and a custom-made 9pin to NES controller adapter. Then in the 3rd episode I- among other things- showed how to make the 9 pin to NES controller adapter (solderless connector connected to a cut off NES controller cord). Here's episode 2 which contains the bulk of the information on this (and don't forget to subscribe to my channel, if you'd decide you like what you see): Edited November 13, 2018 by ave1 Quote Link to comment Share on other sites More sharing options...
