Igor Posted February 19, 2019 Share Posted February 19, 2019 I'll try it, I think I know why my printer is making this raft now Quote Link to comment Share on other sites More sharing options...
Greenious Posted March 4, 2019 Share Posted March 4, 2019 While waiting for this, I could use a single pcb for eproms to do some testing, anyone knows where I can get one? Quote Link to comment Share on other sites More sharing options...
Igor Posted March 5, 2019 Share Posted March 5, 2019 Karri should have blank carts for sale. I'll have 5 of the new programmer boards completed shortly, just waiting for some standoffs to arrive from China. From this lot only 1 hasn't found a new owner yet, so it will be for sale at the same price as Karri's programmer board. I'll be updating the board design slightly and then ordering a larger batch for anyone interested. I might start a new thread to gauge interest later. Quote Link to comment Share on other sites More sharing options...
zoran Posted March 5, 2019 Share Posted March 5, 2019 Karri should have blank carts for sale. I'll have 5 of the new programmer boards completed shortly, just waiting for some standoffs to arrive from China. From this lot only 1 hasn't found a new owner yet, so it will be for sale at the same price as Karri's programmer board. I'll be updating the board design slightly and then ordering a larger batch for anyone interested. I might start a new thread to gauge interest later. I want them both - the programer and the carts! What should I do? Also what will I need in order to use the programmer? Quote Link to comment Share on other sites More sharing options...
+karri Posted March 5, 2019 Author Share Posted March 5, 2019 Can you print covers by yourself? Then get a panel of carts from me. They are in the shop. The programmer is still a bit wip. To use the programmer you need a Raspberry Pi. Quote Link to comment Share on other sites More sharing options...
Igor Posted March 5, 2019 Share Posted March 5, 2019 I want them both - the programer and the carts! What should I do? Also what will I need in order to use the programmer? As Karri said, you need a Raspberry Pi. My version is a 'pi hat' which slots on top, Karri's version uses a ribbon cable. Software for reading/writing carts is here: https://bitbucket.org/atarilynx/lynx/src/cd1c78cf3a25b8e9cb22c930d6204fbe8c6bf3c6/contrib/blankcart/programmer/?at=master I can't provide blank carts or shells. Here's a comparison of the two programmer boards... Quote Link to comment Share on other sites More sharing options...
42bs Posted March 6, 2019 Share Posted March 6, 2019 Still wonder, why it is not possible to program the card from the Lynx directly? Quote Link to comment Share on other sites More sharing options...
+karri Posted March 6, 2019 Author Share Posted March 6, 2019 (edited) Some flash chips require to flip the addresses back and forth in a way that is not possible on the Lynx. void chipErase() { setDataOutputs(); writeAddrAndData(0x5555, 0xAA); writeAddrAndData(0x2AAA, 0x55); writeAddrAndData(0x5555, 0x80); writeAddrAndData(0x5555, 0xAA); writeAddrAndData(0x2AAA, 0x55); writeAddrAndData(0x5555, 0x10); delay(1000); // 100ms } How on earth do you do this on a Lynx? int byteProgram(int addr, unsigned char data) { writeAddrAndData(0x5555, 0xAA); writeAddrAndData(0x2AAA, 0x55); writeAddrAndData(0x5555, 0xA0); writeAddrAndData(addr, data); while (readByte(addr) != data) { delay20us(); writeAddrAndData(0x5555, 0xAA); writeAddrAndData(0x2AAA, 0x55); writeAddrAndData(0x5555, 0xA0); writeAddrAndData(addr, (data & 0xf0) | 0x0f); delay20us(); writeAddrAndData(0x5555, 0xAA); writeAddrAndData(0x2AAA, 0x55); writeAddrAndData(0x5555, 0xA0); writeAddrAndData(addr, (data & 0x0f) | 0xf0); } return 0; } If you wonder why I check the byte after programming and why I program it as two nybbles instead of as a byte there is a reason. Some of the flash chips just never work be programming the chip a byte at a time. But because of some reason that I don't know the chips always work with this algorithm. I could of course try to jump the address space by doing lots of dummy reads. If the chip only looks at writes to enter the programming mode then this might work on a Lynx. But I doubt it. Edited March 6, 2019 by karri Quote Link to comment Share on other sites More sharing options...
42bs Posted March 6, 2019 Share Posted March 6, 2019 We used to program the old flash card with an similar algorithm: checkFlash: jsr set5555 lda #$AA sta $fcb3 jsr set2aaa lda #$55 sta $fcb3 jsr set5555 lda #$90 sta $fcb3 ldy #250 ldx #0 .4 dex bne .4 dey bne .4 lda #0 jsr SelectBlock lda $fcb2 pha lda $fcb2 jsr PrintHex pla jsr PrintHex rts set2aaa:: lda #10 jsr SelectBlock ldx #0 ldy #2 .0 lda $fcb2 dex bne .0 dey bne .0 ldx #170 .1 lda $fcb2 dex bne .1 rts set5555:: lda #21 jsr SelectBlock ldx #0 .0 lda $fcb2 dex bne .0 ldx #85 .1 lda $fcb2 dex bne .1 rts But I agree, it will take a lot of time to select the different addresses. Does this Flash have no programming mode, where every byte written is directly programmed. The old Intel Strata flashes had this. As for the nibble writing, it might be a power problem. IIRC these flash have to generate the 12V internally. Quote Link to comment Share on other sites More sharing options...
+karri Posted March 7, 2019 Author Share Posted March 7, 2019 Unfortunately the flash chips I use today support only 1 byte at a time programming. "The SST39SF010A/020A/040 are programmed on a byte-by-byte basis." Quote Link to comment Share on other sites More sharing options...
Igor Posted March 21, 2019 Share Posted March 21, 2019 Had a friend print some of these shells for me. The results are not too bad. I'm going to tweak the model a little to see if I can get a better quality print. New 3D printer on the way too. Quote Link to comment Share on other sites More sharing options...
