First Spear Posted March 13, 2015 Share Posted March 13, 2015 This has been touched on a few times in different threads I think. I am trying to capture disc-only input from Controller #2, not confusing it with keypad input. My pseudo-code is main loop: if cont2.key = 12 gosub disccheck wait goto loop disccheck: If cont2.right <> 0 and cont2.up = 0 and cont2.down <> 0 Then gosub moverightonly etc This successfully lets a disc-push to the right only go right, it does not accept diagonals, which is what I want. However, pressing [6] on the keypad still moves to the right, which I don't want. What is the right pattern for distinguishing the input? Thanks. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted March 13, 2015 Share Posted March 13, 2015 Try this: c = cont2.button IF (c = $20)+(c = $40)+(c = $80) THEN GOTO skip_disc ' Evade keypad clicks skip_disc: 1 Quote Link to comment Share on other sites More sharing options...
freewheel Posted March 14, 2015 Share Posted March 14, 2015 (edited) This may help, or may make things more confusing. It's the actual output returned by the controller for every input, in both decimal and binary form. You can use the decimal values to check for absolute explicit presses of something. You can also use the binary values (which is what nanochess is doing above by checking if any of the 3 left-most bits are set) to either include or exclude input. I find that it really depends on exactly what you're looking for. I didn't bother with all 16 directions but they're just a combination of the various directionals. In fact if you look closely you'll see that the 4 diagonals are just ORing the cardinal directions together, and setting an extra bit. Also one thing to consider - if you exclude all diagonals, it can make the control very clunky on the real thing. Depends on the game of course. Personally I'd rather allow for them and make a "best guess" as to what they represent (DZ has a great technique for this). That way a player can still use the disc as designed (rolling around it) and not have to have pinpoint accuracy. Hopefully this looks OK: input dec bin nothing 0 00000000 s 1 00000001 e 2 00000010 n 4 00000100 w 8 00001000 nw 28 00011100 ne 22 00010110 sw 25 00011001 se 19 00010011 button0 160 10100000 button1 96 01100000 button2 192 11000000 key1 129 10000001 key2 65 01000001 key3 33 00100001 key4 130 10000010 key5 66 01000010 key6 34 00100010 key7 132 10000100 key8 68 01000100 key9 36 00100100 key10 136 10001000 key11 72 01001000 key12 40 00101000 Edited March 14, 2015 by freeweed 3 Quote Link to comment Share on other sites More sharing options...
intvnut Posted March 14, 2015 Share Posted March 14, 2015 (edited) Try this: c = cont2.button IF (c = $20)+(c = $40)+(c = $80) THEN GOTO skip_disc ' Evade keypad clicks skip_disc: This slick trick, if I did it right, may be quite a bit faster: . c = cont2.button + $100 IF (c AND (c-1)) = $100 THEN GOTO skip_disc ' Avoid keypad clicks . This trick relies on a bit-fiddling trick I learned from K & R's C book: The expression (x AND (x - 1)) clears the rightmost set bit. So what this trick does is the following: Add $100 to the cont2.button value. If cont2.button has any bits set of its own, they're all below $100. Clear the rightmost set bit. One of three things happens: If cont2.button had exactly one set bit (ie. was $20, $40, or $80), then this will clear that bit, leaving $100 as the result. If cont2.button has no bits set, it'll clear $100 to 0. If cont2.button has multiple bits set, it'll clear the rightmost of those bits, leaving a value other than $100 as the result Test the result to see if it's $100. The only case that would give $100 is when cont2.button returned $20, $40 or $80 Just a quick eyeball of the generated code suggests a ~2✕ speedup, in part due the costly generation of 0 / -1 for the equals comparisons. (99 cycles vs. 180, if I counted correctly. The actual comparison math is about 3✕ as fast (40 cycles vs. 123), but the other code around it doesn't speed up.) Edited March 15, 2015 by intvnut 3 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted March 14, 2015 Share Posted March 14, 2015 This slick trick, if I did it right, may be quite a bit faster: . c = cont2.button + $100 IF (c AND (c-1)) = $100 THEN GOTO skip_disc ' Avoid keypad clicks . This trick relies on a bit-fiddling trick I learned from K & R's C book: The expression (x AND (x - 1)) clears the rightmost set bit. So what this trick does is the following: Add $100 to the cont2.button value. If cont2.button has any bits set of its own, they're all below $100. Clear the rightmost set bit. One of three things happens: If cont2.button had exactly one set bit (ie. was $20, $40, or $80), then this will clear that bit, leaving $100 as the result. If cont2.button has no bits set, it'll clear $100 to 0. If cont2.button has multiple bits set, it'll clear the rightmost of those bits, leaving a value other than $100 as the resutl Test the result to see if it's $100. The only case that would give $100 is when cont2.button returned $20, $40 or $80 Just a quick eyeball of the generated code suggests a ~2✕ speedup, in part due the costly generation of 0 / -1 for the equals comparisons. (99 cycles vs. 180, if I counted correctly. The actual comparison math is about 3✕ as fast (40 cycles vs. 123), but the other code around it doesn't speed up.) Wow! a great suggestion, I remember that trick from the IOCCC usually I don't fiddle with bits in my daily work, but for the Intellivision any cycle gained is important! I would suggest only to use #c because the normal c is only 8 bits. 2 Quote Link to comment Share on other sites More sharing options...
intvnut Posted March 14, 2015 Share Posted March 14, 2015 Wow! a great suggestion, I remember that trick from the IOCCC usually I don't fiddle with bits in my daily work, but for the Intellivision any cycle gained is important! I would suggest only to use #c because the normal c is only 8 bits. Ah, yes. I forgot about that. I suppose you could avoid using a variable entirely with this: . IF ( (cont2.button + $100) AND (cont2.button + $FF) ) = $100 THEN GOTO skip_disc . That one also shaves another 4 cycles, coming in at 95 if I counted correctly. 1 Quote Link to comment Share on other sites More sharing options...
