jeff20 Posted April 17, 2015 Share Posted April 17, 2015 (edited) I'm a complete newbie with 2600 hacks. Just for fun, I've been making my own graphics for Pepsi Invaders, but I've encountered a strange problem. I can't find the location of a specific graphic in the code! I'm using showgfx. The top bar where it shows "COKE WINS" has graphics located 0b6e - 0ba9. The problem is I cannot find the left most vertical bar that composes the left part of the letter C in COKE. I simply want to shorten the 10 line bar to a 3 line bar, but I don't see where it's located. Can anyone help me find it? EDIT: I've added the text file of the code. Again, 0b6e - 0ba9 seem to be the graphics section of focus. pepsiinvaders.txt Edited April 17, 2015 by jeff20 Quote Link to comment Share on other sites More sharing options...
jeff20 Posted April 17, 2015 Author Share Posted April 17, 2015 0b6e | XX XX | 0b6f |XXXXXXXX| 0b70 |XXXXXXXX| 0b71 |XX XX XX| 0b72 |XX XX XX| 0b73 |XX XX| 0b74 |XX XX| 0b75 |XX XX| 0b76 |XX XX| 0b77 | | 0b78 | XX XX| 0b79 | XX XX| 0b7a | XX XX| 0b7b | XX XX| 0b7c | XX XX| 0b7d | XX XX| 0b7e | XX XX| 0b7f | XX XX| 0b80 | XX XX| 0b81 | | 0b82 | XX | 0b83 | XXX | 0b84 | XXXX | 0b85 | XXXX | 0b86 | XX XX | 0b87 |XX XX | 0b88 |XX XX | 0b89 |X XX | 0b8a | XX | 0b8b | | 0b8c | XXXXXX | 0b8d |XXXXXXXX| 0b8e | XX| 0b8f | XX| 0b90 | XXXXXX | 0b91 |XX | 0b92 |XX | 0b93 |XXXXXXXX| 0b94 | XXXXXX | 0b95 | | 0b96 |XX XXX X| 0b97 |XX XXX X| 0b98 | X X X| 0b99 | X X X| 0b9a | X X X| 0b9b | X X X| 0b9c | X X X| 0b9d | X X X| 0b9e |XX XXX X| 0b9f |XX XXX X| 0ba0 | XXX X | 0ba1 | XXX X | 0ba2 | X X | 0ba3 | X X | 0ba4 | XX X| 0ba5 | XX X| 0ba6 | X X | 0ba7 | X X | 0ba8 | XXX X | 0ba9 | XXX X | 0baa | X X | 0bab |X XXXXX| 0bac | X X | 0bad | X X | 0bae | X | 0baf |XXXX XX| 0bb0 |XXXXX XX| 0bb1 |X X X X| 0bb2 | XX X | 0bb3 |X X X| 0bb4 |XXX X | 0bb5 |X X X X| 0bb6 | XXX | At 0b96 the letters for COKE begin, but notice how the C is truncated? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted April 18, 2015 Share Posted April 18, 2015 Stella's Fixed Debug Colors mode can help, it changes this: To this: Using this color key: We can tell that COKE is drawn using the PLAYFIELD graphics. If you've gone through the newbie course, you should recall the diagram in Session 14 which shows the weird way the playfield information is drawn. Measuring out the pixels shows that the line that makes the left part of the C is the rightmost pixel of PF0. Additionally, notice how that line in the C extends upward? An educated guess says that $80 was stored in PF0 at the start of the kernel routine which draws COKE WINS. Why would they do that instead of using another table of graphics? It saves ROM and cycle time, both of which are in short supply on the Atari. To see what's going on, enter Stella's Debugger by hitting the ` key (just to the left of your 1 key). In the prompt enter the command trapwrite PF0 then exit. The debugger mode screen will briefly go away then come back. The Disassembly view in the bottom right will be positioned just after the write to PF0, so you might have to scroll it back a little bit to see the code where you'll see LDA #$80 followed by STA PF0 at address $F97F. Also note how the display in the top-left is black & white - that means the current screen hasn't been drawn yet. Look closer and you'll notice a white square in the top-left of the B&W image. That's where the electron beam of the TV is currently at. If you start to hit the STEP button(top-right corner) the code will execute one instruction at a time and the screen will start to be drawn: Check the list of Developer Keys in Stella's documentation to see other useful options you have. 2 Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted April 18, 2015 Share Posted April 18, 2015 Funny but I always thought of Coke Wins as more of a Pepsi ad than a Coke ad. Carry on... 1 Quote Link to comment Share on other sites More sharing options...
jeff20 Posted April 18, 2015 Author Share Posted April 18, 2015 Measuring out the pixels shows that the line that makes the left part of the C is the rightmost pixel of PF0. Additionally, notice how that line in the C extends upward? An educated guess says that $80 was stored in PF0 at the start of the kernel routine which draws COKE WINS. Why would they do that instead of using another table of graphics? It saves ROM and cycle time, both of which are in short supply on the Atari. Thanks so much for the detailed and informative response! I need to read more. I couldn't understand the ROM savings , but the cycle time makes sense. So, quick question. Just working with the binary, what code line would I change to remove that line in the C completely? Somehow I got confused because I can't make it go away. Quote Link to comment Share on other sites More sharing options...
jeff20 Posted April 18, 2015 Author Share Posted April 18, 2015 Funny but I always thought of Coke Wins as more of a Pepsi ad than a Coke ad. Carry on... Agreed! Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted April 18, 2015 Share Posted April 18, 2015 (edited) Thanks so much for the detailed and informative response! I need to read more. I couldn't understand the ROM savings , but the cycle time makes sense. So, quick question. Just working with the binary, what code line would I change to remove that line in the C completely? Somehow I got confused because I can't make it go away. No problem. The ROM savings is they only need to have 1 graphic value in ROM, vs 10 values if they'd updated it on every scanline. The change would be to make the LDA #$80 at $F97F into LDA #$00, more specifically change the $80 found at $F980 into $00. I'm not familiar with showgfx, but I gather there's a way to convert pepsiinvaders.txt back into a ROM file? That file starts at $0000 instead of $F000, so you'd change line 0980 from this: 0980 |X | to this: 0980 | | Edited April 18, 2015 by SpiceWare Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted April 18, 2015 Share Posted April 18, 2015 Consider checking out my blog series Collect if you'd like to go beyond graphic hacks. It covers in great detail the creation of a 2K Atari game. Quote Link to comment Share on other sites More sharing options...
jeff20 Posted April 18, 2015 Author Share Posted April 18, 2015 (edited) Will do! I'm working my way up to that. Big fan of your work! BTW, has anyone ever created an annotation of Atari program codes (like a detailed annotation of Space Invaders, for example)? I'm easing my way into this, and it would be helpful to figure out one little variation at a time such as the changing the timer of this game from 3 to 1 minute or changing the colors. Just wondering. I'm content with the solution to this mystery though. Edited April 19, 2015 by jeff20 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted April 19, 2015 Share Posted April 19, 2015 You can find some over at http://www.qotile.net/minidig/ Quote Link to comment Share on other sites More sharing options...
jeff20 Posted May 9, 2015 Author Share Posted May 9, 2015 You can find some over at http://www.qotile.net/minidig/ Ok, I've been studying and learned a lot in the last few weeks. I'm so glad for these resources. I hate to be a bother again, but I've run into another murky area: the player's cannon. It seems to be stuck in some kind of multicolor mode. How do I escape/affect that? I'm also confused by the cannon's destruction animation. It appears to be two frames, but I can't find the graphics anywhere in the code. I've looked at several Space Invader hacks, and I noticed none seem to change these graphics. Did I just not look hard enough? Or are they stored differently than the other graphics? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted May 9, 2015 Share Posted May 9, 2015 Code at $F256 draws and colors the cannon. Player's color table is located at F9E9. Destruction graphics are drawn using both players. There's 2 images at FC14 and FC1E that are alternated for each player so that the colors of the pixels keep changing. Space Invaders has concurrent 2-player game variations so most hacks won't use both players to draw a single ship's death sequence. Quote Link to comment Share on other sites More sharing options...
jeff20 Posted May 9, 2015 Author Share Posted May 9, 2015 Code at $F256 draws and colors the cannon. Player's color table is located at F9E9. Destruction graphics are drawn using both players. There's 2 images at FC14 and FC1E that are alternated for each player so that the colors of the pixels keep changing. Space Invaders has concurrent 2-player game variations so most hacks won't use both players to draw a single ship's death sequence. Is that Space Invaders or Pepsi Invaders code? Also, I'm using showgfx. WOuld that make the cannon $0257? Sorry I'm a slow learner. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted May 9, 2015 Share Posted May 9, 2015 Pepsi Invaders code. $F256 is programming code, not graphics - don't change that. Color data is at F9E9, or so you'd change the values in your file starting at 09e9. Likewise for the destroyed cannon graphics - drop the leading F for 0c14 and 0c1e. The non-destroyed cannon graphics are at FC0A, or 0c0a. Quote Link to comment Share on other sites More sharing options...
jeff20 Posted June 10, 2015 Author Share Posted June 10, 2015 Grrr. I can't seem to find the "border" color. That is, how can I change the red bars to blue? Are the top red bar and bottom red bar handled separately? Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted November 28, 2015 Share Posted November 28, 2015 Separate...and slightly different (because the top border changes color from right to left to "hide" the text). The color is fetched from ram location $e4/$e5 (so the colors are allowed to shift during attract). Hacking this is a little bit involved...since the same value is used to update another variable when $e5 is initialized. But if you don't mind an unchanging color, the method can go like this: First, alter the $a5 value at rom address $x280 to be $a9, then put your chosen color value (such as blue $86) into rom address $x281. ex f280: a5 e5 -> f280: a9 86 That takes care of the bottom border. What was done was to change the LDA $zeropage instruction into LDA #immediate. The first step of the top border is just as easy. Scroll down to rom address $x973 and alter it the same way: ex f973: a5 e4 -> f973: a9 86 If you run the game at this point, you'd notice that the playfield text is not hidden behind the "wins" bitmaps. You need to alter the loop instruction at rom address $x9b7 too (which is using LDX instead of LDA): ex f9b7: a6 e4 -> f9b7: a2 86 1 cycle was shaved off in the loop as a result, but it doesn't appear to affect anything. Quote Link to comment Share on other sites More sharing options...
