budz2355 Posted April 18, 2015 Share Posted April 18, 2015 Greetings, I apologize in advance if this is somewhere else on the forum already. I was using CorComp Inc. Peripherial Diagnostic Module 1985 to test a 32k memory expansion. There are two options: 1.) Memory Bit Check 2.) Memory Retention Check The result is the same however: 1 & 2.) Error found at Address >2000 Value written >2000 Value read >2040 Press "Proceed" to Continue The only difference between the two seems to be that when I try the second option their is a countdown from 20. SIZE in XB reveals the full 24k in program memory. Question: What does this mean? Is it fixable? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted April 18, 2015 Share Posted April 18, 2015 >2000 is the area in memory where XB would load Assembly routines, and is totally separate from the 24K area that is used for XB programs. It might be a bad memory chip for that space (most likely cause)--so it should be relatively easy to repair. Quote Link to comment Share on other sites More sharing options...
budz2355 Posted April 19, 2015 Author Share Posted April 19, 2015 I was hoping you would say just push function 2! Oh well I appreciate the help. I'll maybe work on it once I get my ti online... Just waiting on a couple parts, the. I can start another project. Quote Link to comment Share on other sites More sharing options...
