Dexter Posted April 22, 2015 Share Posted April 22, 2015 I’m about to buy two F18A’s, one for my “new” TI-99/4A, and one for my 65816 based homebrew computer MARC-2. As I said before, my intention is to write a few little machine language games for both systems simultaneously. So both having the same VDP, surely is a huge advantage. Even more because the F18A is becoming almost a standard in the TI community. Of course I’ve looked on Matthew’s site and on this forum, but I probably overlooked one or two things. MARC-2 has a 3.3V data bus on the CPU side, and a 5V data bus on the RAM side. In between, there is a 3.3V but 5V tolerant CPLD. (XC95288XL) My question is, can I connect the F18A to the 3.3V side? And just out of curiosity, who of you uses the F18A with another computer than the TI-99/4A? *------ Although MARC-2 is 3.3V, it’s not the definitive destination for the F18A. I’m designing a new computer, MARC-3 (My Adorable Retro Computer version 3). It’s practically almost ready, except for the actual build. The main difference is that it will be modular, that is, I’ll use a ground plane, similar to the S-100 bus, and carts for the different parts of the computer system. The second difference will be that it’s running solely on 5V. 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 22, 2015 Share Posted April 22, 2015 Matthew and I talked a lot about running it standalone, but I never got around to it. I am still waiting for one to hook up to a Beaglebone, hopefully. Quote Link to comment Share on other sites More sharing options...
Dexter Posted April 22, 2015 Author Share Posted April 22, 2015 (edited) I took a look at the specs of the beaglebone, all GPIO's are 3.3V. So you talked about that, I assume? Edited April 22, 2015 by Dexter Quote Link to comment Share on other sites More sharing options...
pnr Posted April 22, 2015 Share Posted April 22, 2015 And just out of curiosity, who of you uses the F18A with another computer than the TI-99/4A? The MiniCortex I'm designing has an F18A. The MiniCortex is a eurocard sized SBC with a 9995 CPU and roughly modeled on the Powertran Cortex (schematics). It started out as an extended version of Stuart's breadboard design for the 9995. 3 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 23, 2015 Share Posted April 23, 2015 I took a look at the specs of the beaglebone, all GPIO's are 3.3V. So you talked about that, I assume? Nope, unrelated discussions. That's my problem. Quote Link to comment Share on other sites More sharing options...
Dexter Posted April 23, 2015 Author Share Posted April 23, 2015 The MiniCortex I'm designing has an F18A. The MiniCortex is a eurocard sized SBC with a 9995 CPU and roughly modeled on the Powertran Cortex (schematics). It started out as an extended version of Stuart's breadboard design for the 9995. That looks very interesting! I hope to see more from it. Nope, unrelated discussions. That's my problem. Well, there clearly comes something good out of those "unrelated discussions" 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 23, 2015 Share Posted April 23, 2015 Mostly I'm just hoping to be able to do some semi-hardware testing, rather than build a new product. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted April 23, 2015 Share Posted April 23, 2015 The MiniCortex I'm designing has an F18A. The MiniCortex is a eurocard sized SBC with a 9995 CPU and roughly modeled on the Powertran Cortex (schematics). It started out as an extended version of Stuart's breadboard design for the 9995. Nice! Will it have some for of Basic in ROM? (I assume Powertran Cortex Basic). Also what about storage? Quote Link to comment Share on other sites More sharing options...
matthew180 Posted April 25, 2015 Share Posted April 25, 2015 The F18A buffers all input and most output (the data bus) through a 245 buffer: http://www.onsemi.com/pub_link/Collateral/MC74LCX16245-D.PDF The device has LVTTL I/O that is 5V tolerant. So in a word, yes, it will work with a 3.3V I/O system on both sides. The FPGA is 3.3V but does not have 5V tolerant I/O which is why I had to use the buffer. As for using the F18A in other systems, I use it in my 99/4A, MSX1, and CV. It has been tested in a good number of systems (a somewhat complete list is on my website somewhere.) f18a_minimal_v1.3.pdf 1 Quote Link to comment Share on other sites More sharing options...
Stuart Posted April 25, 2015 Share Posted April 25, 2015 Matthew, the version of the F18A with the longer pins - how much higher does it sit above the board? (Couldn't see a picture of that version anywhere.) Quote Link to comment Share on other sites More sharing options...
Dexter Posted April 25, 2015 Author Share Posted April 25, 2015 (edited) Please discard Edited April 25, 2015 by Dexter Quote Link to comment Share on other sites More sharing options...
Dexter Posted April 25, 2015 Author Share Posted April 25, 2015 The F18A buffers all input and most output (the data bus) through a 245 buffer: http://www.onsemi.com/pub_link/Collateral/MC74LCX16245-D.PDF The device has LVTTL I/O that is 5V tolerant. So in a word, yes, it will work with a 3.3V I/O system on both sides. The FPGA is 3.3V but does not have 5V tolerant I/O which is why I had to use the buffer. As for using the F18A in other systems, I use it in my 99/4A, MSX1, and CV. It has been tested in a good number of systems (a somewhat complete list is on my website somewhere.) Thanks for the info Matthew. According to the datasheet of the W65C816S, Input High Voltage is VDD x 0.8. So I might use a 74HCT245 on the data bus to ensure proper operation. Would you agree on that? Anyway, I ordered two F18A’s and I’m pretty excited about it. \o/ Quote Link to comment Share on other sites More sharing options...
matthew180 Posted April 25, 2015 Share Posted April 25, 2015 @Stuart: About the height of a socket or standard header. I posted a photo in the F18A thread: http://atariage.com/forums/topic/168968-f18a/page-33?do=findComment&comment=3225571 @Dexter: 5V * 0.8 = 4V. So if you are running the W65C816S with a 5V supply then the buffer I used on the F18A will not drive it's input. You need a dual-voltage level *shifter*, which TI makes a lot of. Or use a CPU that uses standard TTL I/O, in which case a logic level high is usually anything over 2V. The 74HCT245 also looks like it would work, but the only way to know it to try. Mixing logic families is also a pain. Quote Link to comment Share on other sites More sharing options...
Dexter Posted April 25, 2015 Author Share Posted April 25, 2015 You need a dual-voltage level *shifter*, which TI makes a lot of. Or use a CPU that uses standard TTL I/O, in which case a logic level high is usually anything over 2V. The 74HCT245 also looks like it would work, but the only way to know it to try. The '816 on MARC-2 runs on 3.3V, so there I should be OK, according to the LCX16245 datasheet. Do you know a dual voltage shifter, just out of interest. It probably will even work when the '816 is running on 5V, because those ratings are very conservative. I guess, somehow I'll get it to work. Mixing logic families is also a pain. Indeed, amen to that. Quote Link to comment Share on other sites More sharing options...
matthew180 Posted April 26, 2015 Share Posted April 26, 2015 http://www.ti.com/lsds/ti/interface/voltage-level-translation-products.page http://www.ti.com/lit/an/scea035a/scea035a.pdf Quote Link to comment Share on other sites More sharing options...
Dexter Posted April 26, 2015 Author Share Posted April 26, 2015 http://www.ti.com/lsds/ti/interface/voltage-level-translation-products.page http://www.ti.com/lit/an/scea035a/scea035a.pdf Thank you Matthew, very helpful info. Quote Link to comment Share on other sites More sharing options...
Dexter Posted May 22, 2015 Author Share Posted May 22, 2015 (edited) Today I finished porting Matthew's VDP routines to 6502 machine language. I used the 6502 mode of the 65816, I can tell that I'm really spoiled from the 9900. To give a little insight in two of the same routines, one for the 9900 and the other for the 6502: 9900 ********************************************************************* * * VDP Multiple Byte Write * * R0 Starting write address in VDP RAM * R1 Starting read address in CPU RAM * R2 Number of bytes to send to the VDP RAM * * R0 is modified, but can be restored with: ANDI R0,>3FFF * VMBW MOVB @R0LB,@VDPWA * Send low byte of VDP RAM write address ORI R0,>4000 * Set read/write bits 14 and 15 to write (01) MOVB R0,@VDPWA * Send high byte of VDP RAM write address VMBWLP MOVB *R1+,@VDPWD * Write byte to VDP RAM DEC R2 * Byte counter JNE VMBWLP * Check if done B *R11 *// VMBW 6502 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; ; VDP Multiple Byte Write ; ; +vmbw dst, src, num ; ; dst Starting write address in VDP RAM ; src Starting read address in CPU RAM ; num Number of bytes to send to the VDP RAM ; ; move memory down ; ; from = source start address ; to = destination start address ; size = number of bytes to move ; !macro vmbw .dst, .src, .num { lda #<.src sta from lda #>.src sta from+1 lda #<.dst sta to lda #>.dst sta to+1 lda #<.num sta sizel lda #>.num sta sizeh lda #<.dst sta port1 ; Send *lowbyte* (A7 to A0) of VRAM address lda #>.dst | $40 ; | $40 to indicate a write (x1xxxxxx) sta port1 ; Send *highbyte* (A13 to A8) of VRAM address ldy #0 ldx sizeh beq + - lda (from),y ; move a page at a time sta port0 ; Write byte to VDP RAM iny bne - inc from+1 dex bne - + ldx sizel beq + - lda (from),y ; move the remaining bytes sta port0 ; Write byte to VDP RAM iny dex bne - + } The computer is running at 8MHz without wait state, and the F18A has absolutely no problem with it. Edited May 22, 2015 by Dexter 3 Quote Link to comment Share on other sites More sharing options...
TheMole Posted May 22, 2015 Share Posted May 22, 2015 That is all kinds of awesome! Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted May 23, 2015 Share Posted May 23, 2015 Impressive! Quote Link to comment Share on other sites More sharing options...
matthew180 Posted May 26, 2015 Share Posted May 26, 2015 Very cool. Do you have a website or anything where you are documenting the build? 1 Quote Link to comment Share on other sites More sharing options...
Dexter Posted May 27, 2015 Author Share Posted May 27, 2015 I started a blog once, but then never looked at it again. I'm going to change that into sort of a description of MARC-1 and MARC-2. Quote Link to comment Share on other sites More sharing options...
Dexter Posted May 28, 2015 Author Share Posted May 28, 2015 Very cool. Do you have a website or anything where you are documenting the build? I just finished a description: MARC-2 BLOG If you want to know anything in particular, just ask. 2 Quote Link to comment Share on other sites More sharing options...
