+mizapf Posted July 8, 2015 Share Posted July 8, 2015 If displaying the score was time critical, I could set it up with a look up table. I've tried this routing, but it doesn't display anything except "00". Did I mis a byte / word conversion, again? Apart from the fact that there is an INC R5 missing in your loop, for displaying numbers I would rather go for the DIV method. If you only have two decimal digits, you get your result by a single DIV (quotient is the first digit, remainder is the second digit (after adding the offset for the 0)). Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3273500 Share on other sites More sharing options...
Dexter Posted July 8, 2015 Author Share Posted July 8, 2015 Apart from the fact that there is an INC R5 missing in your loop, for displaying numbers I would rather go for the DIV method. If you only have two decimal digits, you get your result by a single DIV (quotient is the first digit, remainder is the second digit (after adding the offset for the 0)). Well, it’s just a proof of concept, two of the above methods already work perfectly, but as you pointed out, we’re trying to keep our code as small as possible, to preserve memory. So I thought make a version with a look up table. Totally needless, just to look if it’s faster, which I’m sure it is. R5 will be incremented during gameplay, at each round, the round number will be moved to R5 and so on. I'll try to get it working, as it doesn't yet. Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3273595 Share on other sites More sharing options...
+mizapf Posted July 8, 2015 Share Posted July 8, 2015 If displaying the score was time critical, I could set it up with a look up table. shwrn1 MOVB @scco(r5),@VDPWD * Write byte to VDP RAM DEC R2 * Byte counter JNE shwrn1 * Check if done I've tried this routing, but it doesn't display anything except "00". Did I mis a byte / word conversion, again? I was referring to this location. You have to include an INC R5 before DEC R2; I assume you want to write two consecutive bytes, don't you? Or you unroll the loop: MOVB @scco(r5),@VDPWD MOVB @scco+1(r5),@VDPWD Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3273605 Share on other sites More sharing options...
Dexter Posted July 8, 2015 Author Share Posted July 8, 2015 You have to include an INC R5 before DEC R2; Thanks! That did the trick. Now it's working as intended. No, I won't keep that routine as the final one, but I'll store it for reference. The single DIV method is indeed the one that stays. Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3273616 Share on other sites More sharing options...
Asmusr Posted July 8, 2015 Share Posted July 8, 2015 If you really need to save clock cycles another option is to store the number as individual ascii digits that can be transferred directly to the VDP. This works well with a score where you usually only add (especially if you only add one), so the math is simple. The number you add can also be stored as individual digits so you can add them one by one as when you add two numbers on paper. I used this is Titanium and other games. Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3273647 Share on other sites More sharing options...
ralphb Posted July 8, 2015 Share Posted July 8, 2015 If you really need to save clock cycles ... Well, maybe one should take a step back and look at the context: How often could the score possibly be updated? I'd go for space rather than speed here. (But yes, I like the discussion about saving cycles ...) Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3273666 Share on other sites More sharing options...
Dexter Posted July 8, 2015 Author Share Posted July 8, 2015 If you really need to save clock cycles another option is to store the number as individual ascii digits that can be transferred directly to the VDP. This works well with a score where you usually only add (especially if you only add one), so the math is simple. The number you add can also be stored as individual digits so you can add them one by one as when you add two numbers on paper. I used this is Titanium and other games. Well, maybe one should take a step back and look at the context: How often could the score possibly be updated? I'd go for space rather than speed here. (But yes, I like the discussion about saving cycles ...) The discussion was hypothetical, *if* the routine were time critical, and memory usage wouldn't be an issue. This is the result: shwrn mov @rndnum,r5 * move round number into r5 ai r5,-1 * Start from 0 instead of 1 sla r5,1 * index for bytes to look up li r0,>3910 * line 8 position 15 li r2,2 * 2 bytes to transfer * part of VMBW MOVB @R0LB,@VDPWA * Send low byte of VDP RAM write address ORI R0,>4000 * Set read/write bits 14 and 15 to write (01) MOVB R0,@VDPWA * Send high byte of VDP RAM write address shwrn1 MOVB @scco(r5),@VDPWD * Write byte to VDP RAM MOVB @scco+1(r5),@VDPWD B *R11 scco byte 212,212,212,213,212,214,212,215,212,216,212,217,212,218,212,219,212,220,212,221 byte 213,212,213,213,213,214,213,215,213,216,213,217,213,218,213,219,213,220,213,221 byte 214,212,214,213,214,214,214,215,214,216,214,217,214,218,214,219,214,220,214,221 In this case the value of the character "0" is 212. 1 Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3273699 Share on other sites More sharing options...
Dexter Posted July 14, 2015 Author Share Posted July 14, 2015 Finally, I can present a real playable version!V0.81b SYSTEM REQUIREMENTS:TI-99/4A Home Computer32KiB RAM expansionOne disk driveExtended BASIC STARTING THE GAME:The game automatically starts by selecting Extended BASIC During gameplay, the game is over when pressing a wrong key, or wait for longer than 5 seconds when an input is expected. Enjoy and comment! runme.dsk 6 Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3277732 Share on other sites More sharing options...
sometimes99er Posted July 14, 2015 Share Posted July 14, 2015 Very nice. And funny how it was actually playing a tune - sort of. Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3277752 Share on other sites More sharing options...
Dexter Posted July 14, 2015 Author Share Posted July 14, 2015 (edited) Very nice. And funny how it was actually playing a tune - sort of. Thanks! During emulation, music doesn't play very accurately. Don't know why though. Edited July 14, 2015 by Dexter 1 Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3277769 Share on other sites More sharing options...
+Schmitzi Posted July 14, 2015 Share Posted July 14, 2015 Great !! And the sound works good, no problems (I use Mess)... schmiddy Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3277784 Share on other sites More sharing options...
Asmusr Posted July 14, 2015 Share Posted July 14, 2015 I scored 14. I will test it on my son tomorrow. P.S. You are excuting an illegal opcode at >A971. Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3277837 Share on other sites More sharing options...
ti99iuc Posted July 14, 2015 Share Posted July 14, 2015 very Good playable i like it ... just with numbers is easier for who have good memory with them... suggestion could be to add a choice for only colors or some different chars from numbers. also a progressive difficult level-up i'd like. for example speed up every 10 or 15 levels ? funny intro music (played on Classic99, no problem, scored 11) Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3277851 Share on other sites More sharing options...
RXB Posted July 14, 2015 Share Posted July 14, 2015 Thanks! During emulation, music doesn't play very accurately. Don't know why though. RXB (XB) LOAD program: 100 CALL EAPGM("DSK1.RUNME") Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3277923 Share on other sites More sharing options...
Tursi Posted July 15, 2015 Share Posted July 15, 2015 Very nice! I like it! Regarding the illegal opcode - you can't actually execute at odd addresses, I see the Classic99 debugger screwed up there (displaying and executing the right bytes, but not adjusting the address. But it's an actual explicitly branch and link to A971 (which will be run at A970), which contains >0000 bytes. A0A8 06A0 bl @>a971 (28) A971 A971 0000 data >0000 (10) > A973 CE8B mov R11,*R10+ It would be nice if you enabled QUIT to reset the system. You can scan for it yourself easily, or if they don't conflict with your code, just enable interrupts in your main loop with a LIMI 2/LIMI 0 sequence. On hardware it's kind of annoying to have to power off the machine to exit a program. Or provide a quit option. To scan for it yourself, you just need R12 and another register available (I use R13 here). This code is adapted from the console ROM. BL @CKQUIT somewhere convenient, it will either return or reset. CKQUIT LI R12,>0024 * Load CRU CLR R13 * column select LDCR R13,3 * set the hardware SRC R12,7 * Delay? LI 12,>0006 * CRU row to read STCR R13,8 * Fetch CRU LI R12,>1100 * match value for QUIT CZC R12,R13 * QUIT keys? JEQ DOQUIT * Matched, need to reset B *R11 * no match, go to caller DOQUIT LI R0,>83FE * clear scratchpad to prevent reset crashes ENDCL1 CLR *R0 * probably only need to clear the user interrupt DECT R0 * but this is fine CI R0,>8300 JNE ENDCL1 BLWP @>0000 * ( yeah, it's okay to leave R0 ) The "DOQUIT" loop is probably a little surprising. I do a lot of code that basically takes over scratchpad. Certain values in scratchpad can crash the OS, even on a reset with BLWP @>0000. Eventually I just started putting the above code in anything I wrote that messes with scratchpad enough to not be able to use interrupts. The one assumption in that clear loop is you have your workspace at >8300 (with LWPI), because if it's anywhere else, it will clear your R0 in the middle of the loop and eventually crash. If you have workspace elsewhere, you can just add a LWPI >8300 at DOQUIT and it's done. F18A apps can do a test similar to the above and add in the F18A reset before exiting. Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3278014 Share on other sites More sharing options...
Tursi Posted July 15, 2015 Share Posted July 15, 2015 (Oh, I got 14. ) 1 Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3278017 Share on other sites More sharing options...
Dexter Posted July 15, 2015 Author Share Posted July 15, 2015 Kind of thrilling, now that I’ve got a playable version. Great !! And the sound works good, no problems (I use Mess)... schmiddy Sound is probably hardware related, on another PC it's working OK. I scored 14. I will test it on my son tomorrow. P.S. You are excuting an illegal opcode at >A971. Hope your son likes it. I bugged my wife till she finally tried, and she surprisingly likes it very much.I’ll come back to the illegal opcode at >A971 right ahead. very Good playable i like it ... just with numbers is easier for who have good memory with them... suggestion could be to add a choice for only colors or some different chars from numbers. also a progressive difficult level-up i'd like. for example speed up every 10 or 15 levels ? funny intro music (played on Classic99, no problem, scored 11) Indeed, the numbers help, but eventually the sequence will get too long to remember. However, I could squeeze in a menu item to choose between squares and numbers. I have a game mode, to build in the game, on my to-do list, to add progressive speed build-up, like the original toy from 1978.I entered the music by hand from a YouTube video. I liked it because it only contains the four notes from the SIMON game, an A minor chord. RXB (XB) LOAD program: 100 CALL EAPGM("DSK1.RUNME") I assume you imply an improvement of the music playback? Unfortunately, it doesn’t. Very nice! I like it!Regarding the illegal opcode - you can't actually execute at odd addresses, I see the Classic99 debugger screwed up there (displaying and executing the right bytes, but not adjusting the address. But it's an actual explicitly branch and link to A971 (which will be run at A970), which contains >0000 bytes. A0A8 06A0 bl @>a971 (28) A971 A971 0000 data >0000 (10) > A973 CE8B mov R11,*R10+ It would be nice if you enabled QUIT to reset the system. You can scan for it yourself easily, or if they don't conflict with your code, just enable interrupts in your main loop with a LIMI 2/LIMI 0 sequence. On hardware it's kind of annoying to have to power off the machine to exit a program. Or provide a quit option. To scan for it yourself, you just need R12 and another register available (I use R13 here). This code is adapted from the console ROM. BL @CKQUIT somewhere convenient, it will either return or reset. CKQUIT LI R12,>0024 * Load CRU CLR R13 * column select LDCR R13,3 * set the hardware SRC R12,7 * Delay? LI 12,>0006 * CRU row to read STCR R13,8 * Fetch CRU LI R12,>1100 * match value for QUIT CZC R12,R13 * QUIT keys? JEQ DOQUIT * Matched, need to reset B *R11 * no match, go to caller DOQUIT LI R0,>83FE * clear scratchpad to prevent reset crashes ENDCL1 CLR *R0 * probably only need to clear the user interrupt DECT R0 * but this is fine CI R0,>8300 JNE ENDCL1 BLWP @>0000 * ( yeah, it's okay to leave R0 ) The "DOQUIT" loop is probably a little surprising. I do a lot of code that basically takes over scratchpad. Certain values in scratchpad can crash the OS, even on a reset with BLWP @>0000. Eventually I just started putting the above code in anything I wrote that messes with scratchpad enough to not be able to use interrupts. The one assumption in that clear loop is you have your workspace at >8300 (with LWPI), because if it's anywhere else, it will clear your R0 in the middle of the loop and eventually crash. If you have workspace elsewhere, you can just add a LWPI >8300 at DOQUIT and it's done.F18A apps can do a test similar to the above and add in the F18A reset before exiting. It seems that I branched to odd an address. In front of that address there were “byte” pseudo commands, and naturally, there was an odd amount of them. I placed an “even” opcode after them, which resolved the problem. I also neglected to place an “aorg >a000”, which isn’t mandatory, but I did it now anyway. A QUIT option is on my to-do list. However, you’re suggesting for checking CTRL=. Either way, I saved the routine in my archive. (Oh, I got 14. ) My hi-score is 13. Wow, such bad, many improve! -------- To-do: Add 1978 mode (progressinve) Add blind mode Add silent mode Add reverse mode Add normal mode Add different speeds Implement squares instead of numbers Add help screen Add quit option providing a nice user manual in PDF format Eventually the menu could look like this: PRESS B TO BEGIN GAME PRESS M FOR MODE: XXXXXXX NORMAL / 1978 / BLIND / SILENT / REVERSE PRESS S FOR SPEED: XXXXXX SLOW / MEDIUM / FAST / INSANE PRESS A FOR APPEARANCE: XXXXXXX SQUARES / NUMBERS PRESS H HELP PRESS Q TO QUIT But first I’ll clean up the code so far, now I know what is meant by that! Then I’ll see what I can implement from the to-do list.Thanks to all so far. 3 Quote Link to comment https://forums.atariage.com/topic/237815-simon-game-in-assembly-language/page/4/#findComment-3278577 Share on other sites More sharing options...
