tschak909 Posted May 6, 2015 Author Share Posted May 6, 2015 Yup. I am working from memory access breakpoints (especially reads) in the debugger, and tracing back from that. So far it's helping get the variables documented. again, don't think of it as byte code for an imaginary processor, bit rather as a terminal emulator, processing escape sequences.... Quote Link to comment Share on other sites More sharing options...
JamesD Posted May 6, 2015 Share Posted May 6, 2015 My music player supports embedded commands in the music that are called via table. No reason the data couldn't have the same sort of thing. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 6, 2015 Author Share Posted May 6, 2015 Hopefully, once I map out the zero page locations (which comprise the entirety of program state, minus the LMS, PMBASE, and CHBASE regions of ram), I'll have a good idea of the data area at the end of the ROM (which is at least two or more tables), and can then trace the memory accesses back into the main parts of the program. -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 6, 2015 Author Share Posted May 6, 2015 It's common in the edu cart to use the X register as the primary parameter for a subroutine call, such as this one, which does a 16-bit increment: where X in this case is the least significant byte to increment. X will increment, and if M = $FF, then X+1 will also increment. lBC47 ; Callers: B855 lBBDA BC15 B8C1 BC7B BC82 inc $00,x ; BC47: F6 00 bne lBC4D ; BC49: D0 02 inc $01,x ; BC4B: F6 01 -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 6, 2015 Author Share Posted May 6, 2015 There are two sets of color setting code present: lBCC7 ; Callers: B906 B970 B936 lda $99 ; BCC7: A5 99 sta COLPF2 ; BCC9: 8D 18 D0 lda $9A ; BCCC: A5 9A sta COLBK ; BCCE: 8D 1A D0 lda $9B ; BCD1: A5 9B sta COLPM0 ; BCD3: 8D 12 D0 sta COLPM1 ; BCD6: 8D 13 D0 sta COLPM2 ; BCD9: 8D 14 D0 sta COLPM3 ; BCDC: 8D 15 D0 lda $BD72 ; BCDF: AD 72 BD sta COLPF1 ; BCE2: 8D 17 D0 uBCE5 ; Callers: -c BCE5 rts ; BCE5: 60 This would put $99, $9A, and $9B to set the color registers. $BD72 is $0A, which given COLPF1, would be the default text intensity. I'm going to guess this is the standard color setting routine. But wait, there's more... in BC76 we find: lBC76 ; Callers: lB8ED lB939 B958 B8E5 pha ; BC76: 48 txa ; BC77: 8A pha ; BC78: 48 ldx #$92 ; BC79: A2 92 jsr lBC47 ; BC7B: 20 47 BC bne lBCC3 ; BC7E: D0 43 ldx #$94 ; BC80: A2 94 jsr lBC47 ; BC82: 20 47 BC bne lBCC3 ; BC85: D0 3C lda #$FE ; BC87: A9 FE sta $94 ; BC89: 85 94 lda #$FF ; BC8B: A9 FF sta $95 ; BC8D: 85 95 lda $96 ; BC8F: A5 96 clc ; BC91: 18 adc #$33 ; BC92: 69 33 sta $96 ; BC94: 85 96 and #$F7 ; BC96: 29 F7 sta COLPF2 ; BC98: 8D 18 D0 adc #$04 ; BC9B: 69 04 and #$F7 ; BC9D: 29 F7 sta COLPF1 ; BC9F: 8D 17 D0 lda $98 ; BCA2: A5 98 clc ; BCA4: 18 adc #$33 ; BCA5: 69 33 sta $98 ; BCA7: 85 98 and #$F7 ; BCA9: 29 F7 sta COLPM0 ; BCAB: 8D 12 D0 sta COLPM1 ; BCAE: 8D 13 D0 sta COLPM2 ; BCB1: 8D 14 D0 sta COLPM3 ; BCB4: 8D 15 D0 lda $97 ; BCB7: A5 97 clc ; BCB9: 18 adc #$55 ; BCBA: 69 55 sta $97 ; BCBC: 85 97 and #$F7 ; BCBE: 29 F7 sta COLBK ; BCC0: 8D 1A D0 lBCC3 ; Callers: BC7E BC85 pla ; BCC3: 68 tax ; BCC4: AA pla ; BCC5: 68 rts ; BCC6: 60 This one uses $93 to $98 (some overlap) with some ANDing involved, so I'm _really_ curious as to what this is used for..will dig in, when I get home. and just when you thought it wasn't weird enough, here's another: lBAC0 ; Callers: BABA pha ; BAC0: 48 lda $80 ; BAC1: A5 80 pha ; BAC3: 48 lda #$00 ; BAC4: A9 00 sta $80 ; BAC6: 85 80 jsr lBB70 ; BAC8: 20 70 BB pla ; BACB: 68 sta $80 ; BACC: 85 80 pla ; BACE: 68 jsr lBAD5 ; BACF: 20 D5 BA jmp lBABF ; BAD2: 4C BF BA lBAD5 ; Callers: BACF clc ; BAD5: 18 adc #$01 ; BAD6: 69 01 bpl lBAF6 ; BAD8: 10 1C adc #$06 ; BADA: 69 06 bmi lBAFF ; BADC: 30 21 tax ; BADE: AA lda $BD6C,x ; BADF: BD 6C BD bit $80 ; BAE2: 24 80 bpl lBAF7 ; BAE4: 10 11 sta COLPM0 ; BAE6: 8D 12 D0 sta COLPM1 ; BAE9: 8D 13 D0 sta COLPM2 ; BAEC: 8D 14 D0 sta COLPM3 ; BAEF: 8D 15 D0 sta $98 ; BAF2: 85 98 sta $9B ; BAF4: 85 9B lBAF6 ; Callers: BAD8 rts ; BAF6: 60 Will dig into these when I get home... Quote Link to comment Share on other sites More sharing options...
Xuel Posted May 7, 2015 Share Posted May 7, 2015 @tschak909 I took a stab at labeling the routines and data locations using dis. esmc.asm - disassembly esmc.dop - dis options file github There are several things I'm not sure about but perhaps we could refine it? 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 8, 2015 Author Share Posted May 8, 2015 Wow! Yeah, this pretty much matches up with the notes I've been gathering. I'll spend this weekend pouring over it and i'll help refine it. it's coming along _very_ nicely. -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 9, 2015 Author Share Posted May 9, 2015 @Xuel, the disassembly you have, lists BD30 as stream, and yeah, you're right really, this is the splash screen at the start of the program, and it's interpreted by the same code, really.. I'm thinking basically to input data into this part of memory, reset the cartridge, and observe the results, to test both my understanding of the code, and the resulting "encoding" The data is most definitely ASCII, an interesting one at that, notice the lone carriage returns, with no line feeds? To me, this screams that the original Dorsett system was built on one of Don Lancaster's TV Typewriter designs. The 32 columns per line, and 13 lines seem to play this out (the TV Typewriter was 32 columns by 16 rows), and it took data in ASCII format. I have yet to test, but I think it's pretty definite that flipping bit 7 of any printable character causes the "highlighter" to kick in. $00 is timing, and you'll never see one by itself. Always in pairs. I also suspect that $00 was used for the same vestigial reason as it was in other vintage TTY systems, as a NUL for pausing. This leaves the control codes to set colors... Inverse # seems to clear page inverse $ seems to cause a pause for selection. setting correct answer, still TBD. Atari hints there are also quite a few unused control codes. More to come later, as I actually test this out and see if i am right or wrong. -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 9, 2015 Author Share Posted May 9, 2015 Did anyone notice how the LMS'd screen memory dovetails with the unused portion of the set PMBASE? (the first mode 2 line's LMS address is the same as PMBASE) -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 9, 2015 Author Share Posted May 9, 2015 I'm starting a set of library routines to output a .wav file compatible with the cartridge. It's been about 20 years or so since I've written anything that constructs and writes sound buffers from scratch, so am stumbling along. It's being crammed together in just plain C, so it can be embedded into whatever. no outside dependencies, none needed. -Thom 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 10, 2015 Author Share Posted May 10, 2015 Guys, breakthrough. After roughly half a day of coding and debugging, I have the start of an encoder for making Edu system tapes. Turns out AFSK is pretty damned simple, and after a little help from Joey Z. to debug my sine routine (basically approximation errors resulting from plotting too far out past the first cycle), I was able to not only get clean mark/space tones, but I was able to concatenate the baud tones together to get a nice clean FSK modulation happening. Add the start and stop bits, and I was off to the races. I've made a little video showing the code, and demoing it off, with a message for the AtariAge community. Thank you all. Still a lot left to do, but a big break, nonetheless. -Thom 7 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 11, 2015 Author Share Posted May 11, 2015 Further work, tonight: I wanted to show the workflow of how I am using the encoding libraries I am working on. Enjoy. 5 Quote Link to comment Share on other sites More sharing options...
UNIXcoffee928 Posted May 11, 2015 Share Posted May 11, 2015 Further work, tonight: I wanted to show the workflow of how I am using the encoding libraries I am working on. Enjoy. Can't watch it... All Vimeo videos fail to work on 64 Bit Linux with Nvidia drivers, since Adobe stopped updating Flash for Linux. Can you post to YouTube? 2 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 11, 2015 Author Share Posted May 11, 2015 Can't watch it... All Vimeo videos fail to work on 64 Bit Linux with Nvidia drivers, since Adobe stopped updating Flash for Linux. Can you post to YouTube? No, I can't. You should be able to use the download link though, to get the mp4 file. -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 11, 2015 Author Share Posted May 11, 2015 No, I can't. You should be able to use the download link though, to get the mp4 file. -Thom Also, Adobe stopped supporting the Netscape Plugin version of Flash. New versions run under the Pepper API, easiest way to use that, is to use Chrome. -Thom Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 11, 2015 Share Posted May 11, 2015 Excellent work, and a nice setup for developing and testing. Quote Link to comment Share on other sites More sharing options...
luckybuck Posted May 11, 2015 Share Posted May 11, 2015 Just sitting here with my mouth wide, wide open. Breathless. Thom, after 36 years you solved it! Unbelievable! The 'Atari-X-Files' are getting smaller and smaller... Such a great work Thom! Please go ahead. Thank you so much! :-) Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 12, 2015 Author Share Posted May 12, 2015 I have now decoded the color palette. From my notes, each hex value is the character code, and the resulting codes 0x11 = Dark Red border 0x12 = Magenta border 0x13 = Red border 0x14 = Brown border 0x15 = Green border 0x16 = Blue Border 0x19 = Dark Red background 0x1a = Magenta background 0x1b = Red background 0x1c = Brown background 0x1d = Green background 0x1e = Blue Background 0x99 = Dark Red hilight 0x9a = Magenta hilight 0x9b = Red hilight 0x9c = Brown hilight 0x9d = Green hilight 0x9e = Blue hilight Weird color palette, huh? But yeah, those are all the colors I could find, and they all match regardless of what's being set, the background, border, or highlight. One thing to note, each color code causes the cursor to advance, so be sure to do any color changes while text isn't intended to be printed (e.g. before a clear screen at the bottom of a page.) This is what it looks like: (for best results, set quality to 720p/60 HD) Now? I try to decode the interactive codes. (edited to correct the 0x9x codes, they are for hilight) -Thom 7 Quote Link to comment Share on other sites More sharing options...
luckybuck Posted May 15, 2015 Share Posted May 15, 2015 Hi Thom, Maybe, there is additional info in the 2 different roms? AtariWiki V3: Atari Educational System Lesson Cassettes Atari Educational System Master Cartridge CXL4001 at Startup © Copyright Atari 1979: Dorsett 'Talk and Teach System' © Copyright 1983 by Dorsett Educational Systems, Inc.: Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 15, 2015 Author Share Posted May 15, 2015 No, the code is exactly the same, only difference is the built in stream (the title page) -Thom Quote Link to comment Share on other sites More sharing options...
luckybuck Posted May 15, 2015 Share Posted May 15, 2015 Thanks Thom for checking. Where do we have that again with other roms... Your findings are incredible good! :-))) Today, I received: Basic Psychology CX6011, just Cassette B is missing. Basic Sociology CX6005 ; just Cassette B and C are missing. Unbelievable. Quote Link to comment Share on other sites More sharing options...
+Allan Posted May 15, 2015 Share Posted May 15, 2015 Thanks Thom for checking. Where do we have that again with other roms... Your findings are incredible good! :-))) Today, I received: Basic Psychology CX6011, just Cassette B is missing. Basic Sociology CX6005 ; just Cassette B and C are missing. Unbelievable. I'm working on it. Tape B recorded poorly unlike the rest. I will try to re-record it at a louder volume and see if that helps. Allan 1 Quote Link to comment Share on other sites More sharing options...
luckybuck Posted May 15, 2015 Share Posted May 15, 2015 Just go ahead Allan, we are so close to the 100 %... Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 21, 2015 Author Share Posted May 21, 2015 An Update from my side: Now that the archaeology of the master cartridge disassembly and forensic analysis of the tape format is completed, and the encoder functions, I am currently writing up a book detailing the entire "dig", and will be releasing it to the public once complete. It will consist of three major parts: * Introduction * Disassembling the Cartridge * Forensic Analysis of the Cassette Format The focus on this particular book is very much a "post mortem" of the Atari Educational System, with the intent of the book being viewed as a proper historical text deconstructing one of the earliest examples of both multimedia and computer based training.I will then take the content of the book, and at the very least, take the reference bits and place onto AtariWiki, as this is the most logical place for it.-Thom 2 Quote Link to comment Share on other sites More sharing options...
luckybuck Posted May 21, 2015 Share Posted May 21, 2015 WOW! That is sooooooooo cool, I am really speechless. Thank you so much. Quote Link to comment Share on other sites More sharing options...
