RS232
budz2355
While all will do basic communications, I believe the TI version is more desirable because:
1) It has the HDX modification available for it. (Most important reason)
2) I've never heard of anything being incompatible with it or it causing glitches with any software. (after all it is the standard)
3) They are more redally available. (but not necessarily cheaper)
Because of the #1 answer, you will be able to keep your future upgrade options open without limitations, or added expense.
It depends. You might want to have multiple printers attached, or several printers and a modem, or two parallel printers--one black and white and the other color, or pretty much any strange configuration that needs a serial port and more than one printer--or even an HDX, a modem, and a printer--all serial.
It could be useful to directly tie two TI-99/4A machines together too. . .
Yes--it changes the CRU address from >1300 to >1500, IIRC.
Yeah, that is about the simplest hack on the planet too! Just un-solder one end of a resistor from the PCB and re-solder it down one hole. That's what I did when I installed my second RS-232. Piece of cake, even if you're a newbie to a soldering iron.
  • 2 weeks later...
I know the TI, CorComp, Myarc, Atronic, and Wiesbaden ones are. I'm not sure about the ICS or Captain's Wheel cards. On Sidecars, I think most of them were too, but I'd have to test the ones in my collection to be sure (and even I don't have all of the possible vendors represented in my collection yet).
