Crab Soul Posted May 7, 2015 Share Posted May 7, 2015 I was trying to put Koronis Rift into a disk onto a floppy, any idea why it wont let me? are there any other free softwares out there to write from PC to floppy with sio2pc? Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted May 7, 2015 Share Posted May 7, 2015 Is this 7800 to PC? You said pro system...Koronis rift has some good copy protection, so you might have to search for one that has been cracked. Atarionline.pl. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted May 7, 2015 Share Posted May 7, 2015 Prosystem is the second piece of software used in conjunction with the Atarimax SIO2PC-USB kit normal ATR to disk creation is done by loading APE then loading Prosystem from within APE if you're using a straightfoward ATR file it should work fine some (possibly obvious, sorry) questions: 1] Are you loading APE first then Prosytem from within APE? 2] Does Prosystem detect your drive? ps - i have a working version of KR that you can have if you like Quote Link to comment Share on other sites More sharing options...
Crab Soul Posted May 7, 2015 Author Share Posted May 7, 2015 Is this 7800 to PC? You said pro system...Koronis rift has some good copy protection, so you might have to search for one that has been cracked. Atarionline.pl. I already have the Atr from atarimania. Its from PC to atari 800 Quote Link to comment Share on other sites More sharing options...
Crab Soul Posted May 8, 2015 Author Share Posted May 8, 2015 Prosystem is the second piece of software used in conjunction with the Atarimax SIO2PC-USB kit normal ATR to disk creation is done by loading APE then loading Prosystem from within APE if you're using a straightfoward ATR file it should work fine some (possibly obvious, sorry) questions: 1] Are you loading APE first then Prosytem from within APE? 2] Does Prosystem detect your drive? ps - i have a working version of KR that you can have if you like Like the ATR file? or a disk? Quote Link to comment Share on other sites More sharing options...
Guest Posted May 8, 2015 Share Posted May 8, 2015 it's on an ATR compilation - will have a delve in the morning and see if i can extract it for you Quote Link to comment Share on other sites More sharing options...
russg Posted May 8, 2015 Share Posted May 8, 2015 (edited) it's on an ATR compilation - will have a delve in the morning and see if i can extract it for you You are trying to use free APE software Prosystem features. I believe that requires registered APE and a prosystem interface, not a regular sio2pc interface and free APE. I could be wrong about what you're working with. Here's a quote from www.atarimax.com: "The Atarimax Universal SIO2PC/ProSystem interface is a redesign of the classic Atari SIO2PC/APE and ProSystem interfaces, combining them into a single multi-function product." APE/Pro interfaces come in USB and RS232 serial flavors. Edited May 8, 2015 by russg Quote Link to comment Share on other sites More sharing options...
Guest Posted May 9, 2015 Share Posted May 9, 2015 i have an ATR version that is standalone - this works nicely. see attached any problems - just shoutKoronis Rift (v1).atr Quote Link to comment Share on other sites More sharing options...
