Marius Posted May 12, 2015 Share Posted May 12, 2015 Hi all, Is there a small tool that loads the sdrive (nuxx) cfg, sets the right settings from that cfg in SDRIVE and than exits to DOS again? I use a PBI harddrive, but in 99% of the cases I have a certain ATR on D2: You can setup the "built-in" boot SDRIVE (from the root) to set this atr, and then reboot, but that won't work if you boot from PBI HD. Everytime after a powercycle I have to load the SDRIVE tool and then leave back to dos. So it would be cool if there was a small tool that would set the SDRIVE and then exit. I'd put this in my autoexec.bat or startup.bat and then I would always have access to the right ATR. If it does not exist I probably have to write it myself. thanks a lot M. Quote Link to comment Share on other sites More sharing options...
