Been studying some on USB I/O protocols...
I am having some difficulty searching for threads on here today from my mobile for whatever reason, so if this has been discussed at length, I would appreciate a link to the thread.
The serial bus architecture and data packet delivery system of the USB interface is fairly simple, so my question concerns interfacing, primarily.
Could a USB port be feasibly integrated into a RAMDisk-type board for use with a USB drive?
I have been referencing the EA manual and Thierry's pages for info on CRU and PAB requirements and it seems like it should be possible to at least load FROM a USB drive into the system.
(Again, if this has been covered, apologies)
IIRC, Tursi did a USB cartridge of some sort... Linux IIRC.
I know far less about I/O protocols and interfacing than most of you on here, but I am learning.
Would it be possible to format a USB card in such a way that plugging it into a theoretical RAMDisk-type card would allow reading AND writing to and from the device?
My initial thoughts were of an rs232 piggyback connection, but with no term program running on-board the device, our current software would not know what to do with it.
Links to info would be appreciated...
https://forums.atariage.com/topic/238375-usb-io/
What I was thinking was more like a standard RAMDisk that is mapped in such a way that would expect data packets in a certain order to be passed via a USB port into physical RAM chips/addresses on the card. Basically a big "copy".
Does that make any sense?
I do not have the vocabulary yet. :)
Edited by Opry99er
https://forums.atariage.com/topic/238375-usb-io/#findComment-3238939
