walker7 Posted May 29, 2015 Share Posted May 29, 2015 Does anyone know how the RNG works on Bomb Squad? It would be interesting to know the RNG iteration algorithm, as well as how it generates 1-digit, 2-digit, and 3-digit codes for the game. Quote Link to comment https://forums.atariage.com/topic/238834-bomb-squad-rng/ Share on other sites More sharing options...
intvnut Posted May 30, 2015 Share Posted May 30, 2015 (edited) It uses the EXEC's built in pseudo-random number generator. Here's the relevant code that generates the 1 to 3 digits: . MVI G_016F, R0 ; 511A 0280 016F MVII #$0170, R4 ; 511C 02BC 0170 MOVR R0, R1 ; 511E 0081 L_511F: MVII #$000A, R0 ; 511F 02B8 000A JSR R5, X_RAND2 ; 5121 0004 0114 029E MVO@ R0, R4 ; 5124 0260 DECR R1 ; 5125 0011 BNEQ L_511F ; 5126 022C 0008 . The above loop calls the EXEC's random number generator (named X_RAND2 by my disassembler) 1 to 3 times, asking for random numbers in the range 0 - 9. The range is set by the value in R0 ($A, the number 10), initialized at location $511F. The high level algorithm of the random number generator at X_RAND2 appears to be this: Count the number of bits in the desired range (4 bits for a number 0 - 9), and generate an N-bit random number. If that N-bit number is in range, return it, otherwise try again. The routine that generates an N-bit random number looks like this: . L_167D: PSHR R5 ; 167D Save return address MOVR R0, R5 ; 167E Copy number of bits (N) to R5 BEQ L_17D4 ; 167F If N was zero, return PSHR R1 ; 1681 Save R1 PSHR R2 ; 1682 Save R2 CLRR R2 ; 1683 Clear R2. R2 will hold a mask MVI G_035E, R0 ; 1684 Get current RNG seed into R0 L_1686: SLL R0, 2 ; 1686 \_ R0 <<= 4 SLL R0, 2 ; 1687 / MOVR R0, R1 ; 1688 R1 = R0 XOR G_035E, R0 ; 1689 R0 = R0 ^ seed SWAP R1, 1 ; 168B R1 = (R1 >> | (R1 << SLL R1, 1 ; 168C R1 = R1 << 1 XORR R1, R0 ; 168D R0 = R0 ^ R1 SLL R1, 2 ; 168E R1 <<= 2 XORR R1, R0 ; 168F R0 = R0 ^ R1 RLC R0, 1 ; 1690 C = MSB of R0 MVI G_035E, R0 ; 1691 \_ R0 = (seed << 1) | C RLC R0, 1 ; 1693 / MVO R0, G_035E ; 1694 seed = R0 SETC ; 1696 \_ Shift a 1 into R2. At the end RLC R2, 1 ; 1697 / R2 has a 1 for each output bit DECR R5 ; 1698 \_ Repeat until all bits have BNEQ L_1686 ; 1699 / been generated ANDR R2, R0 ; 169B \_ Mask away unwanted bits and B L_17D2 ; 169C / and return (restoring R2 and R1) L_17D2: PULR R2 ; 17D2 Restore R2 PULR R1 ; 17D3 Restore R1 L_17D4: PULR R7 ; 17D4 Return . Ok, that RNG looks like a hot mess. What's it actually doing? It's a linear feedback shift register. If you look at all that computation involving R0 and R1, in the end only one bit is saved: bit 15 of R0 gets shifted into the carry bit by the instruction at $1690, and that bit gets shifted into the LSB of the seed by the instruction at $1693 and saved back to the seed. What does that bit contain? The code at $1686, $1687 and $1689 make bit 15 the XOR of bits 15 and 11 of the seed. The code at $1688, $168B, $168C and $168D XORs in bit 2 of the original seed The code at $168E and $168F XORs in bit 0 of the original seed This is a so-called Fibonacci realization of a 16-bit LFSR with the taps 0, 4, 13, 15. (The tap numbers are 15 minus the bit position.) This LFSR is the [16,15,13,4] polynomial in the list of maximal-sequence 16-bit LFSRs here. I've also written a C program to verify that it produces a maximal sequence. The EXEC seeds the random number generator with $3FF at bootup, and then cycles it while the EXEC is idle. So, while you're sitting there at the title screen, or the EXEC's waiting for input, it's busy calling the random number generator over and over generating random numbers used for nothing. This causes the random number generator's actual output to vary based on inputs from the humans playing the games. Note that a Galois realization of the same random number generator would have been much cheaper. In the Galois realization, you shift the seed left by one, and if C was set, you XOR in the polynomial for the RNG. This is the approach the RNG in SDK-1600 takes. They produce equivalent random number sequences, just shifted in time. (ie. it takes a different starting seed for the Galois implementation vs. the Fibonacci implementation to generate the exact same output sequence, but both generate the same sequence for the same polynomial.) Here's a Q&D version I just whipped up, with very little effort: . MVI G_035E, R0 MVII #$8805, R1 CLRR R2 DECR R2 loop: SLLC R0, 1 BNC no_xor XORR R1, R0 no_xor: SLL R2 DECR R5 BNEQ loop MVO R0, G_035E COMR R2 ANDR R2, R0 . So there ya go. And in case you wonder why I happen to know so much about LFSRs, I happened to do a project involving one back in college. (Super-high res PDF of the design here. And yes, I laid out every one of those transistors myself, except for the 'pad frame' that surrounds the design.) The generation of random numbers is too important to be left to chance. Edited May 30, 2015 by intvnut 3 Quote Link to comment https://forums.atariage.com/topic/238834-bomb-squad-rng/#findComment-3246997 Share on other sites More sharing options...
intvnut Posted June 1, 2015 Share Posted June 1, 2015 Does anyone know how the RNG works on Bomb Squad? It would be interesting to know the RNG iteration algorithm, as well as how it generates 1-digit, 2-digit, and 3-digit codes for the game. I'm just curious... did this answer your question? Quote Link to comment https://forums.atariage.com/topic/238834-bomb-squad-rng/#findComment-3248431 Share on other sites More sharing options...
walker7 Posted June 1, 2015 Author Share Posted June 1, 2015 I'm just curious... did this answer your question? Yes. 1 Quote Link to comment https://forums.atariage.com/topic/238834-bomb-squad-rng/#findComment-3248510 Share on other sites More sharing options...
