So, I picked up another C64 and drive the other. The bad news is both didn't work. The "good" news is after closer inspection I found out that my old drive, that also doesn't work, has a 1540 label on the bottom and a 1541 case label on the top. Both are that same beige color so that wasn't something I would have expected.
OK, so back to the 1541. It has a board that says revision A. The chips were manufactured in '84 and it's missing UC7. Here is a pic.
http://1drv.ms/1JiHtWL
I'm trying to repair the thing but the troubleshoot instructions don't cover one w/o the UC7. I did find some w/o UC7 but they also had resistors where UC7 should be. Mine, as you can see, has the place for resistors but no resistors.
Which version am I looking at?
https://forums.atariage.com/topic/238943-which-1541-is-this/
Given the 251968-01 ROM and the 251854 marking, it appears to be a 1541C board. Though I used to have one I have never looked at the bottom of a 1541C nor do I have one in my "collection" anymore, so I cannot speak for the validity of the bottom label, but it seems that 1540 bottom should be from the old VIC 1540 model drive. I used to have a VIC system with the 1540, but I cannot recall if it was the same color as the 1541C.
According to Zimmers:
This drive was introduced around the same time with the C128 and the 1570, to make it look like the C128 and the 1570, which was also in a white 1541-style case. The C128 was also white. This drive has an optical track 1 sensor, but it won't be used unless the jumper J3 on the board is cut.
https://forums.atariage.com/topic/238943-which-1541-is-this/#findComment-3248422
Have you asked Ray Carlsen for clarification on the drive you have? He's right there in Ethel, Washington.
Truly,
Robert Bernardo
Fresno Commodore User Group
http://www.dickestel.com/fcug.htm
July 18-19 Commodore Vegas Expo v11 2015 -
http://www.portcommodore.com/commvex
https://forums.atariage.com/topic/238943-which-1541-is-this/#findComment-3249752
No, I hadn't but I will. Thanks for the tip.
We're having a bunch of people bring their C64's to the Seattle Retro-Computing Society this month. There are some pretty smart guys that attend but I thought I would give it a shot first.
https://forums.atariage.com/topic/238943-which-1541-is-this/#findComment-3249779
