+OLD CS1 Posted June 3, 2015 Share Posted June 3, 2015 I recall a program or two which would run up the drive motor for head-cleaning purposes. I have not been able to turn one up in searches. Anyone happen to know of one or a "M-W" that I can use to do it? I would like to clean my 1571s, 1541s, and MSD-2 with a proper kit. Quote Link to comment Share on other sites More sharing options...
Rybags Posted June 3, 2015 Share Posted June 3, 2015 (edited) The best way by far is to just pull the cover off and use isopropyl alcohol on a cotton bud or lint free non-abrasive cloth. Use a cleaning floppy and it'll still have residue - the problem with leaving gunk behind is it just promotes wearing more coating off subsequent disks you use. Command to start the drive - IIRC the "I" command runs it for a few seconds, probably nowhere near enough. Not sure if a format command will work - it might be that it verifies some data early in the process. Though format, or some utility that spins as well as moving the head would be a good idea - ensures that the gunk doesn't all end up in one place on the cleaning floppy. Edited June 3, 2015 by Rybags Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 3, 2015 Author Share Posted June 3, 2015 For the 1541, the relevant part of the ROM is F9E8 AD 00 1C LDA $1C00 F9EB 29 FB AND #$FB drive motor on F9E0 8D 00 1C STA $1C00 Seems I should be able to whip up an M-W and M-E for this. The 1571 appears to be the same for 1541-compatibility. 1 Quote Link to comment Share on other sites More sharing options...
+sm3 Posted June 3, 2015 Share Posted June 3, 2015 For the 1541, the relevant part of the ROM is F9E8 AD 00 1C LDA $1C00 F9EB 29 FB AND #$FB drive motor on F9E0 8D 00 1C STA $1C00 Seems I should be able to whip up an M-W and M-E for this. The 1571 appears to be the same for 1541-compatibility. Here is a BASIC version that will spin the motor: OPEN15,8,15:PRINT#15,"M-E"+CHR$(130)+CHR$(249):CLOSE15 Found this on a website. Worked on my 1541. Don't forget to change the OPEN command to fit your drive device number. 1 Quote Link to comment Share on other sites More sharing options...
carlsson Posted June 3, 2015 Share Posted June 3, 2015 Is it enough to spin the motor with a cleaning floppy, shouldn't you move the head as well? The U1 command will attempt to read a block. Of course it will trigger error messages but I seem to remember it is possible to send further commands anyway, or at least empty the error channel all the time. Perhaps a program like this one would work? 10 open 1,8,15:open 2,8,2,"#" 12 for i=1 to 3 : rem number of passes 15 print#1,"u1:";2;0;1;0 : rem innermost track 20 input#1,e,e$,t,s : rem wait for error 25 print#1,"u1:";2;0;35;0 : rem outermost track 30 input#1,e,e$,t,s 32 next i 35 close 2:close1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 4, 2015 Author Share Posted June 4, 2015 Is it enough to spin the motor with a cleaning floppy, shouldn't you move the head as well? The U1 command will attempt to read a block. Of course it will trigger error messages but I seem to remember it is possible to send further commands anyway, or at least empty the error channel all the time. Perhaps a program like this one would work? 10 open 1,8,15:open 2,8,2,"#" 12 for i=1 to 3 : rem number of passes 15 print#1,"u1:";2;0;1;0 : rem innermost track 20 input#1,e,e$,t,s : rem wait for error 25 print#1,"u1:";2;0;35;0 : rem outermost track 30 input#1,e,e$,t,s 32 next i 35 close 2:close1 I think the problem with moving the head during is that these cleaning disks are at least a little abrasive, and moving the head has the potential to put abrasions across the normal motion of regular disks. As well, since the head essentially makes contact with and drags across the cleaning disk, moving the heads may put undue lateral stress on them and their supports. That is my hypothesis, in any case, and why I would be hesitant to try it. I welcome any comments on this thought. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 4, 2015 Author Share Posted June 4, 2015 Here is a BASIC version that will spin the motor: OPEN15,8,15:PRINT#15,"M-E"+CHR$(130)+CHR$(249) Found this on a website. Worked on my 1541. Don't forget to change the OPEN command to fit your drive device number. Interesting... that routine is: F982 AD 00 1C LDA $1C00 F985 09 04 ORA #$04 turn drive motor off F987 8D 00 1C STA $1C00 F98A A9 3C LDA $3C F98C 85 48 STA $48 F98E 60 RTS This is from Abacus Software's Anatomy of the 1541 Disk Drive. Notice how the routines are reversed from what we expect and observed behavior. Maybe an error in the book's disassembly. Quote Link to comment Share on other sites More sharing options...
+sm3 Posted June 4, 2015 Share Posted June 4, 2015 Interesting... that routine is: F982 AD 00 1C LDA $1C00 F985 09 04 ORA #$04 turn drive motor off F987 8D 00 1C STA $1C00 F98A A9 3C LDA $3C F98C 85 48 STA $48 F98E 60 RTS This is from Abacus Software's Anatomy of the 1541 Disk Drive. Notice how the routines are reversed from what we expect and observed behavior. Maybe an error in the book's disassembly. I've never really taken a look at the disassembly of this before. You can turn the motor off with: OPEN15,8,15:PRINT#15,"M-E"+CHR$(232)+CHR$(249):CLOSE15 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted June 4, 2015 Author Share Posted June 4, 2015 I've never really taken a look at the disassembly of this before. You can turn the motor off with: OPEN15,8,15:PRINT#15,"M-E"+CHR$(232)+CHR$(249):CLOSE15 heh! That is the entry point to the first routine segment I posted at $9FE8, which is marked to turn the drive motor on. Yeah, looks like a little error in the book. Thanks for the information; since I did not think the JSR would get RTSd properly or without changing something important, I was going to take out the relevant parts of the routine(s) to put in a buffer and execute from there. This is much better! Quote Link to comment Share on other sites More sharing options...
carlsson Posted June 4, 2015 Share Posted June 4, 2015 Regarding moving or not moving the head, it probably is 20 years ago I cleaned a 5.25" floppy drive the last time, although I semi-regularly use them. Back then I am reasonably sure the "recommended" program, whether it was by the disk manufacturer or a magazine, was to move the head but I totally buy what you write about abrasive material and that the head could struggle moving along the surface. I don't know what moving the head would add, unless you want to clean a bigger part of the head than what normally lies to the surface and by moving it in both directions, you get alcohol and rubbing off residue on the entire head. Quote Link to comment Share on other sites More sharing options...
Rybags Posted June 5, 2015 Share Posted June 5, 2015 I'd go for move the head. These things are noisy and sound worse than they are, most of what you hear is just the surface rubbing against the jacket. If you leave residue on the head, the job is only 1/4 done. Having crud on the head just promotes abrasion and addition of more crud. Quote Link to comment Share on other sites More sharing options...
Oge Posted June 16, 2015 Share Posted June 16, 2015 There you go: 10 REM DISK DRIVE CLEANER PROGRAM 20 REM VERSION 1.0 30 REM BY MEL MOORE 40 REM DRIVE CLEANING ROUTINE FROM 50 REM QUANTUMLINK - UPLOADED BY 55 REM HUTCH 09/21/85 60 REM MAIN PROGRAM 70 GOSUB 500 :REM PRINT INSTRUCTIONS 80 GOSUB 1000 :REM SELECT DRIVE NUMBER 90 GOSUB 2000 :REM CLEAN DRIVE 95 GOSUB 3000 :REM CONTINUE OR STOP 500 PRINT"{clear}": REM PRINT INSTRUCTIONS 505 PRINT"this program will allow you to clean your disk drives witout having" 510 PRINT"to turn off your computer." 520 PRINT 530 PRINT"please select which drive you wish to" 540 PRINT"clean then follow the instructions." 550 PRINT 560 PRINT"the drive cleaning programs will " 570 PRINT"default to a 30 second time by" 580 PRINT"pressing return at the prompt." 581 PRINT:PRINT"press any key to continue" 590 GET A$:IF A$ = "" THEN 590 700 RETURN 950 REM 960 REM 970 REM 999 REM SELECT DRIVE TO CLEAN 1000 PRINT"{clear}":PRINT"please select the drive" 1010 PRINT 1020 INPUT "you wish to clean "; CL 1030 IF CL < 8 OR CL > 9 THEN GOTO 1000 1040 RETURN 1950 REM 1960 REM 1970 REM 2000 PRINTCHR$(147)"{space*8}disk{space*2}cleaning program" 2010 PRINTCHR$(17)CHR$(17)"{space*7}{rvson}insert cleaning disk now! {rvsoff}" 2020 PRINT:PRINT"{space*5}and press {rvson}return{rvsoff} when ready!" 2030 GET A$:IF A$="" THEN 2030 2040 N=30 2050 PRINT:PRINT:PRINT"{space*9}# of seconds for cleaning (30)":INPUT N 2060 PRINTCHR$(147) 2070 PRINT"{space*7}cleaning now in effect!!" 2080 PRINT:PRINT"{space*6}{rvson}do not disturb drive now!!{rvsoff}" 2090 PRINT:PRINT:PRINT"{space*4}{rvson}the red light doesn't come on!{rvsoff}" 2100 A=TI 2110 OPEN 15,CL,15:PRINT#15,"m-w"CHR$(0)CHR$(28)CHR$(1)CHR$(244) 2120 IF TI-A<(N*60)THEN 2120 2130 PRINT#15,"m-w"CHR$(0)CHR$(28)CHR$(1)CHR$(240) 2140 CLOSE 15 2150 PRINTCHR$(147) 2160 PRINT:PRINT:PRINT"{space*5}take the cleaning diskette " 2170 PRINT:PRINT"{space*7}{rvson}out of the drive now !!!{rvsoff}" 2175 PRINT 2180 PRINT "press any key to continue" 2200 GET A$: IF A$ ="" THEN GOTO 2200 2210 RETURN 2220 REM 2230 REM 2240 REM 2250 REM 2999 REM CONTINUE OR STOP 3000 PRINT"{clear}":PRINT"do you wish to clean another" 3010 INPUT "drive (y/n)"; AG$ 3020 IF AG$ = "y" THEN GOTO 80 3030 PRINT"{clear}{white}{8}{lcase}{210}eturning to {195}ommodore {199}azette...." 3040 PRINT"{home}{black}{down*2}load"CHR$(34)"program.menu"CHR$(34)","DV"{home}";:POKE198,4 3050 POKE631,13:POKE632,82:POKE633,117:POKE634,13:END Cheers, Oge 1 Quote Link to comment Share on other sites More sharing options...
RobertB Posted June 19, 2015 Share Posted June 19, 2015 Oh, that is similar to the head-cleaning program published in Ahoy magazine. Writing from Crawley, England, Robert Bernardo Fresno Commodore User Group http://www.dickestel.com/fcug.htm July 18-19 Commodore Vegas Expo v11 2015 - http://www.portcommodore.com/commvex Quote Link to comment Share on other sites More sharing options...
+sm3 Posted June 19, 2015 Share Posted June 19, 2015 I found another means that may be of use to someone: The SAMS book "Commodore 1541 Troubleshooting & Repair Guide" has a listing for a BASIC program to assist in repairs/cleaning. It can turn the motor on/off, bump the head, move it half tracks etc.. Not that long as well. It's on page 30 (Fig. 3-1). You can download a PDF here, but it's very hard to read: http://www.bombjack.org/commodore/books.htm 1 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted June 19, 2015 Share Posted June 19, 2015 Here is a BASIC version that will spin the motor: OPEN15,8,15:PRINT#15,"M-E"+CHR$(130)+CHR$(249):CLOSE15 Found this on a website. Worked on my 1541. Don't forget to change the OPEN command to fit your drive device number. Quote Link to comment Share on other sites More sharing options...
+sm3 Posted June 19, 2015 Share Posted June 19, 2015 Right, I posted that. Did you have a question about it? Quote Link to comment Share on other sites More sharing options...
