Heaven/TQA Posted June 10, 2015 Share Posted June 10, 2015 (edited) how can I assemble the RMT player to $fc00 fex but place the code to $4000? normally I would do org $4000,$fc00 but later the ORG player points then to $4xxx? I don't want to recode the whole player like I did in the 5200 version but is there a quick way? I need to dump the player to disk with Altirra... or would presetting $d301 with $fe and an INI help? ah... I can fool Altirra exe loader with a org $4000 lda #$fe sta $d301 rts ini $4000 and then simple ORG $fc00 in player will do the job... don't try this on real hardware! ;=) Edited June 10, 2015 by Heaven/TQA Quote Link to comment Share on other sites More sharing options...
phaeron Posted June 11, 2015 Share Posted June 11, 2015 At least with MADS, you want the ORG arguments the other way. The first argument is the address for assembly, the second is the address to be emitted into the object file. Once you're past the player, you can use .adr to get the current output address to reset ORG. mads 1.9.9 build 19 (6 Mar 14) Source: org.s 1 org $2000 2 start: 3 FFFF> 2000-2002> 4C 00 + jmp * 4 5 2003 org $fc00,$4000 6 FC00 player: 7 4000-4003> E8 inx 8 FC01 4C 00 FC jmp player 9 10 FC04 player_end: 11 FC04 org .adr player_end 12 13 4004 after_player: 14 4004-4004> 00 brk 1 Quote Link to comment Share on other sites More sharing options...
