Van Posted June 16, 2015 Share Posted June 16, 2015 Hi all So in the process of a larger project, I routed a EPROM Pak with a 40 pin connector for external circuits. Much credit and insperation goes to NF6X's EPROM Pak, https://github.com/NF6X/CoCoEPROMpak. I ended up starting from scratch on the board due to the extra space needed for the 40 pin header. I dropped the connector for 26 pin ROMs, 27256 devices are easier to find for me. This EPROM/Ext board hosts a 28 pin ROM and provides jumpers to allow stand alone, manual bank switching or can be controlled externally. With a 27512 this would allow 4 16K images. The external header is laid out almost one to one with the card edge, but the two 12V and one of the GND pins (pins 1 & 2 and pin 34) are re-purposed for ROM banking control. The 40 pin header is un-buffered so take care when handling. Due to the limits of Eagle free, the buffer circuits will have to be a separate board to either be mated to the back of the EPROM/Ext Pak or connected via a short ribbon cable. I've yet to route this board so it's WIP for now. Here is the Schema; The first boards are at fab; after I get the boards and verify them I'll open the files on OSH Park. The cost runs <$40 for a run of 3. So if you just want an EPROM pak use NF6X's design it's on OSH and cheaper Yogi Quote Link to comment Share on other sites More sharing options...
Van Posted July 12, 2015 Author Share Posted July 12, 2015 Well, got the first board run back, yea! During continuity testing found a little weirdness. Some of my GND fills are not contiguous. Bad when the EPROM's GND is isolated Now the weird thing is I can't find an un-routed ratline for the GND net. Weird. Simple fix on these boards, but will re-route the design a bit to correct this. Also some minor changes to the parts selection and placement. Yogi Quote Link to comment Share on other sites More sharing options...
