TaskenLander Posted June 18, 2015 Share Posted June 18, 2015 Hi, My Dreamcast will load/play the games fine, the VMU reads the name of the game, is brand new, zero saves, yet won't save progress with the majority of the games I try. I have two VMU's and they BOTH do the same thing. TV screen says 'save unsuccessful' whenever I try. Is something wrong with my Dreamcast system then? No other problems other than this. Suggestions?? Thanks in advance! Mike Quote Link to comment Share on other sites More sharing options...
Nutsy Doodleheimer Posted June 18, 2015 Share Posted June 18, 2015 Do you have a third party jump pack? If so, they are known for corrupting the VMU. Try ejecting the hyper pack. Quote Link to comment Share on other sites More sharing options...
TaskenLander Posted June 18, 2015 Author Share Posted June 18, 2015 I thought that as well! Turned system off, removed pack then restarted system and still -- unable to save data. :-/ A few of my games DO save, though, although most DON'T. I just don't get it... Quote Link to comment Share on other sites More sharing options...
Nutsy Doodleheimer Posted June 18, 2015 Share Posted June 18, 2015 I thought that as well! Turned system off, removed pack then restarted system and still -- unable to save data. :-/ A few of my games DO save, though, although most DON'T. I just don't get it... Try spraying some canned air or electric cleaner on the controller ports. The Dreamcast is well known for shoddy controller ports. Quote Link to comment Share on other sites More sharing options...
TaskenLander Posted June 18, 2015 Author Share Posted June 18, 2015 Okay, I will give that a try. Though, should it matter, the VMU *does* read the games (title screen, etc), its just when I go to save it has trouble. Thanks, Mike Quote Link to comment Share on other sites More sharing options...
Austin Posted June 18, 2015 Share Posted June 18, 2015 1. Try the same VMU in a different controller. 2. Try popping open the VMU and take the battery out. Let it sit for a bit then put the battery in. 3. Try a different VMU. If you don't have one, buy another. They are cheap. 4. Make sure you are using games that save. No all games IIRC save, but most should have some sort of save file. Quote Link to comment Share on other sites More sharing options...
7800fan Posted June 18, 2015 Share Posted June 18, 2015 Don't need batteries although it will make annoying squeal when it's powered on via controller and the battery is low or missing. Taking it apart, you can cut one of the wire to pizeo to silence it permanently. I have not encountered problem saving. Maybe there's a bad solder or trace that is preventing the data from getting written to the flash rom chip? Worse case: you have a bad flash rom. Do you have a different VMU to test with? If it saves fine, your new one needs to be checked out. If the other VMU still won't save, get the controller checked and try a different DC system too. Quote Link to comment Share on other sites More sharing options...
TaskenLander Posted June 19, 2015 Author Share Posted June 19, 2015 Hi again, Tried both controllers, both VMU's, switched both of them out and game just WON'T save. :-( The VMU display screen READS the title of the game, etc and beeps once system turns on (does that mean anything?) but when I go to start a new file or load previous file it says 'unsuccessful'. The 'Save Menu/please wait' DID flash on for a second one of the times but quickly went away. Could it just be the batteries for some reason, like it has enough juice in them to read game title, etc but NOT save?? Does that make any sense? Thanks, Mike Quote Link to comment Share on other sites More sharing options...
Austin Posted June 19, 2015 Share Posted June 19, 2015 Two VMUs, tried in both controllers.. What game are you trying to save? It's unlikely both VMUs or both controllers are bad. Quote Link to comment Share on other sites More sharing options...
omegadot Posted June 19, 2015 Share Posted June 19, 2015 Battery should have nothing to do with it. Mine are / were always dead. I've actually never replaced one. I used a VMU for the quake 3 maze thing at the end of the game and that's it. And that was around when Q3 launched. Quote Link to comment Share on other sites More sharing options...
7800fan Posted June 20, 2015 Share Posted June 20, 2015 That leaves a possible issue with your Dreamcast system. Do you have access to another one somewhere, maybe a friend's? Try those. Quote Link to comment Share on other sites More sharing options...
TaskenLander Posted June 20, 2015 Author Share Posted June 20, 2015 (edited) The game in question is Shenmue. I only own a handful of DC games but off the top of my head I know for a fact that Soul Calibur and Hydro Thunder also won't save progress. Don't have access to another DC sadly but I want to start being able to playing my DC so I'll probably just seek out a new console. Maybe someone here will have a 'Console only' for sale. Thanks for the suggestions/feedback, Mike Edited June 20, 2015 by TaskenLander Quote Link to comment Share on other sites More sharing options...
Crudex7xchris Posted March 24, 2022 Share Posted March 24, 2022 Having issues saving. Playing 102 dalmatians. Go up to the parrot to save. And it just says accessing VMU and never ends. I can stop it by pulling out the VMU but I get the same result every time. I have two VMU's and it does it with both Quote Link to comment Share on other sites More sharing options...
Video Posted March 26, 2022 Share Posted March 26, 2022 The build quality of dreamcast was absolutely abysmal. The consoles still work, I guess (turns on, reads disc) but the controllers all have failed to varying degrees. I've not saved anything in years, due to them not reading the vmu (all first party in my case) but many have up and decided its not going to read the controllers any more either. I got mine as a curiosity new when tru was blowing them out for sub $50, so my original systems are bought new, but even third hand systems I've picked up over the years suffer the same problem. I don't know what happened, but its got to be a build quality thing. I've even paid up for new controllers and vmu's before and same issue right out of the box. Its a pity, while dreamcast was never a favorite system of mine, it does have a huge library of quirky exclusive games. Quote Link to comment Share on other sites More sharing options...
Zap1982 Posted April 10, 2022 Share Posted April 10, 2022 (edited) On 3/24/2022 at 6:55 AM, Crudex7xchris said: Having issues saving. Playing 102 dalmatians. Go up to the parrot to save. And it just says accessing VMU and never ends. I can stop it by pulling out the VMU but I get the same result every time. I have two VMU's and it does it with both I wonder if this was ever resolved? Im not an expert here but curious if the issue was your controller perhaps where the memory card slot is. I am sure I once had this issue and it turned out to be my controller. I still have the same old batteries in my vmu, never needed changing as I put the little cardboard tab in everytime since 2000 ? I think some consoles do get quirky with old age. My Saturn I still play a lot of but if left for any length of time it gets very picky, sometimes it keeps crashing at the Sega Saturn Screen, other times it only plays first party games. If I want to play something else I need to put Sonic Jam or something in and then reset. It also flits between wanting the drive lid open or closed. I keep thinking of repair or replacement but it's been going on for that long now its like it has a personality. Edited April 10, 2022 by Zap1982 Quote Link to comment Share on other sites More sharing options...
