HackMac Posted June 25, 2015 Share Posted June 25, 2015 Recently I wondered about an often used assembly instruction for the TMS9900, the load immediately a.k.a. LI. That thing, that makes me wondering is the fact that this instruction alters the status flags L>, A> and EQ. I ask me, for what is this good? I mean, when I load a immediately constant value in a register, I know if the value is or is not EQ to zero, so I don't have to check it. So this code LI R0,>1234 JNE @ELSEWHERE doesn't make much sense. I never have seen any code or wrote code that do something like this. Is there a serious use case? Where is the benefit? Perhaps TI implement the instruction in that way to save resources in the CPU, so that the micro code could be smaller. But I think the instruction could run faster when skipping the useless status flags altering. What are your opinions? Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/ Share on other sites More sharing options...
JamesD Posted June 25, 2015 Share Posted June 25, 2015 Self modifying code could benefit from that. Some piece of code that follows several instructions later may also have multiple callers so it doesn't know what code set the status registers. 1 Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3264570 Share on other sites More sharing options...
+mizapf Posted June 25, 2015 Share Posted June 25, 2015 I believe there are many situations where the manufacturer, here TI, kept a feature for the sake of consistency, less because they are really useful. The immediate operations usually set the status flags according to the result of the operation. In this case, LI does not do anything exciting, but the question is whether we would be more surprised to see that the status flags are not set, although they are set with AI, ANDI, ORI etc. Another thing that almost qualifies for a facepalm is the implementation of MOV. If you have a look at the 9900 Family System Design Book you can find the fact that MOV loads the destination value first, although it will be overwritten in the next cycles. It could be understandable for MOVB (read-before-write), but in the case of MOV where nothing of the original destination value will be kept, this is somewhat surprising. (This was actually fixed in the 9995, as the 9995 does not require read-before-write.) Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3264614 Share on other sites More sharing options...
HackMac Posted June 26, 2015 Author Share Posted June 26, 2015 Ok, you see the immediate instructions in conjunction with their common op code format and you group them in a immediate instruction family. I see the LI as a specific form of a common load or set instruction like the LIMI or LWPI and CLR, SETO (the last two are special LI with an build in constant), SBO or SBZ instructions are also forms of a load instruction. All those instructions, but LI, has no affect on status flags. So why should LI be an exception? Well, of course you should think the load/set instructions are a special form of a memory move like MOV does, but with a very special addressing mode. Or better the other way: MOV is a special kind of a load instruction witch has various addressing modes. Therefore the MOV instruction has also a weird behavior. I believe LI and MOV are the most often used instructions and makes 70% of a program code. Because of unnecessary cycles of setting status flags, they slow down the execution time. In my opinion, and in addition of what Michael points to (the odd behavior of MOV and MOVB), CPU is really not well designed. But ok, we have to live with them. Therefore I ask me how we can use those behaviors for sophisticated programming techniques. Are there use cases in real live? Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265021 Share on other sites More sharing options...
Stuart Posted June 26, 2015 Share Posted June 26, 2015 As JamesD said above, the functionality is good for self-modifying code. An instruction might be LI R0,>1234 now, but code can over-write the value >1234. You might do this in a loop perhaps, incrementing what was the value >1234, and with a JEQ to break out of the loop when the value rolls over to zero. Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265029 Share on other sites More sharing options...
HackMac Posted June 26, 2015 Author Share Posted June 26, 2015 Yes I understand you and also I understood JamesD. Your use case is like kind of parameter passing (self modifying code is not a use case, its a programming technique). And where is the benefit? It is not very useful for parameter passing. There are better techniques. Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265040 Share on other sites More sharing options...
+Lee Stewart Posted June 26, 2015 Share Posted June 26, 2015 Clever programming with self-modifying code can certainly benefit from this behavior, as @JamesD and @Stuart have said; but, it is the second point @JamesD made that intrigues me. The fact that not one jump or branch instruction sets the status bits would allow the LI instruction to be used to load a register with a flag or index in several subroutines, or in several places in the same subroutine, to be used as a switch upon return. ...lee 1 Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265131 Share on other sites More sharing options...
HackMac Posted June 26, 2015 Author Share Posted June 26, 2015 (edited) Do you have some examples ready? Is there any known used implementation, where the operand of an LI is dynamically set? I'm not very creative to excogitate a scenario where LI is used to set/reset status bits. When I wish to manipulate single status bits, I would use a BLWP subprogram where I manipulate R15 and set it on the corresponding RTWP. And furthermore creating self manipulating programs is an ugly programming style and unusable in ROMS. Usually you define a byte witch is to set/reset/test. By the way TI forgot an LDST that correspond to STST, in that way how STWP correspond to LWPI Edited June 27, 2015 by HackMac Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265170 Share on other sites More sharing options...
Tursi Posted June 26, 2015 Share Posted June 26, 2015 Setting status flags usually happens in parallel with the movement of the data, so it doesn't likely have any performance impact. I'd expect it's just a microcode savings. Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265193 Share on other sites More sharing options...
+Lee Stewart Posted June 26, 2015 Share Posted June 26, 2015 (edited) Do you have some examples ready? Not really, unless you would consider some of the following as such. Is there any known used implementation, where the operand of an LI is dynamically set? The destination operand of the LI instruction is always “dynamically set”. Dynamically setting the immediate operand (self-modifying code) was not the point of my comment. I'm not very creative to excogitate a scenario where LI is used to set/reset status bits. LI R5,0 L = 0; A = 0; EQ = 1 LI R5,1 L = 1; A = 1; EQ = 0 LI R5,>8000 L = 1; A = 0; EQ = 0 LI R5,SRADDR L = ?; A = ?; EQ = ? The first three could be used for tri-state decisions. Not sure how useful the following would be: The fourth could be used to detect whether a subroutine’s address (SRADDR) is in high RAM before actually taking the branch. There are surely other useful scenarios that would benefit from the speed of LI over MOV. When I wish to manipulate single status bits, I would use a BLWP subprogram where I manipulate R15 and set it on the corresponding RTWP. Very much slower, if manipulating the L, A and EQ bits is all that is necessary. And furthermore creating self manipulating programs is an ugly programming style and unusable in ROMS. Again, not my point. Usually you define a byte which is to set/reset/test. ??? By the way TI forgot an LDST that correspond to STST, in that way how STWP correspond to LWPI I respectfully disagree. To me, the point of STST is to preserve a status for later consideration before a subsequent instruction mucks it up. ...lee Edited March 25, 2016 by Lee Stewart Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265206 Share on other sites More sharing options...
Asmusr Posted June 26, 2015 Share Posted June 26, 2015 Just wondering if CLR R0 also involves a read before write? Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265334 Share on other sites More sharing options...
+mizapf Posted June 26, 2015 Share Posted June 26, 2015 Yes. The reason is that for commands which support various addressing modes (CLR R0, CLR *R0, CLR *R0+ ...), the general "data derivation sequence" is executed which required to load a word at its start. That is, for Workspace Register addressing, the value of the register is always loaded first. Then, the value is changed to 0000 internally, and finally, the write operation takes place. In the 9995, the "data derivation sequence" was replaced by the "address derivation sequence". The latter does not necessarily entail a memory operation. Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265397 Share on other sites More sharing options...
HackMac Posted June 27, 2015 Author Share Posted June 27, 2015 My english must be too bad, no one understood me in the way I want. I'm done. Lee is a bit too serious/rational for me. Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265623 Share on other sites More sharing options...
JamesD Posted June 27, 2015 Share Posted June 27, 2015 (edited) My english must be too bad, no one understood me in the way I want. I'm done. Lee is a bit too serious/rational for me. Look at what you asked. Recently I wondered about an often used assembly instruction for the TMS9900, the load immediately a.k.a. LI. That thing, that makes me wondering is the fact that this instruction alters the status flags L>, A> and EQ. I ask me, for what is this good? I mean, when I load a immediately constant value in a register, I know if the value is or is not EQ to zero, so I don't have to check it. So this code LI R0,>1234 JNE @ELSEWHERE doesn't make much sense. I never have seen any code or wrote code that do something like this. Is there a serious use case? Where is the benefit? Perhaps TI implement the instruction in that way to save resources in the CPU, so that the micro code could be smaller. But I think the instruction could run faster when skipping the useless status flags altering. What are your opinions? You say it doesn't make much sense and you ask where is the benefit. To put the answer another way... it makes perfect sense and we have already stated the benefits. Assembly is a general purpose language meant to be able to implement pretty much anything. An interpreter, compiler, game, word processor, database manager, recipe file program... whatever. The way instructions are decoded in hardware is designed to reuse things like setting status bits. Every time you LD, no matter which form of the instruction, you set the status bits. All LD functions are consistent in their behavior. It simplifies decoding the instruction in hardware whether you use the status bits or not and programmers can always depend on the status bits being set if they use a LD instruction. Do you know how much more difficult it would be to learn assembly if behavior of instructions varied just based on whether or not someone thought something made sense? Have a look at all the special cases for which instructions can be used on which registers on the Z80 and you will understand what I'm getting at. We already told you some other benefits. Just because you don't like self modifying code does not mean it's not a benefit. You keep looking at it through your narrow snippit of code and don't seem to understand what we are saying. You probably haven't seen code like that because you only want to look at it through that exact sequence of instructions. Make this small change to the code: LI R0,>1234 ... Subroutine: ... JNE @ELSEWHERE The LI is now setting a parameter for the subroutine and falling through into it. The "..." indicates some instructions that do no modify the status flags or may leave them alone under certain circumstances. The subroutine can also be called from anywhere else and the JNE instruction has no idea what set the status flags so you cannot presume to know if the value in R0 is zero, positive, negative or otherwise. The status bits are set for consistency in the instruction set. Self modifying code could take advantage of it. And you cannot assume that a sequence of instruction will know where the status bits are set so you cannot assume to know what they are. Just because your code snippet doesn't make sense to you does not mean an instruction's functionality does't make any sense. Would this make sense? LD R0,<1234 LD R0,<4321 Does that mean the instruction used doesn't make sense? Or does it mean the programmer's logic doesn't make sense? Edited June 27, 2015 by JamesD Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265665 Share on other sites More sharing options...
+Lee Stewart Posted June 27, 2015 Share Posted June 27, 2015 My english must be too bad, no one understood me in the way I want. I'm done. Lee is a bit too serious/rational for me. Your English is fine. Misunderstanding will happen among native speakers. That is precisely why I segmented your quote. I wanted my responses to be as clear as I could make them. Rest assured, I am not always right. I have been disabused of conclusions I have drawn by some of the folks in this very thread. Perhaps my use of bold type was a little over the top. That is why I attempted to soften it with a blue color. My intention was to make a good separation between quoting you and my comments. I viewed it with the default page theme for this forum and my comments do look a little more like I am shouting than they do in the “Gravity” theme I have been using. I likely appeared a bit more of a jerk than I normally do. I dialed back the bold in my last post. And—don't give up so easily. You have been on this forum long enough to observe that, at times, discussions get passionate; but, progress usually gets made. ...lee Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265724 Share on other sites More sharing options...
+Ksarul Posted June 27, 2015 Share Posted June 27, 2015 I definitely agree there--the discussion has made clear some of the quirks of programming in Assembly that can be used to the programmer's advantage. Thanks for starting the discussion, HackMac! No problems with your English at all--and although I could hack my points across in French--your English is definitely better than my French (I would do better in German or Turkish, but I'm sure I'd make weird mistakes in both of those too). Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265782 Share on other sites More sharing options...
JamesD Posted June 27, 2015 Share Posted June 27, 2015 (edited) I definitely agree there--the discussion has made clear some of the quirks of programming in Assembly that can be used to the programmer's advantage. Thanks for starting the discussion, HackMac! No problems with your English at all--and although I could hack my points across in French--your English is definitely better than my French (I would do better in German or Turkish, but I'm sure I'd make weird mistakes in both of those too). Exactly. There are any number of ways to implement an algorithm in assembly language. You can make your code easy to follow, optimized for space, optimized for speed, or any combination of those. I've seen some really strange code and you should never assume code should obviously make sense. If we were talking about the 6502, you even have illegal instructions that do so odd things that have been used to save a few more clock cycles in some code. *edit* And don't forget, assembly code can do some really weird things and still work, even if just by accident. Edited June 27, 2015 by JamesD Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3265805 Share on other sites More sharing options...
RXB Posted June 28, 2015 Share Posted June 28, 2015 Recently I wondered about an often used assembly instruction for the TMS9900, the load immediately a.k.a. LI. That thing, that makes me wondering is the fact that this instruction alters the status flags L>, A> and EQ. I ask me, for what is this good? I mean, when I load a immediately constant value in a register, I know if the value is or is not EQ to zero, so I don't have to check it. So this code LI R0,>1234 JNE @ELSEWHERE doesn't make much sense. I never have seen any code or wrote code that do something like this. Is there a serious use case? Where is the benefit? Perhaps TI implement the instruction in that way to save resources in the CPU, so that the micro code could be smaller. But I think the instruction could run faster when skipping the useless status flags altering. What are your opinions? Self modification code in any Language saves space and when programs are smaller they are better. Several sections of Self Modified Code can actually run faster then huge jumps and sections of loading values over and over. Objective C and other computer languages save space, operate faster and if done properly is much more efficient. Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3266230 Share on other sites More sharing options...
matthew180 Posted July 2, 2015 Share Posted July 2, 2015 (edited) Perhaps TI implement the instruction in that way to save resources in the CPU, so that the micro code could be smaller. But I think the instruction could run faster when skipping the useless status flags altering. What are your opinions? You answered your own question. However, it seems you are thinking of the hardware from a software perspective. In order to write a value to a workspace register the value has to come from the ALU output (that's just the way the 9900 is designed), and setting the status flags is something the ALU does automatically. So you get the status update for free and, as Tursi mentioned, updating the status flags probably happens in parallel to other CPU activity. If there was a discrete machine state dedicated to latching the status flip-flops, it would be 333ns long, so hardly a slow-down. The LI is not lumped with LIMI or LWPI because those instructions deal with updating true *internal* registers of the 9900 and have dedicated opcodes. The LI instruction works with the general-purpose registers, which are not part of the CPU itself, and require external memory access. LI is properly grouped with the other Immediate instructions based on how it functions internally. Just because the LI affects the flags does not mean it necessarily makes sense to act on them after the instruction. It would have taken more hardware or a special case to suppress the status flags update for LI, and in hardware every transistor matters. Reducing cost, die transistors, and circuit complexity weigh more heavily than avoiding nuances like LI updating the status flags. If you look hard enough you will certainly find other instructions that have the similar kinds of side effect. You will also find these kinds of nuances in every CPU. The key as a programmer is knowing that this is going to happen and writing your code accordingly. Edited July 2, 2015 by matthew180 1 Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3269427 Share on other sites More sharing options...
+InsaneMultitasker Posted July 2, 2015 Share Posted July 2, 2015 Do you have some examples ready? Is there any known used implementation, where the operand of an LI is dynamically set? I'm not very creative to excogitate a scenario where LI is used to set/reset status bits. When I wish to manipulate single status bits, I would use a BLWP subprogram where I manipulate R15 and set it on the corresponding RTWP. And furthermore creating self manipulating programs is an ugly programming style and unusable in ROMS. Usually you define a byte witch is to set/reset/test. By the way TI forgot an LDST that correspond to STST, in that way how STWP correspond to LWPI I don't know that there is any benefit to restore the status register as you describe. Often the intent (and use) of STST is to allow for subsequent (and potentially consecutive) tests on the saved status value. You can also push the saved status back to a calling (or different) workspace prior to a RTWP to perform some interesting magic. Somewhere in the archives there are examples of self-modifying code that are very handy. One of my common self-modifying code pairs is to load a subroutine's return address into a "B @>xxxx". A stack is not required, the branch address is updated at the start of the subroutine, and the branch substitutes as return with no register use required. Example: SUB1 MOV R11,@RET+2 .. .. RET B @0000 I would argue that self-modifying code can be quite helpful and certainly not ugly, IMHO. As for ROM, I never consider that an issue as all of my programs are intended to run within RAM. 3 Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3269559 Share on other sites More sharing options...
Tursi Posted July 3, 2015 Share Posted July 3, 2015 Never thought of that return trick before - interesting! Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3269915 Share on other sites More sharing options...
Asmusr Posted July 3, 2015 Share Posted July 3, 2015 I usually avoid self modifying code, but I used it recently in a soft sprites routine, to set up fixed shift instructions instead of having to load R0 with the shift value - saved a few clock cycles. ********************************************************************* * * Display a soft sprite at any position * The pattern must be provided as a 'natural' bitmap of R3 lines of * 8 * R2 pixels where a line extends all the way across the sprite. * * R0 x coordinate * R1 y coordinate * R2 Width in bytes (of 8 pixels) * R3 Height in pixels * R4 Pattern address * R5 Mask address * SFTSPR MOV R11,*R10+ * Push return address onto the stack BL @SCRADR * R6 = byte offset, R7 = bit offset AI R6,SCRBUF * Add screen buffer offset * Setup shift instructions LI R1,8 * 8 S R7,R1 * 8 - bit offset SLA R1,4 * Move into place for SLA instruction MOV @SLAX,R0 * Get op code for SLA Rx,0 SOC R1,R0 * Set shift MOV R0,@SLAX1 * Write into program MOV @SLAY,R0 * Get op code for SLA Ry,0 SOC R1,R0 * Set shift MOV R0,@SLAY1 * Write into program * 2nd group of shifts MOV R7,R1 * Bit offset JEQ SFTSP1 * Check if shift would be zero SLA R1,4 * Move into place for SLA instruction MOV @SLAX,R0 * Get op code for SLA Rx,0 SOC R1,R0 * Set shift MOV R0,@SLAX2 * Write into program MOV @SLAY,R0 * Get op code for SLA Ry,0 SOC R1,R0 * Set shift MOV R0,@SLAY2 * Write into program JMP SFTSP2 * Replace shifts with nops SFTSP1 MOV @NOOP,R0 MOV R0,@SLAX2 MOV R0,@SLAY2 * Line loop SFTSP2 MOV R2,R12 * Save the width SFTSP3 MOV R6,R7 * Save the destination address CLR R8 * Pattern register CLR R9 * Mask register * Byte loop MOV R12,R2 * Restore width SFTSP4 MOVB *R4+,@R8LB * Get pattern byte in LSB MOVB *R5+,@R9LB * Get mask byte in LSB SLAX1 SLA R8,0 * Shift (8 - bit offset) bits into MSB SLAY1 SLA R9,0 * Actual shift values will be inserted MOVB *R6,R1 * Get existing screen buffer byte SZCB R9,R1 * Remove bits not set in mask SOCB R8,R1 * Set pattern bits MOVB R1,*R6 * Write byte back AI R6,8 * Next byte in line DEC R2 JEQ SFTSP5 SLAX2 SLA R8,0 * Shift (bit offset) bits into MSB SLAY2 SLA R9,0 * Actual shift values will be inserted JMP SFTSP4 * Final byte SFTSP5 SWPB R8 SWPB R9 MOVB *R6,R1 * Get existing screen buffer byte SZCB R9,R1 * Remove bits not set in mask SOCB R8,R1 * Set pattern bits MOVB R1,*R6 * Write byte back * Next line MOV R7,R6 * Restore destination address COC @SEVEN,R6 * Check for last character row JEQ SFTSP6 INC R6 * Next row within character JMP SFTSP7 SFTSP6 AI R6,256-7 * First row of next character SFTSP7 DEC R3 JNE SFTSP3 * Return DECT R10 * Pop return address off the stack MOV *R10,R11 B *R11 * Instructions SLAX SLA R8,0 SLAY SLA R9,0 NOOP NOP *// SFTSPR 1 Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3270078 Share on other sites More sharing options...
Dexter Posted July 3, 2015 Share Posted July 3, 2015 One of my common self-modifying code pairs is to load a subroutine's return address into a "B @>xxxx". A stack is not required, the branch address is updated at the start of the subroutine, and the branch substitutes as return with no register use required. Example: SUB1 MOV R11,@RET+2 .. .. RET B @0000 Yep, I did put that one into my notes! You mentioned in Matthew's Assembly thread. I haven't used it yet, but it's too nice ignore Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3270133 Share on other sites More sharing options...
Tursi Posted July 4, 2015 Share Posted July 4, 2015 I usually avoid self modifying code, but I used it recently in a soft sprites routine, to set up fixed shift instructions instead of having to load R0 with the shift value - saved a few clock cycles. Remember too, if you can spare the register (or want to use a variable in RAM) that X can also be used to replace a single instruction. It doesn't save as many cycles, but it works from ROM. I've generally tried to use that since we have it, though I'm not too much against self-modifying code. (I've mostly used it to save extra comparisons in loops ). Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3270718 Share on other sites More sharing options...
Asmusr Posted July 4, 2015 Share Posted July 4, 2015 Remember too, if you can spare the register (or want to use a variable in RAM) that X can also be used to replace a single instruction. It doesn't save as many cycles, but it works from ROM. I've generally tried to use that since we have it, though I'm not too much against self-modifying code. (I've mostly used it to save extra comparisons in loops ). X is on my list of weird stuff I will try some day along with BLWP and the ISR . 1 Quote Link to comment https://forums.atariage.com/topic/239767-philosophic-assembler-use-cases-programming-tipps/#findComment-3270914 Share on other sites More sharing options...
