thegamezmaster Posted June 27, 2015 Share Posted June 27, 2015 I have one that only shows white and grey blocky shapes on screen. Cleaned and checked connector, solder joints, and checked for broken traces with no luck. Anyone ever had this problem and or know how to fix or what should I do next? Appreciate any help with this. Thank you. Quote Link to comment Share on other sites More sharing options...
CatPix Posted June 27, 2015 Share Posted June 27, 2015 I canse you do'nt know, you have to press "reset" to boot up games. Might be a defective cart, too. The screen you describe is typical of what the O² displays without any cart inserted. Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted June 27, 2015 Author Share Posted June 27, 2015 I canse you do'nt know, you have to press "reset" to boot up games. Might be a defective cart, too. The screen you describe is typical of what the O² displays without any cart inserted. Didn't know that but will give it a try and post result. Thank you for the tip! Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted June 27, 2015 Author Share Posted June 27, 2015 (edited) Tried pressing the reset button, nothing. Then tried holding down the reset button and powering up, first same white and grey screen, power again got either the same screen with some color or a blue screen, power again with reset held got a dark screen. Can anyone please help me with this? Thank you! Sorry the letters are small, don't know why? Edited June 27, 2015 by thegamezmaster Quote Link to comment Share on other sites More sharing options...
SSG Posted July 25, 2015 Share Posted July 25, 2015 Did you check for any fried electronic components? Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted August 4, 2015 Author Share Posted August 4, 2015 Did you check for any fried electronic components? Didn't see anything that looked fired. Quote Link to comment Share on other sites More sharing options...
SSG Posted August 4, 2015 Share Posted August 4, 2015 Did you try any other games? Quote Link to comment Share on other sites More sharing options...
thegamezmaster Posted August 6, 2015 Author Share Posted August 6, 2015 Did you try any other games? Tried several different games with the same results. Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted November 15, 2015 Share Posted November 15, 2015 Try spraying the circuit board with contact cleaner. I also go over the contacts with an alcohol qtip too. Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
