icemanxp300 Posted June 30, 2015 Share Posted June 30, 2015 Not the systems, pins were cleaned very well. I actually have had this broken cart for years now and just got into soldering boards and such and figured I might be able to fix. I see no bad connections. Does anyone have a pin-out diagram of where continuity should be? How can I test stuff like resistors, caps, and chips. I know I could dump the roms and see what they look like. I might just try swapping roms onto a diff board. ... Quote Link to comment Share on other sites More sharing options...
icemanxp300 Posted June 30, 2015 Author Share Posted June 30, 2015 Well I know it is not the cic or capacitor I swapped them w/1080 and they work on 1080 and paper Mario still doesn't work. Quote Link to comment Share on other sites More sharing options...
icemanxp300 Posted June 30, 2015 Author Share Posted June 30, 2015 (edited) Found it. The bottom mask rom if looking from back side had a faulty contact under the pin on bottom left. It would be consider pin 28 if looking at rom normally. The trace looked fine but it was split at hole around pins solder joint. Soon as I sucked solder out the entire ring came out w/it. I was like come on. I ran a new wire from pin to corresponding pin 28 of both roms and it works now. I was getting faulty continuity readings as I pushed down on the contact essentially pushing the pad down to make contact again. Edited June 30, 2015 by icemanxp300 1 Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted July 1, 2015 Share Posted July 1, 2015 Now go play it! Great game.. Quote Link to comment Share on other sites More sharing options...
